1DX Firmware update
Started Jan 7, 2015 | Discussions
mrlugnut New Member • Posts: 8
1DX Firmware update
I just got my new 1DX in the mail, and I must say this camera is the real deal.  I checked Canon's website for firmware updates, and it said version 2.0.3 is available.  When I powered up my camera, the version that is currently loaded is 2.07.  So is the version on my camera a newer version than the 2.0.3?  Seems confusing to me?
 mrlugnut's gear list:mrlugnut's gear list
Canon EOS-1D X Canon EF 85mm F1.8 USM Canon EF 135mm F2L USM Canon EF 70-200mm F2.8L IS II USM
Canon EOS-1D
PhotoKhan Forum Pro • Posts: 11,765
Re: 1DX Firmware update
I can't help you, because I don't own a 1DX.
The fact that you're not getting a reply is living proof how, by throwing the 1D's into the same forum as all FF Canon cameras on earth, DPR has driven most 1D users to other, more friendly e-locations.
I hope this "bump" might lead to one of the dozen 1DX users still remaining here to help you out.
In the meanwhile, why not contact Canon, themselves about this?
All the best.
PK
“Loose praise may feed my ego but constructive criticism advances my skills”
http://www.pbase.com/photokhan
(PBase Supporter)
tarjei99 Senior Member • Posts: 1,300
This is not unusual. We've seen before that new firmware appears in new cameras before it becomes available for download.
I presume that it is a precaution in case there is an issue.
Robert98 Regular Member • Posts: 189
2.0.3 is the latest version available for download (mine's running that). But this Google-translated link describes a user in the same boat as you and suggests (without any evidence) that Canon occasionally put out a batch of cameras with a later firmware before releasing it for download generally:
https://translate.google.com/translate?hl=en&sl=es&tl=en&u=http%3A%2F%2Fwww.canonistas.com%2Fforos%2F1d%2F492308-nuevo-firmware-canon-1dx-firmware-2-0-7-a.html
 Robert98's gear list:Robert98's gear list
Sony RX100 VII Sony a7R III Sony a7R IV Sony FE 55mm F1.8 Sony FE 70-200 F4 +3 more
Tizzio
Tizzio Senior Member • Posts: 2,208
I bought my second 1Dx less than two months ago… firmware is 2.0.3
Totomo Yap
Totomo Yap Regular Member • Posts: 103
Any picture ?
 Totomo Yap's gear list:Totomo Yap's gear list
Canon EOS 60D Canon EOS-1D X Mark II Canon EF 70-200mm F2.8L IS II USM Canon EF 24-105mm f/4L IS USM Canon EF 24-70mm F2.8L II USM +2 more
pikeface Contributing Member • Posts: 533
So you may have seen 2.07 is now released, however I have a problem in that all my saved settings from 2.03 will not load under 2.07.  Has anyone else having this problem. Please post to let me know incase its just my 1DX.
I can confirm that I can save and reload new settings using 2.07.
Help !!!!!!!!
Have a look and leave a message
www.pbase.com/jeremy_broome_smith
Found this on a german web site
http://www.dforum.net/showthread.php?p=2094156
* 1 These changes cameras can not read the "Camera Settings File" with firmware version 2.0.7, when it was created with cameras with Firmware Version 2.0.3 (or earlier) is installed. If the "Camera Settings File" need, create it after upgrading to firmware version 2.0.7.
http://www.kentphotoprinting.co.uk
