Comparison Olypmus 40-150 Pro with 75/1.8, 100-300, 14-140 mk2
Started Jan 12, 2015 | Discussions
gccg88 Junior Member • Posts: 33
I came to m43 with the purchase of the GH1 in 2009 and since then I'm often reading in these forums. And now after short 5 years I feel ready for my first posting ;-). So after this is my first post I try to be as objective as possible, otherwise a troll reputation is gained quickly here...
I purchased a E-M1 a few weeks ago and received my 40-150 2.8 (including the 1.4 TC) last friday. I want to compare the 40-150 at 210mm with the Panasonic 100-300 at 300mm to find out how the image quality of the 100-300 at 300mm is compared to the 40-150 at 210mm (cropped to the same size as the 300mm shot). I included also the Olympus 75mm 1.8 and the Panasonic 14-140 mk2 in the comparison.
I'm not really a pixel peeper, but I would like to see the heavy price tag of 1600 € for the 40-150 represented in its image quality to justify my spending. The weather wasn't that great, cloudy, no sun.
I did some 100% crops of the images to compare IQ, mostly at the same aperture, but added a few pics with wide open aperture. After writing this I noticed, that i forgot to turn off OIS on the two Panasonic lenses! So the comparison with the Panasonic lenses is a bit flawed. I included the crops anyway and will redo this test another time...
Camera settings:
Tripod
ISO 400
Shutter Shock 2s
self timer 2s
IBIS off / Forgot to turn OIS off on the Panasonic lenses
Aperture Mode
spot AF (on the olympic parc logo)
Scene @75mm with 40-150 pro at F2.8
40-150 and 75 both @F2.8 - this comparison ist not flawed -> no OIS on the 75mm 1.8 ...
Pana 100-300 and Oly 40-150 at 140mm both @5.6
Pana 14-140 (@F5.6) and Oly 40-150 (@F2.8) both at 140mm
Oly 40-150 (incl. 1.4 TC) and Pana 100-300 both with F5.0 at 210mm
Pana 100-300 @300mm with F5.6 and Oly 40-150 (incl. 1.4 TC) @210mm with F4.0
This is the first time i try to compare lenes in this fashion, so I'm open to some pointers how i could do this a better way next time (in addition to turning the OIS off on Panasonic lenses...)
What are your conclusions concerning the IQ of my copy of the Olympus 40-150 pro?
 gccg88's gear list:gccg88's gear list
Sony a7R III Sony a1 Sigma 50mm F1.4 DG HSM | A Sony FE 85mm F1.8 Sony FE 100-400mm F4.5-5.6 +4 more
Olympus E-M1 Panasonic Lumix DMC-GH1 Panasonic Lumix G 14mm F2.5 II ASPH
luisflorit
luisflorit Veteran Member • Posts: 8,514
100-300 vs 40-150 Pro
My conclusion regarding the 100-300 is the same I always had: The IQ of my 100-300 is better than my 50-200 + 1.4TC at the center of the frame, and it seems your 100-300 and 40-150 are pretty close at the center of the frame. Exactly what I'd expect with my copies.
Of course the 40-150 has other benefits, like faster lens, weather sealed, better at the corners, less CA. But if center sharpness is all you care about, the 100-300 is excellent.
L.
 luisflorit's gear list:luisflorit's gear list
Olympus E-M1 II Olympus 12-40mm F2.8 Pro Olympus M.Zuiko 300mm F4 IS Pro Venus Laowa 7.5mm F2 MFT Olympus E-M1 +3 more
robonrome
robonrome Senior Member • Posts: 2,334
Re: Comparison Olypmus 40-150 Pro with 75/1.8, 100-300, 14-140 mk2
thanks for the comparison, I'd be particular keen to hear your thoughts on the pany 14-140ii used with the em1 with the OIS turned off.
I have this combination and intend to use it. From what I can see the 0sec antishock is reasonably effective removing shutter shock blurring with the lens. More interested in CA, fringing and contrast so you ongoing tests are of interest.
 robonrome's gear list:robonrome's gear list
Olympus E-M1 II Sony a7R III Olympus M.Zuiko Digital ED 60mm F2.8 Macro Olympus M.Zuiko Digital ED 75mm F1.8 Sony FE 35mm F2.8 +10 more
Kim Letkeman
Kim Letkeman Forum Pro • Posts: 33,444
I don't see much point in repeating the test ... if the 100-300 does any better it will win the comparison outright. As it is, I don't see the difference being enough to spend the megabucks.
Of course, reach is not why you buy the "pro" lens combo .... it has other attributes, like better subject isolation at short focal lengths, and of course conspicuous consumption
 Kim Letkeman's gear list:Kim Letkeman's gear list
Nikon Coolpix 990 Fujifilm FinePix F770EXR Nikon D600 Nikon D7200 Panasonic Lumix DMC-G7 +27 more
drj3 Forum Pro • Posts: 12,636
If you wanted to repeat the test, then something with a little more detail and color with ISO = 200 would probably be better.  Not sure it is necessary, but more detail comparing the lenses might be informative to those interested in purchasing one of the lenses.
drj3
 drj3's gear list:drj3's gear list
Olympus E-510 Olympus E-5 Olympus E-M1 Olympus OM-D E-M10 Olympus E-M1 II +13 more
M43 Dude
M43 Dude Senior Member • Posts: 1,464
It's interesting to me, that the more expensive lens is not always necessarily the sharper of the two and in your testing for example the 75 vs the 40-150 the 75mm IS definitely sharper reading the text on the signs where it counts where the prime has it. The zoom perhaps is more versatile, but its expense does not necessarily always justify the outlay from what I am seeing in these and other photos.
 M43 Dude's gear list:M43 Dude's gear list
Olympus OM-D E-M5 Canon EOS Rebel T4i Panasonic Lumix G 20mm F1.7 ASPH Tokina AT-X Pro 11-16mm f/2.8 DX Sigma 24-70mm F2.8 EX DG HSM +5 more
I think the focus for this comparison is slightly off for the 40-150.  Looking at the branches behind the sign, they appear to be in better focus with the 40-150.  However, it would not surprise me if the 75 prime was sharper than even a professional zoom.
drj3
(unknown member) Veteran Member • Posts: 3,010
I see a noticeable difference between the 100-300 and the other two lenses. It's not as sharp in the center and especially the edges.  If you are into shooting outdoors in poor light the faster lenses will give you much better photos in terms of IQ, noise reduction and better focusing.  I'm not planning on buying the 75mm or the 40-150mm but I can see why someone else would.
OP gccg88 Junior Member • Posts: 33
The next time I have a chance to take some pictures in sunny conditions, I will redo this test with a different scene ...
Re: 100-300 vs 40-150 Pro
Yesterday the sun came out, so I redid the test with a different scene (with more detail).
This time I turned OIS off (IBIS too). Other changes: ISO 200 and Anti Shock 4 seconds.
Luisflorit is right - the 100-300 is very close in sharpness in the center wide open (F4) compared to the 40-150 pro with F2.8. In the corners it's quite different, here the 40-150 pro is alot sharper. The Pany 14-140 mk2 is the softest of these three lenses.
Oly 40-150 Pro at 100mm with F2.8
Pany 100-300 at 100mm with F4.0
Pany 14-140 mk2 at 100mm with F5.4
I did more shots of the same scene, but that might be too many pictures for this post. If somebody is interested in a specific comparison, I will post them...
There are
@ 75mm
Oly 75mm with F1.8, F2.8, F4.0
Pany 14-140 mk2 with F5.4
Oly 40-150 Pro with F2.8, F4.0
@ 100mm
Pany 100-300 with F4.0
@ 140mm
Pany 14-140 mk2 with F5.6
Pany 100-300 with F4.4
@ 210mm
Pany 100-300 with F5.0, F5.6
Oly 40-150 Pro (with 1.4 TC) with F4.0, F5.0, F5.6
@ 300mm
Pany 100-300 with F5.6
There are
@ 75mm
@ 100mm
@ 140mm
@ 210mm
@ 300mm
Yes the pro is sharper at the center but much sharper in the corners. It appears to have better contrast also.
webber15 Senior Member • Posts: 1,600
There isn't much point to this,,the pro wipes the floor with the cheaper lenses,,try shooting feather or fur,,then you will see a real difference as per another recent thread...
 webber15's gear list:webber15's gear list
Fujifilm X-Pro2 Fujifilm XF 100-400mm F4.5-5.6 OIS WR
Kim Letkeman
We weren't really debating lens speed ... but yes, one always pays a lot more for speed at long focal lengths. And it is well worth it if you spend a lot of time shooting in low(er) light.
slartz
slartz Senior Member • Posts: 2,103
Contrast!
I'd say that in terms of center sharpness - the diff is negligible in my eyes, and for now "justified" my decision to buy the 35-100/2.8 as my highend telephoto for portable everyday usage, and complement it with 100-300 (or 75-300 - I still need to decide ;)) for wildlife. When I shoot wildlife, I care mostly about Center resolution.
WITH THAT SAID - I think the big diff between the 40-150/2.8PRO and the 100-300/75-300 is the Contrast and microcontrast. They render better - and as such - using the 75-300/100-300 will require some more PP to compensate for that (and may not reach the same overall quality).
For my personal taste - I only do Wildlife on occasion, and I can live with that compromise. In all honesty - it's smaller than I thought... I expected the 40-150/2.8 to be much better, even with TC.
 slartz's gear list:slartz's gear list
Panasonic Lumix DC-G9 Panasonic Lumix DC-GX9 Panasonic Leica DG Summilux 15mm F1.7 ASPH Panasonic Leica 12-60mm F2.8-4.0 ASPH Panasonic 8-18mm F2.8-4 +10 more
Re: Contrast!
The difference in sharpness at 210mm is larger (in favour of the 40-150 pro):
Center crop:
210mm F5.0 - center crop
Edge crop:
210mm F5.0 - edge crop
Original Image (jpeg ooc) Oly 40-150 Pro @210mm (incl. 1.4 TC):
Oly 40-150 Pro 210mm (incl. 1.4 TC) F5.0
Original Image (jpeg ooc) Pana 100-300 @210mm:
Pana 100-300 210mm F5.0
slartz
Re: Contrast!
Center crop:
Edge crop:
Honestly? The difference is small. Yes, I can see it at 100% crop, but it requires some close looking. if you put them without telling me which is which, I'd have to spend a few seconds to examine the photos to tell which one is the sharper one. Once you see it you can't unsee it of course and it's clear, but - I've seen people pay a lot less diff on the glass for a lot more improvement.
I have to say - I'm quite impressed as how well a "cheapo" 200-600 equiv lens delivers. I know it stops delivering around 250, but it's still a "worthy" 200-500 lens.
I just have to decide if I'm getting the 100-300 or the 75-300 II.
Re: Contrast!
Center crop:
Edge crop:
To me the difference is quite significant in sharpness and especially contrast. I won't be buying the Pro because right now I can't afford it. I want to save up for the new 300 mm lens. The big deal with the Pro zoom is it expands the morning and evening hours when its not easy get HQ wildlife photos with the existing lenses. I suspect that includes AF performance also. For the right customer its worth every penny.
http://www.flickr.com/photos/90891174@N04/
I agree money doesn't grow on tress or so I've been told.
Kim Letkeman
Re: Contrast!
Center crop:
Edge crop:
Yes, exactly. The faster zoom offers several stops improvement in ISO. So obviously it is worth it for the fat wallet right customer.
But ... looking at the final crop comparison, you say that the difference is "quite significant" to you. I look at the full sized crops and I see the chimney being sharper for the Oly and the branches at the top against open sky being sharper for the Panny.
What that says to me is that the focus is off in this test. One focuses much further back than the other, making one sharper at the chimney and one sharper at the branches way back there.
The point being that it has not really earned your level of respect here. It's other attributes remain as important as always, but contrast and sharpness is not at all a spanking against the 100-300 that you purport ...
I have the 100-300 and have always found it to be really sharp and surprisingly contrasty for a consumer zoom. YMMV
Re: Contrast!
Center crop:
Edge crop:
Looking at it again I'm going to downgrade from quite significant to noticeable. I do see a difference in the Pro's favor but not as much as I first thought. The contrast as you point out is very good on the Panasonic lens better that I initially thought. Looking at the sharpness my opinion hasn't changed.
I hear you about the fat wallet mine is pretty thin so this lens isn't in my future.
