E-PM2 video recording duration
Started Jan 31, 2015 | Discussions
yjaquinas New Member • Posts: 8
I have been using an Ipad as a video recording device for few years. It works fine for what I am doing, but the level of grain is too much. I was hoping that maybe using E-PM2 with lower ISO, noise reduction, bigger aperture size may help improving the video image quality.
I usually leave the machine running (recording video) for about an hour.
Today I have tried using E-PM2 instead of Ipad, but it had powered down by itself after about 25 min into recording, missing another half of what I wanted to capture.
The memory space is mostly empty 3.6GB video recorded on 32GB SanDisk Extreme PLUS (80 MB/s).
I was able to power on the camera and the battery showed "full" on the screen, probably 1/5 gone, for the camera runs about 150 min.
I want to know if anyone else is experiencing the same thing, if anyone is using this camera as a camcorder.
Olympus PEN E-PM2
(unknown member) Veteran Member • Posts: 3,010
Re: E-PM2 video recording duration
I'm pretty sure there is a time limit on recording built in so the sensor doesn't overheat.
Corkcampbell
Corkcampbell Forum Pro • Posts: 18,895
A quick Google search would have found your answer.
A quick Google search would have found your answer. This is from the Imaging Resource review of the camera
"The continuous movie recording duration limit changes depending on file format and bit rate setting. For both 1080p and 720p HD video, recording is limited to approximately 29 minutes for Normal bit rate and 22 minutes for Fine bit rate. For M-JPEG format, the recording time is limited to 7 minutes for HD and 14 minutes for VGA. The maximum movie file size is 4GB for MOV format videos and 2GB for M-JPEG. Olympus recommends use of at least a Class 6 Secure Digital card to avoid issues with write speeds during video capture."
You didn't say where you bought the camera but the EU limits recording limit to 29:29. Some companies (in fact, most companies, it seems) extend that limit to other regions; some apply it to all of the codecs on the camera and some only the better codecs. For unlimited recording you'd have to get something like the GH3/4 cameras (sold outside the EU), which is one reason that I've kept my GH3 despite preferring to use an RX10 for most outings. With some cameras you can get around the limit by outputting the video to a recorder via HDMI.
"Knowledge is good." Emil Faber
 Corkcampbell's gear list:Corkcampbell's gear list
Sigma DP2 Merrill Sony Cyber-shot DSC-RX10 Sony RX100 III Sony RX10 III Leica C-Lux +8 more
OP yjaquinas New Member • Posts: 8
Re: A quick Google search would have found your answer.
I am not very good with search keywords I guess... I looked for the answer on google, but failed, and resorted to DPreview.
Thank you very much!
I never thought about that.
I just assumed camera sensors would be similar to those of camcorders.
Hmm... I will investigate on this more
Thank you for the comment!
Your question made me curious so I did a search and came up with this.
http://www.dpreview.com/articles/0794343949/wto-looking-at-moves-to-remove-30-minute-limit-from-digital-cameras
PS don't let anyone tell you or suggest that you can't ask questions here on this forum. Ignore them ..Questions even seemingly simple ones can lead to everyone learning something.
Corkcampbell
Yes, but that link is 2 1/2 years old and there doesn't seem to be any progress.
Yes, but that link is 2 1/2 years old and there doesn't seem to be any progress on ending the recording limit in the EU. What's worse is that some companies are applying the limit universally and there's been a lot of speculation as to the reasons. For example, all of the RX10s have the limit and, when asked about it, a Sony rep said (per the Sonyalpharumors site) in an interview something like "most companies do it," which is not an answer, or course.
I have followed this topic because, like the OP, I must occasionally record, sometimes unattended, for extended periods of time - once I recorded for about three hours with a GH3 on a tripod.
There are other issues with recording limits, a principal one being battery duration. Luckily for me, the GH3 (and GH4) uses a big battery and also offers a grip to hold a second battery. The three hours mentioned above was with one, third-party battery (Watson), and the battery still had life. Unfortunately, even if my RX10 (and RX100M3) had no time limits on recording, the battery issue would still be a sort of limit with those cameras which use smaller, weaker batteries.
If anyone else has any news on this topic, please share it, because for some of us it's a consideration when buying hardware.
Wow.
Thank you for the nice find.
I was only searching for hardware limitations/differences from V-cams.
I would've never know there is an political issue, rather than the engineering problem.
Well, it does point at the 32bit-ness 4GB cap on FAT32, and the overheating issue however...
Thank you for the kind comment also
Olympus tech support with no answer to my question.
I have emailed Olympus tech support asking:
1. what is limiting the longer video recording,
2. can I remove the "software cap" on the maximum length of the video recording.
I didn't get any reply from them
A week later I sent another email with the same questions, along with another question for shutter actuation rating for e-pm2.
This time I got a reply from the tech support.
They only answered about the shutter count rating... which is not tested, but PEN line cameras will have somewhere around 50,000 ~ 100,000 shutter counts before they die.
By the way, I don't think that estimate is a very good one... 50k to 100k. It sounds like he pulled out that number randomly... not very technical answer from the tech support.
Klarno
Klarno Veteran Member • Posts: 4,239
Here are your answers.
  • The EU, one of the largest consumer electronics markets in the world, levies a 4.9-12.5% duty on video cameras manufactured outside the EU; video cameras are defined as cameras capable of continuously recording a video of 30 minutes or longer.
  • The FAT32 filesystem used on SD cards has a technical limit of 4gb per file regardless of EU taxation or video codec. More mature, professionally-oriented video systems are better at starting a new file once the 4gb limit has been reached.
  • Overheating would be another limitation of recording time, but that would only come up situationally.
Most consumer video codecs are not constant bitrate, but adapt to the amount of detail in the scene (more detail is harder to compress and requires bigger files) so it would be impossible to say how long it will take before a given video bumps into the 4GB limit without additional information, and that's information only the camera itself has.
Big companies like Olympus are doing cost-benefit analysis on everything, and most of the time they decide it's not worth it to release different firmware versions for different regions. AFAIK, only Panasonic, and possibly Sony, both consumer electronics giants that have been deeply rooted in video for decades, have decided it's worth it to do anything along the lines of concurrently releasing both a US model of a camera that records NTSC frame rates and no limit of recording time, and an international model that records PAL frame rates and EU's recording time limit.
No. If you could, it would be defined as a camera capable of recording 30 minutes or more at a stretch, the EU would be collecting a duty on the camera and it would cost more in the EU anyway.
Ironically, video cameras aren't manufactured inside the EU, so the tariff doesn't make a lot of sense. It's not protecting any EU industry. Yet, still cameras are manufactured inside the EU, and no tariff is levied against foreign still cameras. But it is what it is.
That's actually a pretty typical estimate for consumer grade focal plane shutters. With a high-precision high-energy component like that, that could wear differently depending on manufacturing tolerances, dust inside the camera body, and even humidity levels, it's not possible to say how long it's rated to last outside of a pretty broad range.
 Klarno's gear list:Klarno's gear list
Sony Alpha NEX-6 Olympus E-M1 Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R Olympus 12-40mm F2.8 Pro +9 more
Re: Here are your answers.
You are more helpful than the Olympus hired Tech Support guy.
So living in the U.S. does not matter, since Olympus does not differentiate EU/US on their firmware.
That is a shame. This leads me to want to switch out of Olympus. One customer away from the company would not make much difference I guess.
I don't know when my camera will die out then.. hmm. I will think of it as 50,000 to be safe.
Thank you so much!
Impulses Forum Pro • Posts: 10,039
Re: Yes, but that link is 2 1/2 years old and there doesn't seem to be any progress.
When shooting on a tripod you can get around battery life limitations by using an AC adapter, I bought a third party one for my Panasonic and I don't remember it being very expensive... I actually bought it for shooting time lapse sequences.
Doesn't Oly's IBIS actually add to the heat generated in there? Might be another reason they don't really wanna push for longer limits... Possibly why the GX7 doesn't make it available for video too.
 Impulses's gear list:Impulses's gear list
Panasonic GX850 Sony a7R IV Olympus M.Zuiko Digital ED 75mm F1.8 Panasonic Lumix G 42.5mm F1.7 Sony FE 20mm F1.8G +31 more
