Shutter count on E-PM2
Started Dec 21, 2014 | Questions
NorthNJDavid New Member • Posts: 11
Good day all.  I have read a few posts about how to get the shutter count on the PEN series of cameras, but that procedure does not seem to apply to the E-PM2 model.  Does anyone know how to get this count on this model?
Thank you in advance!
Olympus PEN E-PM2
emoned New Member • Posts: 1
Re: Shutter count on E-PM2
Tested is on E-PM2 and works:
By following these steps you can check your shutter count as well as a few
other things. Follow these steps:
1. While holding the "Menu" button, press Power button to switch on
2. Press "Menu" and go to "Monitor brightness adjustment" screen
3. Press "Info" and "OK" button at same time, you will see the screen
showing "Olympus"
4. Press the following buttons in the sequence: Up, Down, Left, Right
and then press the Shutter, followed by Up (dial button in my E-P2)
5. Engineering mode page is seen. Press dial button to Page 1, 2, 3, and "D".
6. Shutter count is on "Page 2" under "R".
The other lines on the screen mean:
R: shutter release count
S: flash use count
C: CMOS cleaning mode (with mirror lock-up - in E-410 series)
U: number of ultrasonic dedusting, ~ number of power switch on
V: number of use of LiveView
B: number of shot using In-Body Stablization
Please be careful when doing this. Although it's probably perfectly safe to
do this i hold no responsibility if you mess up your Pen.
Regards
Alex Notpro
Alex Notpro Senior Member • Posts: 1,013
Where is the "Monitor brightness adjustment" screen?
 Alex Notpro's gear list:Alex Notpro's gear list
Sony FE 35mm F1.4 Sony a5100 Sony a7 II Sony E 16mm F2.8 Pancake Sony E 10-18mm F4 OSS +7 more
Guy Parsons
Guy Parsons Forum Pro • Posts: 40,000
Re: "Monitor brightness adjustment" screen
It's the LCD adjustment item in the setup (wrench) menu, anyway, see my page for the same instructions, it may help. http://homepages.ihug.com.au/~parsog/olyepl1/12-epl1-shotcount.html
Regards......... Guy
