Samsung NX1 Audible Noise and OIS Questions
Started Dec 22, 2014 | Discussions
STexan Contributing Member • Posts: 657
I'm running the Samsung 16-50 "S" lens on NX1 with updated firmware (body and lens)
Why does the camera (or lens?) make a "humming/whirring" sound at all times when it's on? It sounds like the image stabilizer on my Canon 70-200 lens when activated. I hear this when the OIS switch on the lens is on or off. Furthermore, when the shutter is activated, I can't hear any new "noise" from the OIS system, however it does seem to be working to reduce camera shake.
It made this noise before any updates were applied, as well. I have it defaulted (in settings) to engage OIS on shutter press as opposed to Off, or Always On.
Is this normal or perhaps a bug or a bad lens? Do these lenses operate the OIS in an "idle"mode that still spin even when OIS is not supposed to be activated?
If I remove the lens from the body, then turn the body on, I do not hear any noise.
 STexan's gear list:STexan's gear list
Samsung NX1 Samsung 16-50mm F2.0-2.8 Samsung 50-150mm F2.8 S +2 more
Samsung 16-50mm F3.5-5.6 power zoom Samsung NX1
Tugela Contributing Member • Posts: 755
Re: Samsung NX1 Audible Noise and OIS Questions
More likely you have the camera in servo auto focus mode, so it is continually focusing when it is on. the stabilizer has nothing to do with that. Put it into single shot mode unless you need continual autofocus (your lenses will probably have a longer life doing that as well).
 Tugela's gear list:Tugela's gear list
Nikon Coolpix P900 Sony RX100 V Nikon Coolpix P1000 Samsung NX1
OP STexan Contributing Member • Posts: 657
I wish it was that simple.  I've tried all the different auto-focus modes, OIS modes, but it "hums" constantly regardless, even without shutter press.  So can I get a confirmation from others running the 16-50 "S" lens on NX1 body that they do [or do not] hear this same "hum" all the time with the lens attached and the camera on?
This hum does not seem to have anything to do with the camera auto-focusing, that is a separate unique "clicking" sound that can be heard in addition to the hum, when it initially focuses.
But understand, there is a noticeable difference in OIS effect when shutter is partially depressed, so OIS is NOT actuated until you partially depress the shutter button, yet the hum is still there, regardless.
(put your ear to the body or lens and you'll hear it if it's there)
Do I need to contact Samsung or do others' similar setups do the same?
Feel like I'm talking to myself here, but ... just spent some time via chat with some Samsung tech support guy, and he's of the opinion I have a bad unit (body or lens,  not sure) and says I'll need to ship it in for examination and/or repair ... oh joy.
OrdinarilyInordinate
OrdinarilyInordinate Veteran Member • Posts: 3,741
Swap to manual focus and see if the noise is still there. Turn off OIS after that if not and check again.
 OrdinarilyInordinate's gear list:OrdinarilyInordinate's gear list
Nikon Coolpix A Fujifilm X-T2 Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Fujifilm XF 23mm F1.4 R Fujifilm XF 56mm F1.2 R +4 more
Done all that.  No help.  Something is wrong and if no one else is having the issue, I'm leaning towards a defect in the lens.  Will be receiving a 50-150 lens in a few days.  If that is silent, I will assume a bad lens and see about shipping my 16-50 back for replacement.
The contacts all look good, re-seating does not help.
Usee
Usee Senior Member • Posts: 2,223
My 16-50 PZ is doing the same like yours - as it seems...
...I'm also not quite happy about that, because I'm pretty picky in regard of sound...
...however, the lens I have is optically that good, that I prefer to have a quiet lens sound, over lens aberrations...
...maybe you will get what you want, but I guess, that the lens needs to keep the stabilizer working all the time, to provide perfect alignment of the OIS lens elements...
...even in the "standby" position.
I would check the optical quality first and if you find some decentering, or smth.
you have a real reason, to send it back, for replacement.
Envy is the highest form of recognition.
Stop to run, start to think.
Think twice - that doubles the fun!
Your world is as big, as Your mind.
Avoid to have only one point of view!
U see?
 Usee's gear list:Usee's gear list
Samsung NX1 Samsung NX 12-24mm F4-5.6 ED Samsung NX 45mm F1.8 2D/3D Samsung 16-50mm F3.5-5.6 power zoom Samsung 50-150mm F2.8 S
arbuz Senior Member • Posts: 2,247
My copy is completely silent.
 arbuz's gear list:arbuz's gear list
Nikon D600 Samsung NX300 Panasonic Lumix DMC-G6 Samsung NX30 Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS +14 more
jkoch2
jkoch2 Senior Member • Posts: 1,198
Answer: Samsung 18-200 f/3.5-6.5 Movie Pro Lens with Silent AF
Probably the AF, although possibly the OIS too.
I don't think Samsung promises that either the 16-50 or 55-200 fast lenses, although fast and expensive, have silent AF.   This is a pitty, since buyers may wish to shoot video and be unable to afford other lenses or rig-up external mics, which I don't think the NX1 allows one to control very well.  Camera reviewers usually ignore on-board audio capture altogether, although they should not.  True, the earliest DSLR cameras that captured good video had such bad on-board mics, and some remain very bad, but most people need to know if there is some way to get half-good sound without need for a studio-type set-up or an awkward add-on apparatus.
The Samsung Movie Pro lens uses a silent voice coil motor that is supposed to spare audio capture of any lens noises.
Anyone considering use of the NX1 for lots of video should probably consider that lens.  It is not as fast as the two expensive, recent lenses, but is pretty versatile and apparently optimized for video.
Oh, did I repeat myself saying that the two fast lenses are expensive?  Well, repeat I shall again.  Of course fast lenses are expensive, but (expensive or not) they weren't billed as ideal for video, unless one dumps or smothers the native audio or shoots only in loud settings.
Nougat77 Forum Member • Posts: 98
OK. So I just tested my NX1 with three lenses.
  • w/16-50mm S lens - There is a very low audible hum (sounds like OIS hum) when I put my ear near the lens. I shut off OIS on the lens and in the menu and I still hear it. It's not loud enough to be picked up in video, so I don't mind it at all. You really have to have to be in a very quiet room and have your ear near the lens to pick it up. I also tried switching to manual focus and still hear it, so I really don't think it's focus noise. The focus noise on this lens is the quietest I have ever heard -- nearly silent and perfect for video.
  • w/50-150mm S lens -- the OIS hum is a even lower on this lens. Again, it does not go away when OIS is turned off or when switching to manual focus. The focus noise on this lens is just as good as the 16-50mm S.
  • W/16-50mm PowerZoom Lens -- the OIS hum is a little louder with this lens. Again, it does not go away when OIS is turned off or when switching to manual focus. The focus noise on this lens is louder than the two S lenses, but still acceptable for video.
None of the lenses are perfectly quiet, but not loud enough to bother me one bit. I am curious why the OIS seems to be active when disabled.
 Nougat77's gear list:Nougat77's gear list
Well that's good news and bad. Good that maybe this is either wide-spread problem, or by design. But it would certainly explain a limited battery time. I'm just used to Canon I guess, and they spin up when needed, but Samsung may have decided to keep them spinning all the time, then engage when time for faster response/ready time ... but that makes no sense, because the hum is there even when OIS is turned off on the lens. Why run the OIS and consume power if the OIS is not switched on?
I say all this assuming this is OIS hum (gyros), With no lens on the body, the hum is not there.  Maybe a future lens update will correct this? [fingers crossed]
The "noise" is not a problem for me, and probably won't be for others. The vids I do are typically made for view only, and add sound later if desired. I can't say that I can hear the hum in any vids I've done where there was no wind.
Thanks for the feed back.
amanieux Junior Member • Posts: 26
my 16-50 PZ make the same continuous humming on both nx1 and nx500 but the 30mm f2 is silent on nx1 and nx500. it is as if the ois in the 16-50PZ is never turned off even with ois off in the menu ?? it does not look good for the lifespan of the 16-50 lens, voluntary planned obsolesence from samsung ??
funkandsoda Forum Member • Posts: 67
Could you perhaps also check if your OIS works right from the start with the 16-50 s lens? Mine seems only Start to work after the 4th picture was taken after turning on the camera. I'm still trying to find out if this is a general problem or if it could be solved by exchanging / repair.
Is it possible to handhold 1/20 - 1/10 pictures that are sharp after turning on the camera for you? Mine are all blurry till picture number 5... In my opinion it sounds more like a firmware Bug... But i'm also thinking of sending it in for repair.
See also here: http://www.dpreview.com/forums/post/55970506
There are more people having the same issue.
 funkandsoda's gear list:funkandsoda's gear list
Samsung NX1 Samsung NX 30mm F2 Pancake Samsung NX 50-200mm F4-5.6 OIS Samsung NX 85mm F1.4 ED SSA Samsung 16-50mm F3.5-5.6 power zoom +2 more
yes based on the many bugs i see on nx1 and nx500 (such as the manual focus in video bug) i am assuming it is most likely general software bugs rathen than specific hardware problems. they have good hardware but bad software
Markr041 Forum Pro • Posts: 10,078
There is no "manual focus in video" bug. You do not understand how the camera works. If you go into video mode first and then set  MF when you shoot you stay in in MF mode and in video mode until you change either. This is true in the latest firmware. Your general negative statement applies to early firmware, not to the latest.
 Markr041's gear list:Markr041's gear list
Panasonic ZS100 Olympus TG-5 Canon EOS M Panasonic Lumix DMC-GH4 Nikon Z6 +5 more
SurfGuy Regular Member • Posts: 140
I just got the 16-50mm S lens and have had no issues with noise or vibrations at all. The lens works spectacularly with OIS turned on both mode 1 and mode 2.
the problem i has with both nx500 and nx1 firmware upadated last month to the latest fw version available for both cameras was the following:
1 go in manual focus mode
2 i do my manual focus
3 i press the record button
-> it goes back to AF, my focus is lost
Kisaha Senior Member • Posts: 2,300
My 16-50pz does that as well! I kept it, as the previous one was silent, but had some focusing problems. The sound of these small mics is unacceptable for me anyway and I am using different sound equipment if there is any need for that. I hope it won't explode!
