Using OM lens with E-PM2 newbie question
Started Jan 17, 2015 | Questions
Jhumroo Senior Member • Posts: 2,194
Hello,
I'm making my first foray into the m4/3 world having just got the E-PM2 with the 14-42 and 40-150 lens kit.
I'd like to add a Prime lens and was thinking of getting a legacy OM 50mm 1.8 lens and m4/3 adapter to use with this camera, since the dedicated Prime is not in my budget currently.
I would like to get some comments on this combo of E-PM2 with the 50mm if someone has tried it before. How well does it perform for portraits and is it easy to manually focus this lens with the E-PM2.
Also would like some thoughts on getting a cheap $10 eBay adapter like this one (http://www.ebay.com/itm/Olympus-OM-Lens-to-Micro-4-3-M43-Mount-Adapter-for-EPL3-EP2-EP3-GF1-GH1-G3-G2-G1-/381077141270?pt=US_Lens_Adapters_Mounts_Tubes&hash=item58b9f7b716) vs the Fotodiox.
Any comments would be appreciated
Thanks!
Just a Pixelpusher, currently experimenting with Fuji HS10 and Panasonic LX5
 Jhumroo's gear list:Jhumroo's gear list
Fujifilm FinePix F40fd Olympus E-M5 II Olympus M.Zuiko Digital 14-42mm 1:3.5-5.6 II R Olympus M.Zuiko ED 75-300mm 1:4.8-6.7 II Olympus 14-150 F4-5.6 II
Olympus PEN E-PM2
hindesite Veteran Member • Posts: 4,893
Re: Using OM lens with E-PM2 newbie question
The OM 50/1.8 is very good on m4/3, I have used a couple (with different results) on both an E-P1 and G6. Not as sharp as the 45/1.8, nor as convenient, but definitely useful. And cheap.
The main problem you will have is judging focus, with no EVF and no focus peaking you will need to use magnified view which wasn't implemented at all well on the E-P1; maybe it is better on the E-PM2 (it isn't good on the E-PM1, either).
Pretty much any cheap adapter will do, the advantage f the OM lenses is that the adapter don't need any release button or moving parts. I prefer adapters with tripod mounts, so they can support heavier lenses without straining the camera.
baxters Veteran Member • Posts: 5,319
The adapter will probably be fine. I buy the cheap ones too. The OM 50 is a good lens. Don't pay too much for it. I've used one on several of the PEN's, including EPM1, EPL1, and EPL5. It's the same on all of them, except having the tilt LCD on the EPL5 was the best.
Manual focus in magnify mode is pretty straight forward. You will need to program a button on the EPM2 to invoke magnify mode, but it does have two buttons for this purpose. EPM2 should do fine.
 baxters's gear list:baxters's gear list
Olympus OM-D E-M5 Panasonic Lumix DMC-GX85 Olympus M.Zuiko Digital ED 75mm F1.8 Olympus M.Zuiko Digital 17mm F1.8
farmer35 Contributing Member • Posts: 968
I've really enjoyed the old lenses.  Even the hunt for them is fun.  If you live in USA you might check out Rainbow imaging.  I've had good luck with their adapters and you can pick up the m43 inside lens caps to go with it for next to nothing.
Valentinian
Valentinian Contributing Member • Posts: 883
2raj wrote:
would like some thoughts on getting a cheap $10 eBay adapter /Olympus-OM-Lens-to-Micro-4-3-M43-Mount-
I got an ebay cheap adapter OM to m4/3 for a Zuiko MC 200mm/f4 (also an ebay purchase).
It works very well, except that manual focus is a little difficult for me (roughly 50% keeps)
 Valentinian's gear list:Valentinian's gear list
Panasonic Lumix DMC-GX8 Panasonic Lumix DC-G9 Panasonic Leica DG Summilux 15mm F1.7 ASPH Panasonic 100-300mm F4-5.6 II Panasonic 35-100mm F2.8 II +1 more
OP Jhumroo Senior Member • Posts: 2,194
Thanks. I'll check out Rainbow Imaging.
Can you clarify what you mean by "m43 inside lens caps"? Are you referring to the Olympus Body Cap Lens? I already got the BCL-1580 15mm/f8.
Would you recommend the OM 50/1.8 over other brand (Nikon, Canon etc.) lenses to use with the E-PM2?
Thanks for the tip. I'll try to program one of the buttons to Zoom to help with manual focussing.
So, you think going with the $10 adapter over more expensive ones is ok?
What's a reasonable price to pay for the OM 50, and are there things to watch-out for before buying?
Any suggestion on which button to program for zoom?
Thanks!
Thanks. Any other suggestions on primes?
It's a cap to protect the inside of the lens when it's not on the camera.  It will fit on the side of the adapter that attaches to the camera and keep it closed up when you have the adapter mounted on the lens.  I think they sell a body cap/inside lens cap combo for under a dollar.  The ones I got from them had Lumix written on them but they work just fine on my Olympus stuff.  Last time I ordered from them they offered free shipping on any order over $15.00 so if you order an adapter you need some odds and ends stuff anyway to get up to $15.
alcelc
alcelc Forum Pro • Posts: 19,005
I love to shoot flowers with G1 + Nikon ai 50mm f/1.8 (why Nikon, becuase I have a few of them back from the film slr time, so 0 cost to me). I used a <US$5 non-brand adapter plus a monopod. My Panny bodies automatically magnified on manual focusing.
alcelc: Is the Nikon a macro lens?
Just a pixelpusher with a love of photography
Thanks for the additional info.
alcelc
None, but it could focus very close up with nice bokeh and silk-like smooth focusing ring... and free of charge.
alcelc
Of course, because the mount of the adapter (attach to camera's end) is a M43 mount and so any M43 lens end cap would do.
alcelc
alcelc wrote:
Forget to mention, old manual film lenses of any kind would be better than newer AF lenses in 2 aspects. 1) There are aperture control ring on the ring by which we could precisely set the aperture on the lens instead of through the one on adapter that is a wild guess (despite all M43' A mode won't care with it anyway and we could see the effect through real time live preview). 2) Cheaper and quality assurance on a just flinch distance modification adapter.
alcelc wrote:
alcelc wrote:
Any recommendations for good legacy portrait lenses and long zoom lens for birding?
Joinker Forum Member • Posts: 53
Olympus and Minolta lenses have good reputations as adaptable legacy types. So do Canon FD, Konica AR. Check out the adapted lenses forum at mu-43.com.
Also that forum contains a focus-peaking type of workaround for the current generation of Olympus cameras that don't have it built in. I use it in conjunction with the magnification and its very useful and fun.
The OM lens feels and looks nice, but I also have Helios 44K-4 58/2, Canon 50/1.8, Nikon 55/2.8 Micro Nikkor, Nikon 50/1.8, Pentax 50/1.4 and OM 50/3.5 Macro. Cost varied from about $50 to $5 or $0 for most of them.
Of the standard 50mm lenses, it really comes down to what you are used to handling, they are somewhat similar though of course the macro lenses and the Helios are different.
The OM lenses have the aperture ring on the front of the lens, can be confusing for some; also Nikon bayonet is braindead and backwards. Canon FD mount is the subject of quite a few questions in this forum, it is a bit complicated. Adapters are so cheap it is reasonable to leave them permanently attached to your favourite lenses.
The big deal with these lenses is stay clear of fungus and you should be right.
On the E-P1 I had to be in the correct display mode, press the centre button, focus then press the centre button to compose. Very tedious. Anything would be an improvement, and the G6 was more than that - it makes using MF lenses a delight.
I've never bought an expensive adapter and been happy with what I have received and the results I have got.
M43 Dude
M43 Dude Senior Member • Posts: 1,464
You don't have to use OM lenses, you can use lenses from just about any system you like, Canon and Konica lenses are also very good. If you do go with a Canon lens, just make sure you get a new FD lens (FDn) rather than an old breach lock lens which can be hard to mount on adapters.
 M43 Dude's gear list:M43 Dude's gear list
Olympus OM-D E-M5 Canon EOS Rebel T4i Panasonic Lumix G 20mm F1.7 ASPH Tokina AT-X Pro 11-16mm f/2.8 DX Sigma 24-70mm F2.8 EX DG HSM +5 more
