Panasonic 14mm 2.5, how about it.
Started Jan 14, 2015 | Discussions
Jere Landis Senior Member • Posts: 1,933
I just bought the 14mm 2.5, had been thinking about it for a long while. How many of you out there have and enjoy that lens. Tell me about you experiences with it and how well you like, also what type of photography you use it for.
 Jere Landis's gear list:Jere Landis's gear list
Olympus PEN E-PL3 Canon EOS 550D Panasonic Lumix DMC-G10 Panasonic Lumix DMC-G5 Olympus PEN E-PM2 +11 more
Panasonic Lumix G 14mm F2.5 II ASPH
Martin Ocando
MOD Martin Ocando Veteran Member • Posts: 6,722
Re: Panasonic 14mm 2.5, how about it.
For your reference, just a couple of recent threads, featuring almost solely the 14mm 2.5. Is a great, fast and tiny lens. I love it.
http://www.dpreview.com/forums/post/55070474
http://www.dpreview.com/forums/post/55086788
 Martin Ocando's gear list:Martin Ocando's gear list
Panasonic Lumix DC-G9 Olympus 12-40mm F2.8 Pro Panasonic Lumix G X Vario 35-100mm F2.8 OIS Panasonic Leica DG Summilux 15mm F1.7 ASPH 7artisans 7.5mm F2.8 Fisheye +13 more
rkhndjr Forum Pro • Posts: 13,082
Jere, it is very tiny and quite interesting to use. I had a couple of them and got as good results as with the 20/1.7. Good luck.
Russell Smith
Eternity was in that moment.
M43 Dude
M43 Dude Senior Member • Posts: 1,464
I have the more expensive 12mm F/2 lens, so I see no need for the 14mm. It's a great place to start though if you're starting out.
 M43 Dude's gear list:M43 Dude's gear list
Canon EOS Rebel T4i Olympus OM-D E-M5 Olympus M.Zuiko Digital ED 12mm 1:2 Olympus M.Zuiko Digital 14-42mm 1:3.5-5.6 II R Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R +5 more
OP Jere Landis Senior Member • Posts: 1,933
Surely there are more users of this lens out there, I'd like to hear more about it from everyday users. I hope I can find a use for it.
Dr Hal Senior Member • Posts: 2,186
I have the lens and probably do not use it as much as I should.  Usually, I use the 20mm.  Whenever I use the 14mm, I am always pleased by the colors and the sharpness.  It is a wonderful walk around lens.  In fact, when I get up from the computer, I am going to put it on my GM1 and use it tomorrow and if I like the results (which I probably will), I am going to leave it on the camera for an extended period of time.
Hal
 Dr Hal's gear list:Dr Hal's gear list
Canon EOS M6 II Panasonic Lumix DC-S5 Canon EF-M 11-22mm f/4-5.6 IS STM Canon EF-M 18-150mm F3.5-6.3 IS STM Canon EF-M 55-200mm f/4.5-6.3 IS STM +3 more
sbszine
sbszine Contributing Member • Posts: 806
I use it as a walkaround lens. It's a good match with the E-PM2, and you can just leave that combo hanging from your neck while you're wandering about. I really like the 14 for landscapes and also for street scenes at night.
 sbszine's gear list:sbszine's gear list
Olympus Tough TG-2 Olympus OM-D E-M5 Olympus PEN E-PM2 Olympus E-M5 III Olympus M.Zuiko Digital ED 12-50mm 1:3.5-6.3 EZ +8 more
baxters Veteran Member • Posts: 5,319
Not bad for landscapes. It earns its keep by being small.
 baxters's gear list:baxters's gear list
Olympus OM-D E-M5 Panasonic Lumix DMC-GX85 Olympus M.Zuiko Digital ED 75mm F1.8 Olympus M.Zuiko Digital 17mm F1.8
Chas2 Veteran Member • Posts: 3,715
I am embarrassed to say so, but I have this lens, and hardly use it. Video for parties occasionally, but that is about it. I have no issues with the lens IQ wise.
I use the 20 mostly, but if I have to go wide, I used the 9-18. I had visions of the this classic kit, 14, 20 and 45, all small lenses on the GX1, and it never really worked out. Now I mostly use my GX7 and 20. If I need wide, I use the 12-32 because it is about the same size as the 20, and is easy to carry around. Given the choice of carrying one lump in your pocket or small bag, the 12-32 wins out over the 14. It was a bad purchase on my part, but at least it was cheap (relatively)! I got one of those new lenses that was split from a kit on eBay.
 Chas2's gear list:Chas2's gear list
Panasonic Lumix DMC-GM1 Panasonic Lumix DMC-GX7 Panasonic G85 Panasonic Lumix G Vario 45-200mm F4-5.6 OIS Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 +12 more
adamandbean
adamandbean Contributing Member • Posts: 615
I got it used here in Japan for 150 dollars and like it very much- makes me want to buy the 20 as well but I have the oly 25
 adamandbean's gear list:adamandbean's gear list
Olympus OM-D E-M10 Canon EOS 5D Olympus M.Zuiko Digital 25mm F1.8 Olympus 9mm F8 Fish-Eye Body Cap Lens +1 more
TN Args
TN Args Forum Pro • Posts: 10,687
I have it, like it, and do use it, but it struggles for time on my camera compared to the 25mm f/1.4. Not because of IQ (the 14 is great) but because most of my photography demands a narrower field of view. When I shoot wide, I need to be sure I can avoid cluttered backgrounds, which I don't like in my own images. That means I get very selective about when I can use it.
Arg
 TN Args's gear list:TN Args's gear list
Sigma dp0 Quattro Panasonic Lumix DMC-GX7 Olympus E-M5 II Sony a7R III Panasonic Leica Summilux DG 25mm F1.4 +10 more
Paulmorgan Veteran Member • Posts: 9,499
Its a good all round little lens, good for wide angle shots as well as close ups.
Narcosynthesis Senior Member • Posts: 1,832
I got mine back in the day with my GF2, and it is a cracking wee lens - decent quality and absolutely tiny in size.
My only real complaint about it that I am not a huge fan of the focal length - so nothing against the lens itself in any way, just a personal preference for other focal lengths - I find 14mm a bit too wide for a standard lens, yet not really wide enough to be a 'proper' wide angle - so I normally default to my 20mm f1.7 instead.
If you have the GM1 or GM5 though, it is an absolutely perfect match for those cameras, being even neater than the 12-32mm kit lens and makes for a very compact (yet high quality) setup. As much as I prefer the 20mm, I still do keep finding myself going out with the GM1 and 14mm in my bag and really enjoy shooting with it...
www.flickr.com/photos/narcosynthesis
www.illaname.deviantart.com
M43 Dude
The general consensus seems to be what I assumed, people have bought it at some point, but it doesn't seem to be a regular hit with everyone who owns it. The shots above tell me what I suspected, it's a bit wide, but not enough wide for a wide angle, but at the same time not narrow enough for normal shots. The aperture of F/2.5 makes it not as compelling as some of the faster primes also, all be it that it is cheaper.
If money wasn't the issue I'd hesitate to recommend the 14mm over the 12mm, for the budget conscious its sharp enough and kind of fast, but that seems to be its major caveat.
jim stirling
jim stirling Veteran Member • Posts: 7,356
I have it and the 20mm , though I use the 20mm more the 14mm is a  good performer , its wider angle works well in smaller locations { pubs , restaurants , house parties and so on}. It has fast AF , good results and its small size goes well with the smaller mFT cameras.
 jim stirling's gear list:jim stirling's gear list
Panasonic FZ1000 Panasonic Lumix DMC-GF1 Panasonic Lumix DMC-GX7 Nikon D810 Panasonic Lumix DMC-GH4 +12 more
woof woof
woof woof Senior Member • Posts: 1,897
A 28mm field of view (on a 35mm camera) is considered by some to be a classic focal length and the 14mm therefore fulfils the same role for MFT.
My advice is to buy one and enjoy it
RedDog Steve
RedDog Steve Senior Member • Posts: 1,972
I like it.
It's small and light, fast focus and the price was right.
I think the maximum aperture could have been a bit larger (f2.0 ?)
But hey, at the size and price point it's still more than a stop faster than the kit zoom.
There's the corner CA issue on older Oly bodies but it works fine on my GX1.
And lastly it's one of the all-time classic "equivalent" wide angle focal lengths.
rd
 RedDog Steve's gear list:RedDog Steve's gear list
Olympus OM-D E-M10 II Olympus M.Zuiko Digital ED 75mm F1.8 Leica Nocticron 42.5mm Panasonic 8-18mm F2.8-4 Panasonic Lumix G Leica DG Summilux 12mm F1.4 ASPH +17 more
WT21 Veteran Member • Posts: 5,473
General purpose wide angle, kids, social
I have the 14/2.5 I thought about the 15/1.7 and other options, but for size and price, it's a nice lens. The output is good. Maybe even great. Not spectacular, but quite lovely. Close focusing, reasonably fast. Contrast is good, as are colors.
I use it for kids, family and social. Some travel. And just for goofing around. It's the only wide angle lens (aside from the RX100 compact) I own.
 WT21's gear list:WT21's gear list
Panasonic 100-300mm F4-5.6 II Panasonic Leica 12-60mm F2.8-4.0 ASPH Panasonic Lumix DC-G9 Olympus E-PL7 Panasonic Lumix G Vario 45-150mm F4-5.6 ASPH Mega OIS +6 more
BigGG Contributing Member • Posts: 933
What I like about the 14mm Lens is that it is lightweight & a good field of view, so I don't have problems with the GX7+14mm on a selfie-stick. I have other m43 lens (12-35mm F2.8, PL-25mm, Nocticron, Oly 45mm. Oly 75mm) but these other lenses weigh a lot more.
GaryG
 BigGG's gear list:BigGG's gear list
Sony SLT-A77 Sony Alpha a99 Panasonic Lumix DMC-GX8 Sony a77 II Sigma 35mm F1.4 DG HSM Art +43 more
RedDog Steve
Well, the 28mm f2.8 lens was universally ubiquitous on the film systems.
ALL the manufacturers had one in their lineups and all the aftermarket lensmakers offered them.
Having said that, though, I also have a 24mm SMC of which I really like the FOV.
I'd say they are both equally useful FLs.
rd
