Macro advice please
Started Dec 6, 2014 | Questions
soulman1949 New Member • Posts: 22
Macro advice please
I have a Canon EOS5D MkIII and (would) like to do (among other things) food, insect and flower photography. I've a number of zoom and prime lenses (including the EF 50mm f/1.4) but no macro lens.
1. I'm potentially looking at the Canon EF 50mm f/2.5 Compact Macro but I'm confused on a number of points. Firstly, looking at the spec the lens is described as producing 0.5X shots but reading the product description from one trader that states "Optional Converter for 1:1 Macro". Is this a separate product, as I'm struggling to find it listed in Canon's product range. What should I be looking for to get 1.0X magnification (I can't run to either of the EF100mm Macro lenses)?
2. Looking through Amazon, I see they advertise a couple of Canon Lens Extension Tubes EF12II and 25II. Am I right in saying these are a cheaper/starter alternative to a macro lens?
3. Also on Amazon they're advertising a "Metal Auto focus AF Macro Extension Tube Ring Set 13mm 21mm 31mm for Canon EOS EF DSLR SLR Camera Red 5D 6D 60D 600D 7D 70D 700D DC46" by XCSOURCE. Presumably this is a third party alternative to the Canon Extension Tubes. I realise there's a world of difference in price between this item, GBP19.99 and some GBP170 and that you get what you pay for, but does anyone have any comments on this item. Could I use this in conjunction with the EF50mm macro lens?
4. Finally, given what I'd like to be able to photograph better, is there any other product I should be considering?
Many thanks in advance.
Alan
PS can a teleconverter be used in conjunction with the EF 50mm Macro?
 soulman1949's gear list:soulman1949's gear list
Canon EOS 300D Canon EOS 5D Mark III Canon EF 50mm F1.4 USM Canon EF 100mm f/2.0 USM Canon EF 16-35mm F2.8L II USM +6 more
Canon EF 50mm f/2.5 Macro Canon EOS 5D Mark III
photosen Veteran Member • Posts: 6,226
Re: Macro advice please
Alan
I've had Kenko extension tubes but I'm just about to start seeing if they work well (didn't have live view before and focusing was a pain). My impression is that the best is to have a dedicated macro lens instead of tubes, at around 100mm or more, with some way of getting plenty of light. A half way solution might be a close up lens on a telephoto.
 photosen's gear list:photosen's gear list
Canon EOS 30D Canon EOS 70D Canon EF 35mm F2.0 Canon EF 50mm F1.4 USM Canon EF-S 10-22mm F3.5-4.5 USM +3 more
BAK Forum Pro • Posts: 26,020
1/ The Canon 50mm macro requires a separate unit that fits between the camera and the lens to get to the 1:1 reproduction ratio.
See http://gdlp01.c-wss.com/gds/5/0300003495/02/ef50f25compactmacro-im2-eng.pdf
I too cannot find a picture of this unit, but it is mention in the instructions.
2/ Buy a Sigma 50mm macro lens instead. Not unit needed.
3/ Consider a screw-in closeup lens instead. These screw into the front of an existing lens and let you get closer. Canon has several and other companies make them, too. I use Kenko.
cberry Senior Member • Posts: 1,127
There are many ways to skin this cat.
First of all, you should look at what you need in your macro photography:
1. Focal length + Magnification: There is a 5x option in the canon 65mm several 90-100mm options
2. Image stabilization.
3. A versatile prime for other purposes too. 100mm f/2.8 is lovely
4. Extension tubes. - better for wider lenses (50mm) no quality loss
5. Diopter filters - better for longer lenses some quality loss.
6. Kit lenses with front element removed (Yes this works !) and it's probably the cheapest!
cb
 cberry's gear list:cberry's gear list
Canon PowerShot G7 X Canon EOS 70D Canon EF 70-200mm F4L IS USM Canon EF-S 18-135mm F3.5-5.6 IS STM Canon EF-S 24mm F2.8 STM +3 more
(unknown member) Veteran Member • Posts: 5,590
The EF 50/2.5 Macro gives 1:2 or half life size reproduction on its own. To get 1:1 you should ideally use the Canon Life Size Converter designed specifically for this lens. This converter has lens elements in it and is not simply an extension tube. The advantage is that the optical quality is very good indeed as the converter is matched precisely to the optics of the prime lens. Unfortunately the converter, if you can find one, costs about as much as the 50/2.5 itself. I suspect Canon may have now stopped producing this item although some US retailers are still advertising it. For most purposes though 1:2 is probably enough so you might be completely satisfied with the 50/2.5 Macro on its own.
However 50mm as a focal length is not ideal for insects as the working distance will be too close. 100mm or even longer is probably better for insects (but possibly too long for food photography).
Cheaper yes, but of less ultimate optical quality depending on what lens you use them with. Most lenses are computed to give their best results at medium distances to infinity. They will physically focus closer when used with extension tubes but often at the expense of reduced sharpness and increased aberrations, especially at the edges of the image. You'll need to stop the lens down to f/8 or less but then you'll probably need to in many cases anyway because of the limited depth of field at high magnifications.
You could use extension tubes with the 50mm macro yes. The more extension you use the closer to your subject you will have to be and there is a considerable corresponding drop in maximum aperture which can make their use a bit tricky. Make sure any 3rd party set of tubes provides full auto exposure and focus coupling through the electrical contacts - the very cheap ones may not.
Alan
The Canon teleconverters (Extender 1.4x and 2x) can not. Other 3rd party makes may physically fit provided they do not have a front lens element that extends into the back of the lens they are being used with. But you will lose 1 or 2 stops of light and the optical quality may not be that brilliant so it may not be a preferred solution.
I'd suggest you get a cheapish set of 3rd party extension tubes to use with your 50mm f/1.4 and see how you get on. If that really stimulates your interest in macro photography then you might feel it is worth investing in a better quality but inevitably somewhat more expensive solution.
Good luck.
RS_RS Senior Member • Posts: 1,788
Alan
Good luck.
I agree with just about all of that, but here is a bit more information based on over 20 years use of the 50/2.5 and LSC.
My impression is that the 50/2.5 is very specifically designed for close-up work. What I mean by that is that performance at or near f/2.5 is nothing special. It is valuable to have that maximum aperture for focusing, but the lens really comes into its own at the sort of apertures usually used for close-up work, say, f/5.6 to f/11, where all aberrations are extremely well-controlled – including distortion, which makes it an excellent lens for copying artwork. For this and a number of other purposes it is useful to have a standard-focal-length macro lens, and this is the only one that Canon produce. On a crop-factor body the EF-S 60/2.8 is much preferable for its far more convenient handling, but of course you cannot use that on FF.
The Life Size Converter is a combination of extension tube and (4-element) approx 1.4× teleconverter optically matched to the lens, giving very good performance. With the LSC the range is ×0.25 to ×1 (an EF25 tube would give approx ×0.5 to ×1). The lens is aware of the presence of the LSC through the same extra-pin protocol used by Extender-enables lenses to recognise Extenders, and with the LSC reports itself as 70mm f/3.2 (slightly oddly – one would expect f/3.5). Interestingly, the Canon 100mm macro lenses, which are internal focusing, drop to about 70mm at ×1, so by comparison with them, with the LSC the 50/2.5 gives a bit more working distance than you might expect. The LSC will fit other EF lenses (all, I think) but not EF-S lenses. Other lenses, even Extender-enabled ones, do not recognise it, infinity focus is usually lost, and optical performance is generally poor with a few reported exceptions. So it is best to regard the LSC as a dedicated accessory for the 50/2.5.
OP soulman1949 New Member • Posts: 22
That's super, many thanks everyone for the very helpful comments and advice.
I'll follow your recommendations meland and look at some third party tubes to get me started and we'll take it from there. Appreciate you all taking the time to reply.
Best wishes from a cold and grey Manchester, UK.
Alan
