Tamron 17-35mm vs Canon 10-18mm
Started Feb 3, 2015 | Questions
ebphotography New Member • Posts: 1
I am trying to buy an inexpensive wide angle lens for my canon t3i. My main purpose for the lens is my trip to peru so it will be used mostly outdoors for wide angle landscapes.
I am debating between the 17-35mm by tamron and the canon 10-18. They are around the same price but vary in the wide angle. I am wondering what I would be sacrificing with image quality if at all with the tamron lens because it doesn't have image stability.
Basically what I want to know is what is going to give me the best image quality for a wide angle shot for landscapes such as Machu Picchu:)
Peter Kwok
Peter Kwok Senior Member • Posts: 2,635
Tamron 17-35mm is NOT very wide
The Tamron 17-35mm is designed for full frame bodies such as the 5D Mk3. On a crop body such as your T3i, it is about as wide as a typical kit lens.
The Canon 10-18 is an ultra-wide. I would get this lens for outdoor wide view.
Peter Kwok
Click here for my PBase gallery
WYSIWYG - If you don't like what you get, try to see differently.
 Peter Kwok's gear list:Peter Kwok's gear list
Canon EOS 5DS Canon EOS R5 Canon EF 16-35mm F4L IS USM Canon RF 14-35mm F4L IS USM Canon EOS M6 +8 more
The1willy Forum Member • Posts: 92
Re: Tamron 17-35mm vs Canon 10-18mm
Well the tamron 17-35 isn't really a very wide angle lens on the t3i. I have one and use it on a 6D and 5D where it is a wide angle. My copy works fine and produces some great shot, but it is an old lens.
For a crop body the tamron 17-50 f2.8 would probably be a better bet. I had one when I had my t4i and used it a lot, it has great IQ and a constant f2.8 throughout the range and gives you a bit more reach.
But again, 17mm at the wide end isn't exactly ultra wide on a crop,the 17-50 is more a 'standard zoom' .
So if you really want ultra wide the Canon 10-18 or 10-22 are your best options. I had the sigma 10-20 with my t4i but was never really that impressed with my copy.
Good luck with your decision!
 The1willy's gear list:The1willy's gear list
Canon EF 24-105mm f/4L IS USM Canon EOS 5D Canon EOS 6D Canon EF 50mm F1.4 USM Tamron AF 28-300mm F/3.5-6.3 XR Di VC LD Aspherical (IF) Macro +1 more
jvc1 Senior Member • Posts: 2,202
You can't beat the 10-18 for the price. The IQ is quite good if you have decent light. I hope that you're taking another longer "walk around" lens. The 10-18 doesn't provide much range.
 jvc1's gear list:jvc1's gear list
Canon EOS Rebel SL2 Canon EOS 90D Canon EF 85mm F1.8 USM Canon EF-S 15-85mm f/3.5-5.6 IS USM Canon EF-S 60mm f/2.8 Macro USM +10 more
Alastair Norcross
Alastair Norcross Veteran Member • Posts: 9,874
The 10-18 is a really good lens, especially for the money. The IS is also great for landscapes, allowing you to shoot stopped down a bit, and still keep the ISO low, even in fading light. At 10mm, I can shoot handheld down to about 1/2 second. You could pair it with the 18-55 IS STM, and get good quality coverage from ultra-wide to modest telephoto really cheaply.
As the length of a thread approaches 150, the probability that someone will make the obvious "it's not the camera, it's the photographer" remark approaches 1.
Alastair
http://anorcross.smugmug.com
Equipment in profile
 Alastair Norcross's gear list:Alastair Norcross's gear list
Canon G7 X II Canon EOS M6 II Canon EOS R7 Canon EOS R6 Mark II Canon RF 35mm F1.8 IS STM Macro +24 more
victorian squid
victorian squid Veteran Member • Posts: 3,391
As everybody else says - the 10-18 is a real winner. Canon hit it out of the park with this one, and they've been cannibalizing sales of their 10-22 with this inexpensive lens.
The Tamron 17-35 as mentioned is for FF. I've always suspected and now I know that lenses designed for crop perform much better than those for FF. My Sigma 17-50/2.8 OS is nearly identical in sharpness to my EF 24-70/2.8 II on my 70D. On my 6D, the 24-70/2.8 has much higher resolution. In fact, this lens, or the Tamron 17-50/2.8 VC would be excellent as well.
a 10-20 or thereabouts is a true UWA for crop. 17 is not wide enough, but this lens makes for a good compromise if you've only got 1 lens to choose. 10-20 can come close to walk-around, but not quite.
I have a Sigma 10-20/4-5.6 for crop and love it. I could highly recommend this lens in used versions, even though the other poster here wasn't impressed. I had a 3.5 for a while I didn't think was as good, but I may have had a duff copy. I shoot interiors for my company, and I never traded that lens in as nothing was that much better. Not until I went to FF could I make a noticeable improvement.
So really, bottom line - not the Tamron 17-35. It wasn't even that good of a lens when new.
Above examples of the Sigma 10-20 on XTi or 60D.
Above Sigma 17-50/2.8 OS on 60D or 70D.
24-70 performance on 70D
Sigma 17-50 performance on 70D - $600 vs $2200
The advantage you'd have with a lens like the 17-50 is an aperture of 2.8. This is pretty important if shooting inside without flash. For wide angle there's the Tokina 11-16/2.8, which might be getting lower in price now that they've replaced it with the 11-20. A true wide angle is very handy when you're in cramped spaces. My 10-20 can make a bathroom look big enough to roller skate in!
 victorian squid's gear list:victorian squid's gear list
Canon EOS 6D Canon EOS 70D Canon EF 24-70mm F2.8L II USM Tamron SP 150-600mm F5-6.3 Di VC USD Canon EF 16-35mm F4L IS USM +37 more
