Impulses wrote:
Impulses wrote:
Hmm, forum's buggy again and interfering with edits...
I'm actually considering the 12mm and I appreciate the review btw. Are you using the OEM/JJC hood with the tightening thumb screw or an aftermarket one that screws into the filter threads?
Seems like the latter might pack away smaller, but the former might be easier to attach... Downside of a metal build I guess, makes it hard to add an even smaller bayonet mount hood like the 9-18's.
Personally, I went for the small Contax GG-2 hood shown here
http://www.dpreview.com/forums/post/41919316
over the original and the JJC. I have a Contax cap for it so that I can cap the lens without taking the hood off.
Interesting, thanks for sharing that... Looks nice and compact compared to the Oly/JJC or even most screw in alternatives I'd seen...
Yes. As you can see from the thread I linked to, it took a little digging to find it and I doubt that there is anything better out there, based on my personal preferences.
I added the one linked below to a recent Amazon order but with an outside diameter of 70mm+ it might be pretty bulky (or more splayed out than it needs to be to even work effectively), haven't received it yet:
http://smile.amazon.com/gp/aw/d/B009GFYA4W/ref=pd_aw_sbs_p_15?refRID=0TAN0JTW8JWV5X0FHSRQ
Yes, you should be able to find something better than that.
Might just order that GG-2 when I order the 12mm. Seems they've got some Kiwi branded knockoffs on eBay for $20 and the originals for $28? The backside curve is shaped a little differently between those...
Yes, I am aware of the Kiwi knockoffs. I considered those but in the end went for the original for reasons outlined below.
I imagine there's no threads for a clip in cap, hence the slip on? Oddly I found those caps (GK-54) cheaper on Amazon ($4-9) than eBay ($10+).
http://smile.amazon.com/gp/aw/d/B00G349XP0/ref=pd_aw_sim_p_2?refRID=0N7ZGZB0ZNDCXZZP6QM7
The original GG-2 has threads for a clip-in cap so you are not forced to go with the slip-on. And I'd say the latter isn't the self-evident solution in this case. The main pro of the original slip-on is that it looks cool. Put the 12/2 with the GG-2 hood and cap on a silver E-M5, and you've got something looking really old-school in a classy way. The downsides are that it is more expensive and not so securely fastened. Mine is getting increasingly insecure in that regard as the felt on the inside of the rim is being compressed/worn with use. It is still OK the way I handle it. But I wouldn't try walking around with the lens capped but mounted on the camera.
In case you decide to get a clip-in cap, the internal diameter of the original GG-2 is about 54 mm (external about 57 mm).
Don't know if the Kiwi knockoffs have threads and as I recall (it's been a while now) that may have been one of the reasons I went for the original GG-2. Possibly, I asked this question myself (perhaps in the thread I linked to, perhaps somewhere else) and got it answered. But I am afraid no longer remember what the answer was if there was one.
Is the hood on the photo within the post you linked supposed to be silver?
Yes.
Looks really weird/dark on my end...
That's just the photo. Compared to the silver on the lens, that on the hood is a tad less shiny and a tad more yellowish. But the difference is small enough that you'd notice it only if you look for it. I bet that people who just give it a casual look, even at close distance, would think that the hood is originally made for the lens. I am less sure how the Kiwi blends in, which was another reason I went for the original. Oddly, the cap is a slightly different shade than the hood (a bit more like the lens) although that too is Contax original.
I see the Kiwi branded ones in silver & black on eBay; and the original in silver only although there's a set with GG-1, GG-2, and GG-3 replacements plus the cap all in black for $32, go figure. Not even sure what color 12mm I'll end up with.
http://m.ebay.com/itm/181650115698?nav=SEARCH
http://m.ebay.com/itm/161556829091?nav=SEARCH
http://m.ebay.com/itm/110321977698?nav=SEARCH
If you go for a black lens, then the Kiwi would seem like a pretty self-evident choice, any trouble with capping aside.
Kind of inconsequential I guess, I've got a little silver Fotasy screw-in metal hood on my black 45mm and I think it looks fine (it's slimmer than others and closely matches the diameter of the lens barrel), but still...
Seems like we have similar hood tastes. If the hood is the one I think it is, then I use the same on my 45/1.8. My lens is silver though, so no obvious contrast with the hood. However, the hood is more shiny than the silver plastic of the lens barrel in this case.
