zoom lens for my E-pm2 ,,,,???؟؟؟
Started Feb 1, 2015 | Discussions
sam991 Junior Member • Posts: 26
hello everybody
as in title
I was asking about pm2 and finally buy it !!! loool cool camera
anyway I am looking for good zoom lens and i want low price
so I find pany 45-200mm and oly 40-150mm
no compare size an weight ( for sure the pany bigger and heavy )
I am asking about 3 things (IQ - focus - sharpness )
I like the extra reach of the pany (200mm vs 150 mm on oly ) but
I read so many thread
some say / the pany is get soft 150 to 200 and oly is better
and some see the pany is sharp and the oly get soft at 150mm and the extra 50mm is worth on pany
I am really confused !!??? as i told you I like the extra + 50mm  for the pany to get extra recah
but I am afraid the lens is not good in 200mm or even in 150mm
or get the oly and safe $  + lightweight + compact size
So my big question / which one is better ?? I want the lens for birds -moon and other far subject ) ??
any advice ??
thanks in advance for help
Olympus PEN E-PM2
(unknown member) Veteran Member • Posts: 3,010
Re: zoom lens for my E-pm2 ,,,,???؟؟؟
sam991 wrote:
hello everybody
as in title
any advice ??
Maybe neither. How serious are you about birding? I have the 40-150mm Olympus and it's a good lens. I can't comment on the Panasonic because I know very little about it. I ended up buying the Olympus 75-300mm for birds. Birds are small. The 150mm length was too short for me and I suspect the 200mm Panasonic would have been also. Since I got the 75-300 I rarely use the 40-150. The problem is the Olympus 75-300 is twice the price of the Panasonic. I also have the EPM2 and it very usable on that body. I don't find any issues with the handling. So if you are very serious about birding then get the Olympus 75-300 and pay the extra. It's worth it. I paid $150 dollars for my 40-150 and it sits unused.  Did I mention that birds are small.
Alexsfo Senior Member • Posts: 2,362
Panny 45-175mm is great for E-PM2, lightweight and very effective OIS.
 Alexsfo's gear list:Alexsfo's gear list
Canon EOS 5D Mark IV Canon EOS M6 II Canon EF-M 22mm f/2 STM Canon EF 35mm F2 IS USM Canon EF 24-70mm F4L IS USM +4 more
OP sam991 Junior Member • Posts: 26
thank you all of U guys you the Best
I can't buy oly 75-300mm (high cost for me)
ammm the 45-175mm it's very nice lens (compact - high built quality ) but also high price
I know you give me the best zoom lens to choose but Unfortunately, I can't handle the price
I found the pany for 200 usd and oly for 165 usd
but the 45-175 is 2x cost more than pany 45-200
and oly 75-300 also cost more than 2x than the 40-150
so what the best between these 2 lenses :
pany 45-200mm vs oly 40-150mm ??
So the Question is now
PANASONIC 45-200 MM OR  OLYMPUS 40-150 MM F4-5.6 .... ???
I am sorry but the pany 45-175 & oly 75-300 out of my range (my budget is limit by to $200 usd)
http://www.photozone.de/olympus--four-thirds-lens-tests/417-pana_45200_456?start=2
http://www.photozone.de/m43/780_oly40150r?start=2
One thing to think about is Chromatic Aberations. CA is the purple fringing you sometimes see in photos. The Panasonic is  high in CA. Panasonic cameras automatically correct this when it creates a jpg but the EPM2 does not. So you have to edit them out with software like Photo Shop . If you just want to take good photos without the fuss get the Olympus. The Panasonic is probably sharper overall but you may have some CA issues.  Personally I would save up my money and get the 75-300 in the long run you won't be sorry. If not get the Olympus 40-150.
rube39 Veteran Member • Posts: 8,462
I have both, currently use neither (I use the Oy 75-300 instead). Although the Oly is smaller and lighter, I personally like the Pany better, mostly for the longer reach. Plus I have a good copy of the Pany. Lenses like there often vary in quality.
Brought the Oly40-150 and the cheap Sigma 60 to the zoo today. The Sigma blew the Oly away!
Rube
Allan Brown
Allan Brown Veteran Member • Posts: 3,179
The Panasonic 45-200 has very good OIS whereas the Olympus has none. The IBIS in the EPM2 is mediocre at best. Also, the Panasonic OIS will give you a stabilized preview which the IBIS will not give you. So, you will be a lot further ahead by buying the Panasonic.
If you do buy the Panasonic, make sure you have Lens Priority turned ON in the EPM2's menu.
I find my copy of the 45-200 to be quite good at 200.
Allan
thank you so much for helping me !! I am really glad that I am here
ammm..... so the end of story ,, the pany 45-200mm is not recommended because of the CA
anyway dose the CA Corrupts the IQ ??? because I like the extra 50mm reach
If the CA Corrupts the Image Q ok I will get the oly 40-150mm + Olympus TCON-14B (teleconvert 1.4x) ?? is it good idea ???
Allan
hi thank you Allan
so you have the pany 45-200mm good I have questons for please
did you have test another lens (like 40-150 olympus) compare to 45-200mm ??
did you notic the CA ( Chromatic aberration ) in your photo ?? because the guys here told me this lens has high CA and the Olympus body doesn't have auto correction for CA ???
Allan Brown
Very bad reason to dismiss this lens. All lenses have CA to some degree. You need to find out what CA is.
I use Panasonic lenses quite often on my Olympus bodies and I also use Olympus lenses on my Panasonic bodies and they are just fine. I never wory about which combination is going to produce what amount of CA. If you find you do have CA, then remove it during processing.
CA is produced by the lens under certain conditions such as tree branches against a bright sky. How much depends on many factors. Your EPM2 does not remove this effect for any lens including Olympus lenses while Panasonic bodies will remove it for Panasonic lenses. There are a couple of bodies that will do both.
The 45-200 will be better than the Oly 40-150 with the TCON-14b.
Allan
Allan Brown
Allan
hi thank you Allan
I did not buy the Oly 40-150 as it does not have OIS and the EPM2's IBIS is poor. The 45-200 works well on my Panasonic and Olympus bodies.
Why is OIS important? with a longer lens like this, without some form of stabilization, it will be difficult to compose the photo as the image will be jumping around on the screen. The EPM2's IBIS only stabilizes during exposure. The OIS will provide a stabilized image for composing.
Your EPM2 does not have auto correction for any lens including Olympus lenses. I see some CA with my Olympus lenses as well.
I have an EPM1 and an EPL5 and use my Panasonic lenses with those bodies.
Allan
Allan
http://www.flickr.com/photos/90891174@N04/
Your probably right. I had a legacy zoom with bad CA so I was really put off by it. I guess modern lenses aren't as bad. Not sure if he wants to get into PP. But the extra 50mm will make a big difference.
thank you for ssupport my thread
so the panasonic 45-200mm is not that bad and it's better than  olympus 40-150mm right ?
guys thank so much for advice
I just bought the pany 45-200mm can't wait it to get
hope it arrive sooner ,,,,
Congratulations on you purchase. I'm sure you will enjoy it. That lens will add a new world to you photography.
