Are their "good" and "bad" copies of lenses?
Started Jan 6, 2015 | Polls
bruxi
bruxi Regular Member • Posts: 318
 bruxi's gear list:bruxi's gear list
Canon EOS 60D Canon EF 50mm F1.4 USM Canon EF 70-200mm F4L IS USM Canon EF 24-70mm F4L IS USM
POLL
Yep, there is always variability - it's the luck of the draw
50.0% 11  votes
A little bit, but not as much as people say
36.4% 8  votes
Nope, some shooters are just way too fussy
13.6% 3  votes
  Show results
Albert Silver Veteran Member • Posts: 3,373
It is a fact.
 Albert Silver's gear list:Albert Silver's gear list
Nikon D750 Nikon AF-S Nikkor 70-200mm f/2.8G ED VR II Sigma 24-105mm F4 DG OS HSM Tamron SP 35mm F1.8 Di VC USD +1 more
Graham Meale
Graham Meale Veteran Member • Posts: 3,864
Re: Are their "good" and "bad" copies of lenses?
I've never returned a lens, and have always been happy. This means either ...
  1. I've been lucky
  2. I'm not fussy enough
  3. The variation between lenses is not enough to lose sleep over.
Not sure which.
 Graham Meale's gear list:Graham Meale's gear list
Canon EOS 5D Mark II Canon EOS 5D Mark III Canon EOS 5D Mark IV Canon EF 50mm F1.8 II Canon EF 100mm f/2.8 Macro USM +7 more
Just another Canon shooter
Just another Canon shooter Veteran Member • Posts: 4,691
Re: It is a fact.
Albert Silver wrote:
bruxi wrote:
It's not a debate.
http://www.lensrentals.com/blog/2012/11/canon-24-70-mk-ii-variation
Right. One of those crops is from the worst (excluding 3), the other from the best out of 70; I am just not sure which is which?
 Just another Canon shooter's gear list:Just another Canon shooter's gear list
Canon EOS 5D Mark II Canon EF 15mm f/2.8 Fisheye Canon EF 35mm F1.4L USM Canon EF 50mm f/1.2L USM Canon EF 135mm F2L USM +4 more
robert614 Senior Member • Posts: 1,745
As with anything manufactured,there are tolerances.
How big the tolerance range allowed depends on the company,price of the item,etc...but there is always slight differences with anything produced in quantity.
That said,I can't recall ever returning a lens because I thought it was a bad copy.But I have seen differences in sharpness when comparing a lens I've owned with the same lens owned by a friend.
Robert
rebel99 Veteran Member • Posts: 4,025
Re: As with anything manufactured,there are tolerances.
Robert
+1
same here, robert, i own about 13-14 canon "L" lenses, 2 zeiss, and 1 sigma 150mm f2.8 macro lenses. none has been off in any way that i can put my finger on, right out of the box! so, if that is the case and this copy variation is true, at least one of my lenses should have been off in focus or something else. so far, i am not believing in this copy variation myth others' mileage may differ! happy zooming.
jp4 Senior Member • Posts: 1,202
From the LensRentals article quoted in other replies, "I think most people realize there is sample variation."
 jp4's gear list:jp4's gear list
Canon PowerShot G5 X Canon EOS 80D Tokina AT-X Pro 11-16mm f/2.8 DX II Canon EF 100-400mm F4.5-5.6L IS II Canon EF-S 18-135mm F3.5-5.6 IS USM
bruxi
OP bruxi Regular Member • Posts: 318
Re: It is a fact.
touché
bronxbombers4 Veteran Member • Posts: 3,387
yes
No text.
  1. I've been lucky
Not sure which.
#1 with a little bit of #2 (and of course some #3 on average)
but believe me you would've returned the first 17-40L I got!
And I've seen differences between copies of this and that that are enough to reasonable be able to tell the copies apart.
Mostly it's not too bad, but some designs have higher tolerance requirements than others and just in general if you get one of the lesser copies and one of the very better, you can definitely see the difference.
Kjeld Olesen
Kjeld Olesen Veteran Member • Posts: 4,594
Yes, a comparison here
 Kjeld Olesen's gear list:Kjeld Olesen's gear list
Canon EOS M Canon EOS 6D Canon EOS M5 Canon EOS R6
hotdog321
hotdog321 Forum Pro • Posts: 21,141
I've never gotten a new pro-quality lens that was bad (aside from a Canon 20mm f/2.8 lens decades ago, which was simply a bad design). I guess there is some variation from copy to copy, but in 30+ years of shooting, I've never been tempted to return a lens.
 hotdog321's gear list:hotdog321's gear list
Canon EOS 5D Mark IV Canon EF 100mm f/2.8 Macro USM Canon EF 70-200mm F2.8L IS II USM Canon EF 24-70mm F2.8L II USM Canon EF 16-35mm F4L IS USM +3 more
ben sensler Regular Member • Posts: 138
Yes, there are good and bad copies in my experience.  My theory is that the manufacturers have calculated that it is better for their bottom line (and also for the average buyer's bottom line) if  buyers do the quality control.  This lowers the price of lenses and keeps the average buyer, who isn't knowledgeable enough or fussy enough to detect small differences, happier. This often leaves more demanding buyers frustrated.
Andy Blanchard Senior Member • Posts: 1,349
On lens tolerances...
Apparently, Canon (and presumably other manufacturers) allow for a little imperfection here and adjust this via a setting on both camera and lenses. In Canon's case think this is a scale that runs from +5 to -5 with L lenses and 1-series bodies requiring a setting of no more than +/-2, but it's been a while since I discussed this with CPS and I might have the numbers wrong. The sum of the two values then provides an adjustment bias to the focussing mechanism that should correct the error(s) and bring things back into spec.
Where this comes unstuck is when you have a lens and body that are individually within acceptable tolerance, but in combination are beyond the ability of the system to correct, for instance a body with a setting of +2 and a non-L lens with a setting of +4 (which is the issue I had - CPS replaced the lens which fixed the problem). This is why you'll sometimes see issues with a lens having focussing issues on one body but not another, and why people often send both lens(es) and body in when they are having lens recalibrations done.
Andy
maarensv
maarensv Senior Member • Posts: 1,106
Yes, there are
A good copy is a lens that performs like it should be. That is within specifications, which is not by definition perfect.
Than there are bad copies, lenses that perform visibly less than should.
I've had few experience with lenses that were bad, and I mean really bad. The 100-400 V1 was a complete gamble, both optically and technically. I've had a total of 5, of which I had te return 3. Two for optical reasons, one for bad AF.
Had a 70-200 f4 that had a de-centering problem. Wide open the fault was quite clear, stopping down masked that fault. At first I thought it was typical for that lens, but later copies I have used were much better.
Than there were the 55-250mm IS lenses (non-STM). Bought one for my dad and one for my brother. My dad's copy was the worst performing Canon lens I'd ever seen, the replacement was perfect (or normal as I use to say). My brother first copy was bad also, and the replacement less good than my dad's one, but good enough.
All lenses I speak of were new out of box. Latest Canon lenses seem to have less variations.
Not a typical Canon issue, as I've seen similar issues with Nikon and even worse with Pentax.
Sandor.
 maarensv's gear list:maarensv's gear list
Canon 6D Mark II Canon EOS R Olympus E-M5 III Canon EOS R7 Canon EF 100mm F2.8L Macro IS USM +22 more
run2000 New Member • Posts: 3
The best answer I've seen on this subject:
http://www.lensrentals.com/blog/2008/12/this-lens-is-soft-and-other-myths
In short, it's not just the lens, but lens + camera combination that can make all the difference. For sufficiently high resolutions, the manufacturing tolerances of both can come into play.
(unknown member) Veteran Member • Posts: 9,509
bruxi wrote:
Of course there are.
That is why Lens Rentals tests several lenses and does not just get the same result with each.
When buying a second hand lens it is even more of a lottery as you never know if a lens has been dropped or abused or whatever.
I think some more expensive lenses may well have less sample variation but I think there will be variation with even the best.
Then again, the same probably applies to cameras but no one ever mentions this.
And of course, the sample variation between photographers is FAR greater.
So while the answer is undoubtedly yes, the chances of getting a lens that is not within the manufacturers standards and unusable is very slim.
