Photojournalist's upgrade.
Started Dec 15, 2014 | User reviews
hotdog321
hotdog321 Forum Pro • Posts: 21,141
The 16-35mm focal lengths are some of the most useful zoom ranges available, ideal for architecture, landscapes, street photography, photojournalism, artistic effects, even environmental portraits when used properly. I've been a photojournalist for over 30 years and replaced my old 16-35 f/2.8 version 1 with the Canon 16-35 f/4L IS. I bought this new f/4 version because, frankly, my old 16-35 isn't very sharp (v. 2 isn't much better), especially at the corners.
I shot some comparison tests at f/4 at 16mm, 24mm and 35mm. The new 16-35 f/4 blows the old 16-35 f/2.8 version 1 out of the water and, here's the kicker: sharpness, resolution, color fringing, resistance to flare closely matches my fabulously expensive 24-70 f/2.8L II. Even out of focus highlights appear crisper and better defined.
The IS on the new 16-35 f/4 provides exceptional stability for hand-holding under low light conditions. The relatively compact lens hood is less cumbersome than the old design and includes a pinch-style lens cap. Although few will miss it, the new design does not incorporate a gel filter holder on the rear like the old 16-35 f/2.8 version 1.
I'm a photojournalist and prefer a f/2.8 lens to match my other lenses, but the optics on this new lens are so darn good that I've slapped that bad boy on one of my 5D III bodies and leave it there. Canon deserves kudos for producing a truly sharp extreme wide angle zoom at a reasonable price.
 hotdog321's gear list:hotdog321's gear list
Canon EOS 5D Mark IV Canon EF 100mm f/2.8 Macro USM Canon EF 70-200mm F2.8L IS II USM Canon EF 24-70mm F2.8L II USM Canon EF 16-35mm F4L IS USM +3 more
Wideangle zoom lens • Canon EF • 9518B002
Announced: May 13, 2014
hotdog321's score
4.5
Average community score
4.6
Canon EF 16-35mm F4L IS USM Canon EOS 5D
biza43 Forum Pro • Posts: 15,074
Re: Photojournalist's upgrade.
Agree. This lens is the first zoom that I have used confidently for landscapes, it is as good as primes.
www.paulobizarro.com
http://blog.paulobizarro.com/
 biza43's gear list:biza43's gear list
Fujifilm X-T3 Fujifilm X-T4 Fujifilm XF 16mm F1.4 R WR Fujifilm XF 70-300 F4-5.6 R LM OIS WR Fujifilm XF 33mm F1.4 R LM WR +1 more
gipper51 Veteran Member • Posts: 5,904
This is high on my list for 2015 to upgrade my 17-40L.  I've seen nothing but universal praise for this lens.  Frankly, I'm glad Canon made it f/4 because I'm sure they would have charged double had it been f2.8.  While all of Canon's newer L zooms are excellent, this is one of the few you could call a "bargain".
 gipper51's gear list:gipper51's gear list
Canon EOS 5DS Panasonic Lumix DMC-GX85 Canon EOS R6 Mark II Canon EF 85mm F1.8 USM Canon EF 135mm F2L USM +20 more
victorian squid
victorian squid Veteran Member • Posts: 3,391
Completely agree. I'd almost go as far as saying this lens is a bargain. I've gone from being a little impressed to completely head-over-heels crazy in love. From everything I've been able to discern, this lens is every bit as sharp, with color, contrast, CA, you name it - this is the sibling to the 24-70, not some distant cousin. I got this to replace the 17-40, which I like quite a bit actually. I only really expected to find it sharper in the corners - and of course the added advantage of IS.
My first side-by-side tests against the 17-40 showed it was quite a bit better than that. While any of my side-by-sides with the 24-70 showed it to be nearly equal (and in some cases - superior). I was almost shocked to see that Reikan FoCal backed this up with numbers. The only L lens I have that's sharper is my 100L macro.
 victorian squid's gear list:victorian squid's gear list
Canon EOS 6D Canon EOS 70D Canon EF 24-70mm F2.8L II USM Tamron SP 150-600mm F5-6.3 Di VC USD Canon EF 16-35mm F4L IS USM +37 more
rebel99 Veteran Member • Posts: 4,025
hey, craig, you are talking me into getting one of these lenses, even though i have a bunch of very high IQ lenses at this FL
cheerz.
hotdog321
OP hotdog321 Forum Pro • Posts: 21,141
cheerz.
. . .  then my job here is done.  My Canon stock is skyrocketing!
Abu Mahendra Veteran Member • Posts: 5,312
....and...and...if you live in SEAsia, you can pick one up new with Canon warranty or $925.
>> I love the Canon EF-M 11-22mm f/4-5.6 IS STM lens! <<
 Abu Mahendra's gear list:Abu Mahendra's gear list
Canon EF 100mm F2.8L Macro IS USM Canon EF 70-200mm F2.8L IS II USM Canon EF 70-200mm F4L IS USM Canon EF 24-70mm F2.8L II USM Canon EF 40mm f/2.8 STM +5 more
hey, Abu, why such a difference in price of the same lens between 2 market?
cheerz.
Don't know. I got mine for $983 in Singapore in July. I should have waited. With the depreciating rupiah/apreciating dollar I can get it for $925 in Indonesia today.
hotdog321
That's remarkable! I performed down and dirty "real world" tests comparing my 16-35 f/4L IS to the 24-70 f/2.8L II at f/4 at 24mm and 35mm. It seemed that the two were equally fine lenses, but frankly I had a hard time believing my own results. This new wide angle is quite a bargain!
yodermk Senior Member • Posts: 1,393
Thanks guys for confirming that there is no need for me to buy the 24-70 2.8. I can get the same great quality from this lens, and my 24-70 f/4, while not being quite as good, is much more practical than the 2.8 for its lighter weight and IS.
If it's a *Single* Lens Reflex, why do I need so many lenses?
 yodermk's gear list:yodermk's gear list
Canon EOS 80D Canon EOS 5D Mark IV Canon EF 400mm f/5.6L USM Canon EF 100mm f/2.8 Macro USM Canon MP-E 65mm f/2.5 1-5x Macro +12 more
Rexgig0
Rexgig0 Veteran Member • Posts: 7,399
cheerz.
Perhaps the Canon USA price is higher, to cover all of the returns, by US buyers who cannot shoot up to the lens' potential, and return them, or want to buy several, and keep the "sharpest" one, returning the others, or just want to use the lens for a vacation, and then return it?
I already knew US buyers were overly spoiled, but I recently read a book on the subject of advice for US expatriates wanting to live in Asia, and the book cautioned that returns in Asia are seen in a quite different light.
Back on the subject, this lens is now perched at the top of my to-buy list, now that I have finally acquired my third 600EX-RT and 7D Mark II, though when I can fund the lens is still to be determined. I have worked some seasonal over-time, and will see how much of that makes it past the income tax with-holding.
I wear a badge and pistol, and make evidentiary images at night, which incorporates elements of portrait, macro, still life, landscape, architecture, and PJ. I enjoy using both Canons and Nikons.
 Rexgig0's gear list:Rexgig0's gear list
Canon EOS 7D Mark II Canon EF 135mm F2L USM Canon EF 400mm f/5.6L USM Canon EF 100mm F2.8L Macro IS USM Nikon AF-S Micro-Nikkor 60mm F2.8G ED +54 more
