Olympus 45mm vs Olympus 60mm macro for food photography
Started Dec 11, 2014 | Discussions
Skeeterbytes Forum Pro • Posts: 23,182
Re: Panasonic 30mm macro
Mark Thornton wrote:
http://www.43rumors.com/panasonic-30mm-f2-8-macro-to-be-launched-in-q1/
This might be the answer for your food photography.
Perhaps out of left field is the 4/3 Oly 35/3.5 macro. It delivers actual 1:1 and is very sharp and quite cheap...make that inexpensive. It will be pretty large once you add the adapter and focus is really slow and annoying, lacking a focus limit switch, but macro is usually done MF anyway.
It's excellent optically. There's also the brilliant 4/3 50/2.0, which is larger, more expensive and goes to 1:2. Many consider it the sharpest of all 4/3 lenses and it's the one selected for testing most E-series cameras. For µ4/3 I'd probably prefer the mZD 60, but if that's too long then there are these other options.
Rick
OP innatelychatty Forum Member • Posts: 60
Re: Olympus 45mm vs Olympus 60mm macro for food photography
This is the type of food photography I usually take, but I also like to focus in on particular details (like the crust on a pie, etc.)
How far away were you (or the camera) when you took these photos?
Mark Thornton Veteran Member • Posts: 4,570
Left field answer
That isn't left field, this is:
9mm bodycap. JPEG straight from the camera.
Mark
 Mark Thornton's gear list:Mark Thornton's gear list
Panasonic Lumix DMC-GX1 Panasonic Lumix DC-GX9 Olympus Zuiko Digital 11-22mm 1:2.8-3.5 Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital ED 12mm 1:2 +8 more
Cipher Senior Member • Posts: 2,662
I took these in Madrid, Spain this year with the 45mm
the food was behind glass, so IQ was affected a bit.  The place was also pretty crowded and people kept bumping into me and ruining my shots.
BHD2
BHD2 Regular Member • Posts: 104
I don't exactly remember, but probably ~3 feet.
 BHD2's gear list:BHD2's gear list
Ricoh GR III Nikon Z6 Nikon Z 24-70mm F4 Nikon Z 35mm F1.8
Re: Left field answer
Love it! And am suddenly hungry, to boot.
Rick
Uncle Frank
Uncle Frank Forum Pro • Posts: 21,511
Re: shooting food while seated at the table
When you say "I was seated with the camera above me at an arm's length for the first shot" - can you please elaborate? Do you mean you were seated and raised the camera above (or at level to) your head? Does that mean I cannot be seated at a restaurant and just have the camera pretty much attached to my face? What is the minimum focus distance for the 60mm macro lens?
The nice thing about the 20/1.7 is that I can remain seated and take pictures of my food without moving from my seat.
I can even flip the swivel of the lcd  down, hold the camera directly above the food, compose and shoot straight down without being too obvious.
Using a longer focal length like 60mm would require standing up and moving back from the table.  I'm also using the 25/1.8, but find that a bit too long.
You don't need a macro lens for this kind of casual food photography, which is why I suggest you give it a try with your 17/1.8 before you buy another lens.
Warm regards, Frank
Galleries at fdrphoto.smugmug.com
 Uncle Frank's gear list:Uncle Frank's gear list
Nikon D700 Olympus PEN E-P5
peppermonkey Veteran Member • Posts: 5,204
For food? Neither. Get the Panny 20mm...
5
Hello to all food and portrait photographers out there!
I currently have the wonderful Olympus OM-D E-M10 paired with my amazing Oly 17mm f/1.8 prime lens for landscape and street photography.
I am now in the market for a second prime lens. Ideally it would be a lens for both food and portrait photography, but if I had to prioritize one it would have to be food (recipes, restaurant dishes, etc. - so a lens that works well in low-light situations). I am looking at either the Oly 45mm f/1.8 lens or the Oly 60mm f/2.8 macro lens.
I like the shorter focal length of the 45mm, which seems to be a good short tele length and perfect for portrait photography - the bokeh isn't bad either! However I have read several reviews saying macro would be really helpful for food photography.
Between the Oly 45mm or the 60mm macro, which should I be getting? Is the macro lens capable of good bokeh in portrait photography despite its longer focal length and 1:1 macro capability? I have looked into the Panasonic Leica 45mm f/2.8 but it is sadly out of my budget.
The 17mm 1.8 might also be a solution but as I have not used it for food photography (as I don't have one), I can't say.
What I can say is that the 20mm is great for food. I also have the 25mm f1.4. And at times I have wanted something brighter than the 20mm f1.7 as restaurants and such tends to be quite dark at times so any extra speed would be greatly appreciated. What I have found out is that the 25mm, although better than the 20mm in low light because of it's extra speed, is too long and focusing distance too large to comfortably take photos of food from your seats. The 20? Awesome.
Although these are old (aka, I have gotten better since), should give you an idea of what the 20mm can do. As far as I remember, all were taken with the 20mm unless otherwise stated on the photo.
https://www.flickr.com/photos/peppermonkey/sets/72157629408163033/
Hubert
My non-digital gear: Agfa Isolette, Ricoh Ricohflex VII, Zorky 4, Fed 2, Konica Big Mini, Konica Auto S2, K1000, Yashica Electro 35 GX, Recesky
http://farm3.static.flickr.com/2034/2457111090_00eafbf8a4_m.jpg
http://www.flickr.com/photos/peppermonkey/
 peppermonkey's gear list:peppermonkey's gear list
Panasonic Lumix DMC-TZ3 Sigma DP2 Sony RX100 II Pentax K110D Panasonic Lumix DMC-GF1 +11 more
What the...
I think I just 'Liked' my own post...didn't even know I can actually do that...pretty dumb to be honest...
Hubert
honeyiscool
honeyiscool Senior Member • Posts: 1,376
Just seated normally, with the camera below my head. The 60mm focuses down to 7.4".
 honeyiscool's gear list:honeyiscool's gear list
Panasonic Lumix DMC-GX85 Panasonic Leica Summilux DG 25mm F1.4 Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital 17mm F1.8 Olympus 12-40mm F2.8 Pro +2 more
honeyiscool
I definitely agree with that. But my point was that 45mm f/1.8 is a great lens but won't add much to your food photography arsenal because its close focusing abilities are pretty poor and in practice, doesn't magnify details any more than the 17mm f/1.8 does. The 17mm f/1.8 can pretty much do just about anything you need to do informally.
The reason why I suggest the 60mm f/2.8 is because it opens up a whole new world of macro photography where you can focus on individual sugar crystals on a pie, really zero in on top of a cherry on top of a sundae, things like that. And it also functions as a great all-around medium telephoto lens and everything that such a lens is good for (headshots, street photography when you want to be more discreet, or just when you need such a long lens, etc.).
There are so many things worth photographing that really needs a medium telephoto macro lens. For instance, one of my hobbies is guitar building. If I really want to zero in on a bridge or a knob, only my 60mm can get close enough to where I feel like it's properly showing the detail I want to photograph. When I'm shooting at a concert, and I want to get a sharp picture of a drummer, often 60mm can be perfect. If I want to zoom in on a single unusual guitar pedal, most other lenses won't quite cut it. Wedding photographers rely on macro lenses for taking pictures of the ring, or eyelashes as part of a makeup shoot or whatever.
Yes, the 45mm f/1.8 is a wonderful lens but I personally find the 60mm f/2.8 to be a more versatile lens. Yet I still carry around the 45mm f/1.8 a lot more because sometimes, being really great at a few things is better than being pretty good at a lot of things and so, versatility isn't always the most important part of a lens, but when you're starting out with your lens collection, I think versatility is important. That's why I love the 17mm f/1.8, for instance. It's actually probably my third favorite lens to shoot with (after 25mm f/1.4 and 45mm f/1.8) but if I can only use one lens for the next three months, I pick the 17mm f/1.8 because it strikes a great balance between versatility and specialization.
Torsten Hoff Veteran Member • Posts: 3,787
Re: food photography
To me the color temperature is too cool, too much blue and not enough red makes the food look unappetizing. That's not meant as criticism, just an observation.
JeanPierre Martel Veteran Member • Posts: 3,304
Food for thought...
Even if that doesn't reply to the question of the OP, hereunder are some food to look at without gaining weight, taken at different focal lengths:
M.Zuiko 12-40mm, hand-held Olympus OMD-e-m5
Lumix 12-35mm, hand-held Olympus OM-D e-m5 (cropped image of a Pitaya)
Lumix 14-45mm, hand-held Panasonic GH1 (authentic Moon Cake, from China)
Lumix 14-45mm, hand-held Panasonic GH1 (Yin/Yang Soup, in a Guilin Restaurant)
Lumix 14-45mm, hand-held Panasonic GH1 (raviolis in a Guangzhou Restaurant, in China)
Lumix 20mm, hand-held Panasonic GF1 (Sea Bream plate in a Montréal Restaurant)
 JeanPierre Martel's gear list:JeanPierre Martel's gear list
Olympus E-M5 II Olympus M.Zuiko Digital ED 75mm F1.8 Leica Nocticron 42.5mm Olympus 40-150mm F2.8 Pro Olympus 8mm F1.8 Fisheye Pro +17 more
(unknown member) Veteran Member • Posts: 3,010
You can buy a manual focus 50mm f3.5 Minolta macro lens on E-bay for under 100 dollars and then buy the 45mm for portraits insread of the 60mm Olympus. I think macro would be very useful for food photography because of its close focusing ability rather than its macro ability. With the EM10 manual focus on static subjects isn't hard. Quite frankly this lens is a good portrait lens also. But if you want autofocus I would pick the 60mm over the 45mm. The 45mm is very sharp but its minimum focusing distance is going to be too long in many instances for food. I own the 45mm Olympus and the Minolta.
s_grins
s_grins Forum Pro • Posts: 14,011
If you're talking about taking food while eating, FL 60mm is too long. FOV will be insufficient, and only half of the plate will be on the screen. And you'll be struggling with AF because the plate will be too close.
Think about 20-30 mm FL
Camera in bag tends to stay in bag...
 s_grins's gear list:s_grins's gear list
Panasonic G85 Panasonic Lumix G 20mm F1.7 ASPH Sigma 30mm F2.8 EX DN Sigma 60mm F2.8 DN Art Panasonic Lumix G Vario 14-140mm F3.5-5.6 O.I.S +3 more
Elemental Photography Senior Member • Posts: 1,093
If I could only bring one...
I own both and for food photography I find the macro very useful.  The Olympus 45mm doesn't focus very close, relatively speaking, and with food photography I usually have plenty of room to set up the shot how I want it, so the long focal length is rarely a problem.  The 45mm is a great portrait lens but the 60mm does well when shot wide open.
A photograph is a creative interpretation of reality.
 Elemental Photography's gear list:Elemental Photography's gear list
Pentax Optio WG-2 Panasonic Lumix DMC-GF2 Panasonic Lumix DMC-GX1 Panasonic Lumix DMC-GH3 Panasonic GH5 +8 more
Re: If I could only bring one...
Lovely photo, the crystals on the cupcake are so clear! How far away were you from the subjects (the woman and the cupcake) when you took these photos? Do you think the 60mm could be used in a restaurant setting, i.e. sitting down and photographing a dish (or part of a dish) directly in front of you?
rsmithgi Senior Member • Posts: 2,939
You can consider the Sigma 19mm or 30mm as well. The 19mm focuses down to 7.9 inches. The 30mm focuses down to 11.8 inches. Neither is as fast as the 20mm F1.7 or 45mm F1.8 but both are sharp and well regarded for the price. The Sigma 60mm F2.8 is a nice lens also. Macro (IMO) is not needed for food photography. While the Oly 60mm Macro is a great lens, if you look for used lenses, you might be able to get all three of the Sigmas for the price of the Oly.
 rsmithgi's gear list:rsmithgi's gear list
Olympus E-M1 Olympus E-M5 III Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital ED 60mm F2.8 Macro Olympus M.Zuiko Digital 17mm F1.8 +5 more
gugarci Senior Member • Posts: 1,622
The 45mm 1.8 works really well with some extension tubes.
 gugarci's gear list:gugarci's gear list
Panasonic Lumix DMC-LX3 Sony a6000 Sigma 19mm F2.8 EX DN Sony E 16-50mm F3.5-5.6 PZ OSS Sigma 30mm F2.8 DN | A +3 more
alatchin Senior Member • Posts: 1,055
The 45 is right... maybe not while seated, but stand up, take a step away and shoot... it is also superb for portraits.
The shots shown of detail of food is macro, not food photography.
A 17mm and 45 make a great pair:
“You don’t take a photograph, you make it.” -Ansel Adams
blog.alatchinphotography(dot)com
