Overall good camera
Started Dec 17, 2014 | User reviews
Teje Forum Member • Posts: 77
Overall good camera
Coming from DLSR Systems from Nikon (d7000), Canon (two 40d's and a 7d) and Pentax (K20D, K-x), I have to say I'm pretty much satisfied with this small camera.
I was looking for something to carry around everytime, and nx3000 is a great camera to go out, very small with the powerzoom, or with a Samsung pancake. I paid 265€ for a open box, wich is nothing short of a bargain, specially considering it comes with a copy of Lightroom 5.
Build quality is great(for the price), and I found design very attractive. The lens build quality is good also, without wobbling on extension. Also Ifunc button it's very clever and give you another control ring, making twin control dials in a sub 300€ camera, with is great. Camera battery is good for a day out and usb charging is convenient.
In the other hand, micro SD cards and camera strap are simply a CRAP.
Camera offers great quality in good light, but fails to impress in low light, specially in JPG. In Raw results are a lot more cleaner with a little pp work in Lightroom, but it isn't on par with 4/3 cameras or Sony Nex line. Otherwise, results are good up to higher sensitivities for web use or good sized prints, if you work a little. It also applies to DR, which I found a little restricted compared to it's m 4/3 or Sony peers, but easily worked around thanks to pretty accurate metering.
Working on RAW+jpg slow down the camera too much for my taste.
AF is another weak point of the camera, working great in good light (in photo) but becoming very unreliable and missing a lot in low light. This makes me want to try nx300, which phase detection af would make more usable in low light scenarios.
Also manual focus assist is poorly developed and hard to use because of the magnification which does not allow the user to go back to the full view of the shot when used.
Wifi is great and easy to use when you get used, and also let's you downscale quality to 2mp, which I found convenient. Note that RAW files can not be sent to a smartphone, only jpg files.
Lens is also pretty decent, with a correct stabilizer, and very useful powerzoom for video. Distortion and corner shading is auto corrected at some sharpness wise loose but it's not that bad and I find the compromise in between lens range, quality and small size a pretty handy package. Also AF is good, should be better on nx300.
Overall, I find the camera to be pretty good for a everyday carry out camera, and Samsung lens range is one of the most cheap and good in terms of optical quality, specially if you look at pancakes like the 30mm or fixed focal lenghts.
Samsung NX3000
20 megapixels • 3 screen • APS-C sensor
Announced: May 8, 2014
Teje's score
3.0
Average community score
3.8
bad for good for
Kids / pets
mediocre
Action / sports
mediocre
Landscapes / scenery
good
Portraits
good
Low light (without flash)
acceptable
Flash photography (social)
unrated
Studio / still life
good
= community average
ChuckTa Senior Member • Posts: 1,492
Re: Overall good camera
I am a bit curious on your remark on the M4/3  high iso better than NX3000. I have a EPL5 and I can't agree on that, Olympus cheats on high ISO worst being EM10 where actual iso 1600 = 851.
 ChuckTa's gear list:ChuckTa's gear list
Sony a7 Samsung NX500 Fujifilm X-T20 Panasonic Lumix DC-GX9 Panasonic Lumix DC-GF10 (GF90) +8 more
causey Regular Member • Posts: 143
Great review, Teje--very informative for people like me who moved to Samsung mirrorless from a dslr system (Pentax, in my case). My I ask you, how would you rate the 16-50mm powerzoom against Pentax's pretty good 18-55mm II? I was tempted to buy this camera for the zoom, but the camera isn't supported by DxO Pro yet... I have a nx2000, and I was looking for a second camera, to avoid changing lenses on a trip to the Canyons. Thanks!
jimrpdx
jimrpdx Veteran Member • Posts: 3,954
nx300 updates
Reviews suggest the PDAF sensor does better at high I so as well so the nx300 will help there as well.  The focus in low light will still be an issue at times though as PDAF does not switch on in really low light.. but DMF focus override is just like quick shift from Pentax plus focus peaking helps a lot!  It comes in colors too, I am using red
Jim near Kelso: PK + NX user - - http://granitix.blogspot.com
former Alpha and mic43 user
 jimrpdx's gear list:jimrpdx's gear list
Olympus E-M1 Sony a7 II Pentax K-S2 Pentax 18-50mm F4.5-5.6 Panasonic 12-60mm F3.5-5.6 OIS +2 more
OrdinarilyInordinate
OrdinarilyInordinate Veteran Member • Posts: 3,741
I agree--Samsung's 20MP sensors have higher low ISO performance than m4/3, as shown on DxO Mark. I don't know why you think they perform worse than micro 4/3rds--that's not true.  Same for DR.
Here's an example for NX300, which is on par with NX3000:
http://www.dxomark.com/Cameras/Samsung/NX-300
(it does better than Canon's crop sensors too).
 OrdinarilyInordinate's gear list:OrdinarilyInordinate's gear list
Nikon Coolpix A Fujifilm X-T2 Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Fujifilm XF 23mm F1.4 R Fujifilm XF 56mm F1.2 R +4 more
P.S.: DPR's editing function is being buggy again--won't save the post, so I'll add another:
Having owned a Nikon D5200 with really great low light performance and high sensor score on DxO Mark, I can say with confidence that low light performance of NX300 (and consequently NX3000) should absolutely be better than just "acceptable" and is reasonably good for APS-C. I wouldn't use JPEG out of camera for it, but processed RAW is fine up to ISO3200 for low light indoor shots of people and objects.
Auster Pilot Senior Member • Posts: 1,222
Just wanted to pickup on this point (others have already voiced similar opinions concerning low-light capabilities so I won't repeat them here but I am in agreement with them).
I have an NX3000. Both with legacy lenses attached via an adaptor or by switching an AF lens to manual mode I have no problem switching between magnification mode and normal mode. With an NX (AF) lens in MF mode - lifting the finger off the shutter button or depressing it returns the view to normal.. With legacy lenses - depressing either the shutter or OK button returns the view to normal.
Neil....
The Sky is a Beautiful Place
 Auster Pilot's gear list:Auster Pilot's gear list
Panasonic Lumix DMC-FZ200 Panasonic Lumix DMC-ZS40 (TZ60) Panasonic Lumix DC-ZS70 Pentax K-01 Pentax K-30 +2 more
OP Teje Forum Member • Posts: 77
Just my take on it; I had a em10 for a few days and find the files to be a little cleaner when pushing the shadows...also liked more the grain structure. I liked very much my d7000 for the same reason.
Samsung 16-50 is a very fine lens in my opinion, taking in mind it's price and size, and have a very useful range. Auto corrected files don't tell all the truth about the lens, since distorsion is high at wide angle, and corners suffer from field curvature which is clearly visible. Pentax 18-55 is in my opinion much better optically, specially in terms of corner resolution.
My personal opinion, having owned a d7000 is that files on the nikon one have a more appealing grain (to me) and better shadow response when pushed. Also chroma noise is little bit less noticeable. Highlight range are about the same in my opinion, with nikon highlight clipping being a little much abrupt than on the Samsung sensor.
With the 16-50 power zoom there are no way (at least I don't know how to do it) of going back to the full image since it has not a AF switch on the lens. If you depress the shutter button camera obviously goes back to the preview image but attempts to refocus next time you push the shutter.
