NX1100 20-50 & closeup lens
Started Jan 20, 2015 | Discussions
mordor_74 Contributing Member • Posts: 622
Since i have a bit of infatuation with this little lens (althrough the 18-55 fit better my needs and spent the most of time attached to the body...), i wanted to find some spot for it.
So i bought some cheap closeup lens to give it a try, guessing that the edge to edge resolution of the lens wold have helped out resolution loss from the closeup...
While takeing some test picture of my lego trooper i  noticed this object on the desk
closeup +10
I guess this is sort of a cliché but good to test the combination...
What i noticed most (not so much in this picture...) is purple fring not handled by the cam engine... i guess this is the reason we still not have 3rd party lenses, they need to be handled as good as samsung lenses are handled by the drime-thing...
 mordor_74's gear list:mordor_74's gear list
Sony Cyber-shot DSC-HX5 Canon EOS Rebel SL1 Samsung NX1100 Samsung NX 30mm F2 Pancake Tamron SP AF 17-50mm F/2.8 XR Di II VC LD Aspherical (IF) +7 more
Samsung NX1100
vatazhka
vatazhka Regular Member • Posts: 355
Re: NX1100 20-50 & closeup lens
Last night when I was testing my new Samyang 12mm lens on my NX1000 I noticed that the very prominent purple-blue fringing is being reduced by the in-camera JPEG engine. I compared the OOC SuperFine JPEG to the raw file opened in RawTherapee (with Auto CA Removal and Defringing disabled) and there was a significant difference. I will need to do more testing in order to verify if there is indeed CA removal being performed in the in-camera JPEG engine even with dumb lenses as there may be other factors in play (I was taking night long-exposure pictures which involves heavy in-camera processing.).
Edit: There is definitely in-camera CA removal even with a dumb lens attached.
Samyang 12mm - green and purple fringe visible in RawTherapee (Neutral profile)
Samyang 12mm - CA removed in OOC JPEG
Check here if your Samsung NX / NX mini camera & lens firmware is up to date!
 vatazhka's gear list:vatazhka's gear list
Samsung NX1000 Samsung NX mini Samsung NX500 Samsung NX 20-50mm F3.5-5.6 ED Samsung NX 50-200mm F4-5.6 OIS +3 more
