Canon 50mm f/1.4 focus and sharpen problem
Started Dec 14, 2014 | Discussions
kusser New Member • Posts: 3
Hi. I'm new at the forum, so please forgive me if I'm asking something you already answer. I have searched around the forum (and all Internet!) and, although I found similar cases, I didn't found an answer.
The problem is: I'm unable to get sharp images with my 50mm lens on high apertures. For example, if I try at f/1.4, with 1/500 and 10 feet from the subject, I only get blurry images of my subject and I get focus on other points of the image.
I have made some tests with a tripod and different distances, with no better result.
I will show you two examples (I have a lot). The first one is at f/1.4 with 1/500 and 10 feet from the subject (the green ball). You can see that I don't get a sharp image.
The green ball is the subject and where my focus point is.
The second one is with the same conditions, but f/8.0 with 1/80. And here I get good result.
The green ball is now sharp.
Both were taken at the same moment, with a tripod.
My camera is a Canon T3i.
If you can help me, will be great.
Thanks a lot in advanced.
Lemming51
Lemming51 Forum Pro • Posts: 15,278
Re: Canon 50mm f/1.4 focus and sharpen problem
Plane of focus in both pics appears to me to be the pink ball in front.  The green ball is out of focus in the first because it is beyond the shallow depth of field at f/1.4, but is sharper in the second because it is well within the depth of field at f/8.
The lens (and/or the camera) may be front-focussing a bit and need calibration if it was actually autofocussing on the green ball.
Or ...
Did you select the single center focus point to be active?   The individual sensors are a bit larger than the boxex in the viewfinder and may have covered the pink ball.  If you used the default setting of Auto Focus Point Selection, that will AF on the closest subject covered by any of the sensors.
Unapologetic Canon Apologist
 Lemming51's gear list:Lemming51's gear list
Canon EOS 40D Canon EF 50mm F1.8 II Canon EF-S 15-85mm f/3.5-5.6 IS USM Canon EF 70-200mm f/2.8L USM Canon EF-S 55-250mm f/4-5.6 IS STM +5 more
arty H Senior Member • Posts: 1,546
There is going to be some copy variation. How does the lens do at apertures like F2, F2.8, F4 & F5.6. The lens should get sharper as you stop down, but should be pretty sharp at F2 and F2.8. It should be excellent be F4. Most lenses get sharper as you stop down.
clarnibass Senior Member • Posts: 2,480
Assuming you used the middle focus point, you can see the green ball is not in the middle of the frame. The focus point wasn't exactly on it. Also the contrasty part of this ball, the drawing, is even higher in the frame.
The focus point is around that "thing" between the big green ball and other ball and the most contrasty and very close area is where the small balls highlights separating them from the darker background. So, not surprising at all, the camera focused on the most contrasty target almost exactly where the focus point.
No sign at all that there is any problem with the lens from this test. If you have focus issues on a good target where the focus point is directly on that target, that's different. Maybe you can post examples if you do?
If you used a non-center focus point then that's also different.
OP kusser New Member • Posts: 3
After months of thinking I was crazy, last night I finally came to a solution. I checked what happend with very low light and full automatic (no flash) and the photo was perfectly taken by the camera at f/2.0.
I tried taking the photo with every aperture available, and realize I was starting to get good results over f/4. So, automatic was working good but manual don't. So, the problem should be on the camera.
I did a camera settings restore and... SOLVED!
Here is the same picture, taken before and after the restore. You can see the letters on the ball and everything is very sharp.
Left, before the camera settings restore. Right, after the restore.
Thanks anyway!
Kevin Coppalotti Veteran Member • Posts: 9,594
the 50mm f1.4 is soft at  f1.4. It gets good at f2.8. as noted by others the dof matters, but it is still soft wide open. back in the day Joe mama did many tests with 50mm lenses and i concur with his results back then
I don't want to discourage you and I'm not saying the camera reset didn't solve a problem (weird but who knows...), however...
In your new side-to-side examples, you can see that the good focus example (right) has the center focus point exactly on the big ball where it says "student". The out of focus (left) has the center focus point under the writing, exactly on that thing that is in front of the ball, and there is even more contrast just in front/below that.
So again, it makes sense that it was front focused (in comaprison with the green ball, but correct for the photo). I'm not saying this is what happened, but in the left example it makes more sense that the focus isn't on the green ball. The focus in both of those photos is what I would expect it to be, assuming you used the center focus point.
Actually, both photos has the same focus point, and that's my problem. I don't have the RAW photo any more, so I can't show you right now the focus point, but it was in both photos on the letters over the ball. It's weird, i know, I tried to solved it for months. I'm still making some tests to verify that the problem is solved.
Thanks for your answer!
Wait... do you mean these are crops and not the full photos? I assumed they are not crops. If they are crops (different ones, I guess done each seperately) then what I said doesn't apply. If they are not crops, but full photos, and since you used the same (I assume center) focus point for both as you say, then the focus point wasn't on the letters on the out of focus example.
