Review of Sony Xperia Z3 (Including Samples)
Started Jan 8, 2015 | Discussions
TSGames Regular Member • Posts: 261
Hi everyone,
I thought I make a review of a phone I just got a few days ago, and share my thoughts, impressions and image results with you.
Before I start, I have to note that my previous phone was a Nexus 5 and I'm usually don't use my phone for serious photography. I just think it's good to have a usable camera with you.
Okay, here is a short list of what I like and dislike, so for the ones who don't want to read the whole review
Pro:
- Nice Build Quality
- Camera produces good image results
- Good Low-Light performance for a phone (up to ISO 12800)
- 4k Video capturing is supported
- Waterproof, so you can use it even for underwater shots, which is great
- 120 fps Slowmotion video function
- Great battery life (Even when heavily used still around 40% at the end of the day)
- Dedicated camera button which opens the camera pretty quickly even when the phone is in standby
Cons:
- Sometimes the phone "floats" on the surface (probably because of the glas on the backside)
- Camera app is sometimes a little bit "complicated" to use
- Sometimes focus doesn't seem to lock correctl
Moving one and describing a little more what already mentioned above, especially the camera features:
While I don't use my phone for any serious photography as mentioned above, I found the results pretty good.
The camera itself offers 20.7 MP (and a F 2.0 lens!) but most time it makes more sense to use the reduced 8 MP mode, also because all the scene modes (like HDR, High ISO) just work in this resolution.
After taking the first shots in good lighting conditions at the full 20 MP resolution, I found the results quite good. The images showed a lot of detail, even due you could see some details where "smeared" especially in darker areas.
What I noticed while trying to take some flower macro shots: The focus doesn't seem to always focus on what you would actually like to. The default camera app doesn't offer any macro focus mode (at least I didn't see any), which make it tricky. After several tries, it finally worked, but it was a little bit annoying.
When shooting at night, I tried to use the High ISO mode offered by the app. It seems to be the best mode to get "bright" images even at night. It usually takes 1/8 s exposure time and uses an appropriate ISO, which can be as high as ISO 12800. I first thought you won't see anything but noise on the images, but was very impressed that you could still use them, at least in a very small size. Sure, they're still noisy and lack of detail, but having a photo is better than having none, right? In combination with the F2.0, you can still capture a lot of light, and the images are even brighter than what you see with your eyes.
I also like the ability to capture underwater. While the touchscreen is not working, you still have a dedicated shutter button to take your shots. I didn't had the chance to actually try it, but that will come soon as well.
All in all, I think it's a great phone and the camera quality is (for what you can expect from a smartphone) pretty good. It may also replace your Point and Shot, if you don't need an optical zoom.
Here, as promised, some Out-Of-Phone Samples:
Full-Resolution Sample (ISO 100)
HDR Mode
ISO 12800
Hope this was helpful and Best Regards
Torsten
 TSGames's gear list:TSGames's gear list
Sony RX10 III Sony a7R II Sony FE 90mm F2.8 macro Tamron 28-75mm F2.8 III
afterswish1
afterswish1 Contributing Member • Posts: 743
Re: Review of Sony Xperia Z3 (Including Samples)
That's just what I was looking for, thanks very much! Have you tried the 120fps mode at all?
Gravity will make you crazy until you get the hang of it.
March Of The Tripods
March Of The Tripods Contributing Member • Posts: 856
Those samples are pretty good. Amazing really, astounding even.
"People who think they know everything are a great annoyance to those of us who do." - Isaac Asimov
OP TSGames Regular Member • Posts: 261
Yes, I also tried it. The internal app allows you to select the range you want to slow down after you've recorded it. This will then be saved as a seperate video. The original 120FPS 720p video is still available as an original which I think is great. The software video stabilization works great as long as you don't shot 4k (I guess there are limits for the processing in realtime here).
Regards
Torsten
