Which has better background blurriness?APSC 50mm vs M43 75mm
Started Jan 10, 2015 | Discussions
ageminmo Forum Member • Posts: 74
I was researching to buy a light combo for doing portraits and I enjoyed using GM1 with Olympus 45mm but I know the bokeh of Sony 50mm is better. The question now is when compared to Oly 75mm, which has more bokeh between these two cameras:
Any M43 camera with Olympus 75mm F1.8
versus
Any Emount APSC with Sony 50mm F1.8
COnsidering the effective aperture calculation for both?
I read that you can compare the background blurriness by dividing the focal length and the aperture.
So the Olympus combo will yield a ratio of ~42 and the Sony combo will yield ~28. That's a lot!
But they are from different systems, so if I will use their effective apperture..
Olympus 75mm will have 21[75/(1.8x2)] and SEL50 will have 18[50/(1.8x1.5)].
Then they are almost the same! WIth the sony combo, I dont need to be much farther to the subject and the body+lens combo is lighter. (Of course, I would be needing a good IBIS body like GX7, EM5, EM1, EPM2 etc and not GM1/GM5)
 ageminmo's gear list:ageminmo's gear list
Sony RX1 Canon EOS RP Olympus E-M1 III Olympus M.Zuiko Digital ED 75mm F1.8 Olympus Stylus 1 +32 more
Olympus E-M1 Olympus PEN E-PM2 Panasonic Lumix DMC-GM1 Panasonic Lumix DMC-GX7
Chas2 Veteran Member • Posts: 3,715
Re: Which has better background blurriness?APSC 50mm vs M43 75mm
versus
While I do not dispute your calculations, what about angle of view provided by the focal lengths?  The FF angle of view equivalent of the 75mm is 150mm, while the 50mm is 100mm.  I have not done any calculations, but it seems that the longer focal length does a lot to background blur, even at smaller apertures (e.g. 150mm @ f5.6) ...this is just observation from personal experience, not calculations.
 Chas2's gear list:Chas2's gear list
Panasonic Lumix DMC-GM1 Panasonic Lumix DMC-GX7 Panasonic G85 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Panasonic Lumix G 20mm F1.7 ASPH +12 more
linux99 Senior Member • Posts: 2,151
Or learn about composition.....
12
Fetishising Bokeh is one way to go for taking portraits.
The other is to learn about composition.
 linux99's gear list:linux99's gear list
Sigma DP2x Canon PowerShot S100 Sigma DP3 Merrill Nikon Coolpix A Fujifilm X100T +19 more
Anders W
Anders W Forum Pro • Posts: 22,144
6
versus
It's a bit more complicated than that. Which of the two will give more background blur depends on the magnification as well as the distance between the subject and the background. For example, for a head-and-shoulder portrait, the 50/1.8 on APS-C will give slightly more blur if the background is less than 2 meters from the subject whereas after that point, it is the other way around. You can experiment with other cases by means of this background-blur calculator:
http://howmuchblur.com/#compare-1.5x-50mm-f1.8-and-2x-75mm-f1.8-on-a-0.9m-wide-subject
Panasonic Lumix DMC-G1 Olympus PEN-F Olympus E-M1 II Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS Panasonic Lumix G Vario 7-14mm F4 ASPH +20 more
OP ageminmo Forum Member • Posts: 74
Thanks a lot! Very useful link! Instant bookmarked!
After playing with the graph, I concluded that the effective aperture/sensor format matter most if the background is near.
But the focal length matters most if the background is far(like what the author said). Perhaps you need to be farther from the subject and compresses the background more causing more blurriness.
So I guess Olympus 75mm wins this one!
DaveLemi
DaveLemi Regular Member • Posts: 391
Re: Or learn about composition.....
Agree!
And what exactly is more bokeh?
If I had a dollar for every poster using thin DOF and bokeh interchangeably, I'd be very weathy.
Some of my pics can be found here-
http://www.flickr.com/photos/davelemi
 DaveLemi's gear list:DaveLemi's gear list
Olympus E-M1 Panasonic Lumix DMC-GM1 Nikon Z6 Panasonic Lumix G 20mm F1.7 ASPH Olympus M.Zuiko Digital 45mm F1.8 +4 more
Vlad S Veteran Member • Posts: 3,766
It's even more complicated than that
There is also the look of the OOF areas, which is what traditionally has been called "bokeh", and that also depends on the spherical aberration corrections. You can have more blur with hard outlines, or less blur with very soft edges, and it's difficult to tell without testing which case you will like better.
Vlad
 Vlad S's gear list:Vlad S's gear list
Olympus OM-D E-M5 Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Panasonic Lumix G 20mm F1.7 ASPH Panasonic Lumix G Vario 100-300mm F4-5.6 OIS +2 more
Sergey_Green
Sergey_Green Forum Pro • Posts: 12,058
Wonder ..
Is not bokeh a part of the composition?
- sergey
Robert Garcia NYC Senior Member • Posts: 2,200
I copied this from someone else and its true "Fast lenses lead to bad habits: I waste my time trying to create beautiful bokeh instead of focusing on the subject matter." except, I would put the word can lead to... in there.
Gerry Siegel
Gerry Siegel Veteran Member • Posts: 3,244
+1 for sure. Bokeh is really an obscure or undefined term and when we think we know what it means (creamy bokeh or what have you) as a significant variable, we all have something else in mind depending on our interests or fetishes....Portraits can be headshots or full body shots where subject and surrounds does depend on composition a whole lot... It is true that background appearance (has to be illustrated to define) depends on focal length, size of sensor and f stop.... And more-distances to subject and BG.
That is how I look at the argument of composition control;  space background to foreground as a parameter.
We seem to now have a standard in our eye that like other things is a residue of the 35mm film appearance.
Now when I used medium format, the equation changed and ultra fast lenses were not always suitable in portraits.  Or affordable....
Lenses now tout circular aperture blades, good for them,  and claim to give prettier appearance re circularity of light blobs.
As photographers we are also obliged to take  a more sophisticated approach to the subject.  But it takes some complexity of mind.
 Gerry Siegel's gear list:Gerry Siegel's gear list
Panasonic ZS100 Panasonic Lumix DMC-GX7 Olympus E-M1 Panasonic Lumix DMC-GX8 Panasonic Lumix DC-G9 +4 more
(unknown member) Veteran Member • Posts: 5,193
versus
Your first calculations were right in fact. You should compare 42 with 28.
For a given magnification (or framing), you can compute this ratio to know which lens will have more background blurr..
You don't have to take into account the crop factor. (Because equivalent focal lenfth and equivalent aperture are equally affected by the crop factor)
quezra Veteran Member • Posts: 3,915
Medium format doesn't actually have ultrafast lenses.  The fastest lenses in DoF terms are all found in 35mm systems (there is nothing as fast as an 85/1.2 or 50/1.2 or 35/1.2 on 645 for example, let alone f/0.95 lenses).
OP isn't clear about whether he means the most blurring or the nicest blurring with bokeh.  They are not the same things.
 quezra's gear list:quezra's gear list
Sony a7 Sony FE 55mm F1.8 Sony Vario-Tessar T* FE 16-35mm F4 ZA OSS Sony Alpha NEX-5N Panasonic Lumix DMC-GH3 +10 more
Mr Olympian
Mr Olympian Regular Member • Posts: 224
Some easy tips
The reason some call these crop sensor cameras is because they yield the same image only "cropped".  Using a micro43 camera vs. an APS-C camera means using a different aspect ratio and little bit of a crop with a smaller field of view.   You lose a little background but the "blur" is about the same - some say greater, but that is another story.
If I want a little more subject isolation, I can have a subject take a step closer, make the background a little more distant, add some vignetting, or add a touch more blur when post processing.
About 6 years ago I used an old Olympus 4/3rds camera with a 300mm F/5.6 zoom and was able to get the shallow depth of field look some crave. I am not a big fan, but when you want it there are many options with any camera.
If you really love always having a blurred background then maybe a full frame camera is the way to go.  I found it more of a nuisance because it was another factor I had to worry about.  Anytime I had more than one subject if I didn't factor in DoF, there was a good chance one would end up slightly blurred.
"your camera is better than mine, shame about your photos" - Anonymous
 Mr Olympian's gear list:Mr Olympian's gear list
Sony RX100 Nikon D600 Nikon AF-S Nikkor 24-85mm F3.5-4.5G ED VR
DonParrot Veteran Member • Posts: 4,968
Re: Wonder ..
No, it's a tool allowing you to avoid composing your puctures. Although it can be a nice feature when it comes to shooting portraits.
I wish I was an OLYgarch
 DonParrot's gear list:DonParrot's gear list
Panasonic FZ1000 Olympus E-30 Olympus OM-D E-M5 Olympus E-M1 Panasonic Lumix DMC-GH4 +13 more
versus
The op has the correct formula (except that he made a mistake with the crop factor) for the background at infinity..
Anders W
You are welcome!
Right!
Don't think you will be disappointed.
Anders W
Re: It's even more complicated than that
I too prefer to reserve the word "bokeh" for the quality rather than quantity of the blur. They are of course two completely different things. The quantity is something you can deduce from the lens specs and the shooting situation. For the quality, you have to look at how the lens actually performs.
Anders W
Christof21 wrote:
versus
... but since background at infinity is but one possibility (and perhaps not the most likely one), the calculator is pretty handy.
Sergey_Green
For portraits ..
versus
Take APSC with 50/1.8, this will make it 75mm equivalent, which if framed well will in the majority of cases look better than 150mm (75/1.8) equivalent. The totale amount of blur is hardly relevant here.
- sergey
Anders W
Re: For portraits ..
versus
On what grounds would it look better?
Why isn't it relevant?
