NX1100 (maybe other?) unable to set af spot in center
Started Jan 11, 2015 | Discussions
mordor_74 Contributing Member • Posts: 622
as you see in the picture, i am unable to move to the exact center the af area. What i am missing???
 mordor_74's gear list:mordor_74's gear list
Sony Cyber-shot DSC-HX5 Canon EOS Rebel SL1 Samsung NX1100 Samsung NX 30mm F2 Pancake Tamron SP AF 17-50mm F/2.8 XR Di II VC LD Aspherical (IF) +7 more
Samsung NX1100
Coldamus Senior Member • Posts: 2,281
Re: NX1100 (maybe other?) unable to set af spot in center
What happens if (after pressing ok) you press right once and down once?   Does it go too far the other way?
I had a little trouble centering mine on the NX10 because the grid lines disappear when adjusting the af area.  It took a couple of attempts to get it right.  I'm using fewer grid lines than you and the minimum af area size.
You could try reducing the af area to its smallest size, center it and then expand it again.  It may not work but is worth a try.
ihkim Regular Member • Posts: 451
Try that press "OK" button, and press "DEL" button.
Although I don't have NX1100, that is common way for all NX cameras to reset AF point.
 ihkim's gear list:ihkim's gear list
Samsung NX10 Canon EOS 550D Samsung NX100 Samsung NX20 Samsung NX300 +5 more
OP mordor_74 Contributing Member • Posts: 622
Yessss! I Know that i was missing something! Forgiveme but i am an NX newbe!
