X-A1 ND Filters question
Started Jan 16, 2015 | Discussions
Teodor87
Teodor87 New Member • Posts: 6
Hello, I'm eager to receive my X-A1, that should be delivered by Jan 22nd. Meanwhile i am looking to buy some accessories and filters (ND).
I see many 58mm filters for sale on ebay but i am not sure what their quality is. What good quality non-fuji filters would you recommend(if any)? I don't want to spend ~$70 on a filter
 Teodor87's gear list:Teodor87's gear list
Fujifilm X-T1 Fujifilm XF 18-135mm F3.5-5.6 R LM OIS WR
slimandy Forum Pro • Posts: 17,161
Re: X-A1 ND Filters question
You want a decent filter but you don't want to spend much. Unfortunately the two don't go together well. I wouldn't skimp too much.
I tend to use a filter kit for grads and ND's (Lee) but when I wanted a screw-in filter for a particular lens I did some research and bought one of these...
http://www.ebay.co.uk/itm/B-W-58mm-1-8-ND-106-Neutral-Density-Filter-For-Fujifilm-FinePix-X-E1-XF-18-55mm-/331223152243?pt=UK_CamerasPhoto_CameraAccessories_CameraLensesFilters_JN&hash=item4d1e703673
..... and I would happily recommend it.
www.andrewsandersphotography.co.uk
 slimandy's gear list:slimandy's gear list
Sony RX100 II Nikon D200 Nikon D700 Fujifilm X-E1 Fujifilm X-T1
Teodor87
OP Teodor87 New Member • Posts: 6
Thanks for the reply.
As a not professional photographer i just wanted to know if there are any good quality filters, that don't cost as much as the whole camera I am pretty sure that the original fuji lens are better than the 2$ ones on ebay.
So to specify - do you think filters like these: http://www.ebay.com/itm/58-mm-UV-FLD-CPL-Polarizing-ND4-Neutral-Density-Lens-Filter-Kit-Hood-For-Canon/221601274406?_trksid=p2050601.c100103.m2451&_trkparms=aid%3D111001%26algo%3DREC.SEED%26ao%3D1%26asc%3D20140211150826%26meid%3Df10382f25d224c57ad016520fc373493%26pid%3D100103%26rk%3D3%26rkt%3D4%26mehot%3Dpp%26sd%3D281331528850%26clkid%3D3402181867650666239&_qi=RTM2010736 will do the job or should i just stop looking at such cheap ones?
ryan2007 Forum Pro • Posts: 12,001
This is the deal with filters and why you want good quality that is preferably designated as multi-coated.
When light passes through the filter it scatters the coatings help to reduce or eliminate it. Cheap filters can make things worse so much so you should not bother with the filter at all.
With that said, go and buy your $5 filter whatever, and if you like the results so be it, discussion ended.
If not, the worse is you are out little money though your $70 filter is now a $75 filter because you bought the same filter twice.
Photography if you are serious or want to get more involved as a hobby is very expensive.
Another way to look at this is to do more research. For example, the Fuji X100s or T have a built in ND filter eliminating the need to have to buy a separate filter, though you can piggy back it for more ND effect.
Take the $600 whatever you spent on your camera plus another $100 for filters you now have a $700 camera. For $150 more you can still buy a new X100s and maybe a used one for the same cost as the XA-1 (forget how much it costs).
You have to research, decide what is a must have and play the numbers.
The answer may be buy a $5 filter and live with it or spend more and get better product. I will attest that filters are a loss leader, meaning they have a HUGE markup since camera stores make virtually no profit from the camera or lens. Bags, filters, batteries, cleaning supplies etc is where more profit margin lies. But, why have your photography suffer unless it just does not matter.
*You do not have to buy Fuji branded filters.
*Buy multi-coated filters from Hoya, B&W or Heliopan. Tiffen is ok and they have more effect type filters.
*Always buy a multi-coated filter when you can, BUT be 100% certain if the filter has front threads or not. Not a deal breaker unless you need to stack filters or use a lens cap.
***If you buy on Ebay no matter a $5 item or $500 item it will behoove you to check the seller rating and understand any shipping fees. The filter can be $5 and shipping can be $20 making it a $25 filter, BE CAREFUl with the fine print.
Teodor87
Thanks Ryan!
Yup, i've bought lots of things from ebay so i know what you are talking about.
As for the filters topic - you've fully explained all i needed to know! Thanks!
Cheers!
HB1969 Senior Member • Posts: 1,724
cheap ND filters
Cheap generic ND filters are ok if you're just starting out and not sure if you're going to be using them much. They will let you experiment and see if you're into that style of photography. I think ryan2007 has mentioned going for multicoating which is good advice but the biggest problem with cheap ND filters is not light scattering but colour cast. Here are some examples....
NB i bought 3 ND filters (ND2, ND4 and ND8) which equate to a 1, 2 and 3 stop reduction in light and the set cost about $8-$10 on ebay (free delivery)
The following is an extreme example where I stacked 2 of the cheap filters together to get the slow shutter speed that I needed to affect how the fountain and flags looked.
ND8 plus ND4 stacked together to get 5stop reduction in shutter speed
You can see the terrible pink/purple colour cast. Normally it's not that bad but a combination of stacking two filters and long exposure has exacerbated the problem. The same shot with quick conversion to black and white looks as follows.
I've been playing with these cheap ND filters for about a year now and I found that if you don't stack them, keep the exposure short or convert to black and white then you can get some reasonable shots. Note that they do slightly affect the sharpness of images so you'll need to do extra post processing on top of dealing with colour cast.
PS. I've really enjoyed the long exposure style (5-60 second exposures) and can only achieve this with 5 or more stop reduction in light so I've splurged on a set of 3 Haida filters (ND8, ND64 and ND1000) that equate to 3, 6 and 10 stop reduction in light. The set cost me $150 and from the quick test with the ND1000 (60 sec exposure of crap on my desk) I can't see much of a colour cast so that's good for me. Looking forward to using them out "in the field"
 HB1969's gear list:HB1969's gear list
Fujifilm X-E1 Fujifilm X-Pro2 Canon EF 50mm F1.8 II Canon EF 75-300mm f/4.0-5.6 III Nikon AF Nikkor 50mm f/1.8D +12 more
Chris Dodkin
Chris Dodkin Forum Pro • Posts: 13,956
Hoya HD ND
I have found Hoya to provide an excellent filter at a very good price.
Optically I can't find any difference between the Hoya HD or HMC models and say B+W.
They are well made, have multi-coated glass, no color cast, reasonable pricing.
B+W have brass threads - which are wonderful, but they are super expensive
Hoya, is my personal choice for ND.
I wouldn't go cheap - as they tend to degrade the IQ and/or be poorly manufactured.
http://f-sunny.com
The future is just a click away...
 Chris Dodkin's gear list:Chris Dodkin's gear list
Fujifilm X100F Fujifilm X100V Fujifilm X-T2 Fujifilm GFX 50S Fujifilm GFX 50R +50 more
Teodor87
Re: Hoya HD ND
I just won an ebay auction for Hoya ND8 filter. That was a good deal I will update the topic with the results as soon as i receive my X-A1 and the ND filter. Thanks again guys!
Cheers
