50mm f1.4 not wide enough on 60D, ideas??
Started Nov 25, 2014 | Questions
shani Forum Member • Posts: 60
Hi guys,
I fall in love with photography again every time I put my 50mm back on my camera, but it's just too cropped on my 60D body for general use, because it turns into something like an 80, and I'm feeling pretty bummed about it.
Is there anything with that low aperture, but wide enough for me to use, maybe similar equivalence to 35mm (not that I've ever used one!), that is a reasonable price, e.g. hopefully lower than $500.
I don't think I could go higher than f2, unless you really convince me it's worth it.
Cheers!
Canon EF 50mm F1.4 USM Canon EOS 60D
Just another Canon shooter
Just another Canon shooter Veteran Member • Posts: 4,691
Re: 50mm f1.4 not wide enough on 60D, ideas??
The 35/2 IS would be a great choice. I am not sue how much it is in Australia (~$600 in the US).
 Just another Canon shooter's gear list:Just another Canon shooter's gear list
Canon EOS 5D Mark II Canon EF 15mm f/2.8 Fisheye Canon EF 35mm F1.4L USM Canon EF 50mm f/1.2L USM Canon EF 135mm F2L USM +4 more
Araldite Contributing Member • Posts: 829
35mm f2.0 $649 dollars in Australia form CamBuy. Good choice of lens
 Araldite's gear list:Araldite's gear list
Fujifilm X-S10 Fujifilm 50-230mm Fujifilm 15-45mm F3.5-5.6 OIS PZ +2 more
tarjei99 Senior Member • Posts: 1,300
EF-S 18-55
EF-S 18-135
are two lenses that easily should cover your needs.
PhotoDaveM New Member • Posts: 8
I would take a long hard look at the new EF-S 24mm f/2.8 STM lens that just started shipping.  I have one and quite like it - just wish I had more time and good weather for photography.  It's not as fast as the 50mm, but it is almost as inexpensive (but much better built) focuses faster and quieter, and is quite a bit wider.  And of course it is very small.
Dave M - Ogden, Utah
 PhotoDaveM's gear list:PhotoDaveM's gear list
Canon EOS 70D Sony a6000 Canon EF-S 18-135mm F3.5-5.6 IS STM Sony E 16-50mm F3.5-5.6 PZ OSS Canon EF-S 24mm F2.8 STM
brightcolours Forum Pro • Posts: 15,885
shani wrote:
Hi guys,
What is it about the 50mm f1.4 that you like? Do you like using it wide open, and notice the shallow DOF?
What do you mean by this. Do you mean an equivalent on APS-C for a 35mm lens on FF?
If you actually just meant a 35mm lens, being kinda equivalent to a 50mm lens on FF, then you have these relatively affordable options:
  • Sigma 30mm f1.4 EX DC HSM. Lens with nice bokeh, comes closest to the big aperture but wider than 50mm wish.
  • Sigma 30mm f1.4 Art. Improved version of the above lens.
  • Canon EF 28mm f1.8 USM. Not the nicest bokeh.
  • Sigma 28mm f1.8 macro. Nicer bokeh than the Canon above, bigger, heavier, slower AF.
  • Canon EF 35mm f2. Compact and light, bokeh can be nice up close, a bit less nice at middle distances. I like it.
  • Canon EF 35mm f2 IS USM. Bigger and better.
  • Samyang 35mm f1.4. Manual focus.
If you meant equivalent to 35mm on FF:
  • Canon EF-S 24mm f2.8. Very small, very affordable, lacks big aperture.
  • Canon EF 24mm f2.8 IS USM. Great lens, lacks big aperture.
  • Sigma 20mm f1.8.
  • Sigma 24mm f1.8.
  • Samyang 24mm f1.4, manual focus only.
Keep in mind that the wider a lens is, the less shallow DOF will be, DOF is aperture size dependent.
Cheers!
photosen Veteran Member • Posts: 6,226
Do a search on this forum, this is an age old question which many of us have had to deal with. My answer (not necessarily the best and certainly not the only one) was to get the 35mm f2; there's also a newer IS version which is apparently very nice but I think costs more than $500. I'm thinking of complementing both the 50mm f1.4 and 35mm f2 with the new ef-s 24mm f2.8. If you'd prefer a single length for all this range then a 17-55 or 17-50 might make sense. Good luck!
 photosen's gear list:photosen's gear list
Canon EOS 30D Canon EOS 70D Canon EF 35mm F2.0 Canon EF 50mm F1.4 USM Canon EF-S 10-22mm F3.5-4.5 USM +3 more
Tyr-Sog Contributing Member • Posts: 926
Sigma 30 1.4.
 Tyr-Sog's gear list:Tyr-Sog's gear list
Nikon D4 Nikon AF-S Nikkor 50mm F1.4G Nikon AF-S Nikkor 20mm f/1.8G ED Nikon 24-70mm F2.8E ED VR Nikon AF-S 70-200mm F2.8E FL ED VR
Tom Holly Contributing Member • Posts: 564
I had the same experience when I bought a 50mm canon prime for my 50D. At that time I didn't understand crop factors, and was thus disappointed with the results.
I then bought 30mm 1.4 Sigma, which gave me precisely what I wanted. It's equivalent to 50mm f/2 on full frame.
IN summary it's a fast "normal" prime lens for APS, which sounds like what you want.
Read this site:
http://www.michaelthemaven.com/?postID=1692&best-portrait-lenses-for-aps-c-1-6-crop-canon-body
 Tom Holly's gear list:Tom Holly's gear list
Canon 6D Mark II Canon EOS 90D Canon EF 50mm F1.4 USM Canon EF 85mm F1.8 USM Canon EF 135mm F2L USM +11 more
Steve Balcombe Forum Pro • Posts: 15,582
shani wrote:
Hi guys,
I have the Sigma 30/1.4, the older model as it happens but old and new are very similar in performance. Great lens, compact, fast, HSM focusing, reasonably good wide open and properly sharp by f/2.
However if I were buying today I would possibly go for the canon 35/2 IS. Comparing both lenses at f/2 it's sharper than the Sigma especially towards the corners, and it has the huge advantage for low light shooting of four-stop IS. It's great having f/1.4 on the Sigma, but as soon as you have to stop down a little for sharpness or depth of field, the advantage is lost - but the 35/2 still has its image stabilisation. Don't let anybody tell you IS is for long lenses - as soon as you have less than ideal light it's a great thing to have on any lens.
The other one to consider is the Sigma 18-35/1.8. It's optically outstanding and of course it has the added flexibility of being a zoom. The two disadvantages are no IS, and it's *much* bulkier and heavier. It's also the most expensive of the three.
MAC Forum Pro • Posts: 18,502
Agree 35 f2 IS
 MAC's gear list:MAC's gear list
Canon EOS 7D Mark II Canon EOS RP Canon EOS M6 II Canon EOS R8 Canon EF 70-200mm f/2.8L USM +7 more
davel33 Senior Member • Posts: 2,978
Save your money and get the 35 F2 IS, its a great lens
Dave
 davel33's gear list:davel33's gear list
Canon EOS R Canon EOS R6 Canon RF 35mm F1.8 IS STM Macro Canon RF 24-240mm F4-6.3 Canon RF 85mm F2 Macro IS STM +29 more
lighthunter80
lighthunter80 Contributing Member • Posts: 990
As mentioned, the Sigma 30 1.4 Art (the new version) seems to be the perfect candidate for you. Its wider, as fast and not too expensive.
It's an APSC only lens but if you don't go full frame in the nearest time I would suggest looking at it.
 lighthunter80's gear list:lighthunter80's gear list
Canon EOS R Canon EF 70-200mm F2.8L IS II USM Sigma 35mm F1.4 DG HSM Art Sigma 50mm F1.4 DG HSM | A Canon EF 16-35mm F4L IS USM
Powerdoc Veteran Member • Posts: 3,941
try the 24 EFS STM
the new 24 mm STM should be great
It's a 37 mm equivalent, very light, quiet focusing, nice IQ, and pocket friendly price : http://www.the-digital-picture.com/Reviews/Canon-EF-S-24mm-f-2.8-STM-Lens.aspx
It's all about photography
 Powerdoc's gear list:Powerdoc's gear list
Fujifilm X-T1 Fujifilm X-H2S Fujifilm X-H2 Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 27mm F2.8 +13 more
Re: try the 24 EFS STM
38 and something mm equivalent, actually
