Why has Canon Abandoned F/2.8?
Started Nov 18, 2014 | Discussions
DavidNJ100
DavidNJ100 Contributing Member • Posts: 514
A basic set of lenses consists of three zooms. For Nikon those were 12-24, 24-70, and 70-200 F2.8 zooms. For Canon they have been a 16-35, 24-70, and 70-200 F2.8 zooms. In both cases only the 70-200 have IS. Tamron and Sigma have 24-70 and 70-200 F2.8 zooms. Tamron has a 15-30 zoom coming out early next year.
Canon introduced the 70-200 in 2010 and the 24-70 in 2012 which makes them much newer than Nikon's lenses which date from 2007-2009. The two Tamron's on the market are from 2012.
Then in 2014 Canon introduced 16-35/4L IS. And it now appears we are moments from seeing a new 11-24/4L in early 2015. Canon's 16-35/2.8 dates from 2007.
Have Canon abandoned fast super wide angle lenses? For video and activities that have motion, including wedding photography, the shutter speed can't be dropped below 1/50th (video) or 1/80th second or so. Low light is often an issue.
Is Canon abandoning F2.8 under the assumption that a higher ISO can compensate? Do they expect their future cameras to have better high ISO performance?
 DavidNJ100's gear list:DavidNJ100's gear list
Samsung TL350 Canon G9 X Canon EOS 7D Canon EF 300mm f/4.0L IS USM Canon EF-S 60mm f/2.8 Macro USM +21 more
Jonathan Brady
Jonathan Brady Veteran Member • Posts: 6,725
Re: Why has Canon Abandoned F/2.8?
12
Look how big that front element is... now imagine it needs to let in another stop of light...
Great Bustard Forum Pro • Posts: 45,641
Simply because...
6
...Canon has released an update for the 17-40 / 4L in the form of a 16-35 / 4L IS before an update to the 16-35 / 2.8L, and are going to release an 11-24 / 4L, doesn't mean that they've abandoned f/2.8 on UWA.  It just means that they felt the f/4 lenses should come first.
rebel99 Veteran Member • Posts: 4,025
technically, making UW tele zooms are very complicated (controlling perspective, for example) to make and costs a lot more. also, to make UW tele zoom, the elements have to be large as well! just look at the 24-70 f2.8, filter thread is 82mm and the same goes for 16-35 f2.8II.
cheerz.
Al Downie Senior Member • Posts: 1,407
7
Where did you read THAT??
Wider than 35mm, nobody's very interested in shallow depth of field, so avoidance of camera shake is the only real reason to want 'more light', and Image Stabilisation pretty much takes care of that.
11mm f2.8?? That would be nuts! First of all it'd be HUGE; secondly, you'd have to actually be a Parkinson's patient driving a car with square wheels in the middle of an earthquake to see camera shake through an 11mm lens.
 Al Downie's gear list:Al Downie's gear list
Fujifilm X-Pro2 Fujifilm XF 35mm F1.4 R Fujifilm XF 23mm F1.4 R Fujifilm XF 56mm F1.2 R APD +1 more
Landscapeforfun Contributing Member • Posts: 739
or shooting astrolandscape images. 2.8 is nice to have when you are limited to 30 second exposures and trying to reduce noise. I would LOVE an 11mm 2.8 lens.
 Landscapeforfun's gear list:Landscapeforfun's gear list
Canon 6D Mark II Canon EF 100mm F2.8L Macro IS USM Rokinon 14mm F2.8 IF ED MC Rokinon 24mm F1.4 Aspherical Canon EF 16-35mm F4L IS USM +1 more
Nobody?
All at 24mm f/1.4 ISO 100:
Re: Nobody?
Great Bustard wrote:
Doh! I stand corrected! Great images.
Schwany
Schwany Forum Pro • Posts: 10,169
Why would a couple of new lenses indicate f/2.8 is abandoned
Not abandoned, the f/4 design makes lenses affordable for a larger audience, and high ISO on newer camera models is pretty impressive, so shutter speeds can stay up there. I'd rather have f/2.8 in any lens, but f/4 isn't bad in a ultra wide angle, or a giant telephoto either.
 Schwany's gear list:Schwany's gear list
Canon EOS-1Ds Mark II Canon EOS 5D Mark II Canon EOS-1D Mark IV Canon EOS-1D X Canon EOS 5D Mark IV +14 more
Re: Nobody?
Kind of you to say!  That said, I'm pretty sure I'm in the minority when it comes to UWA shallow DOF, whether that be taking those types of photos or actually liking the results.
hotdog321
hotdog321 Forum Pro • Posts: 21,141
Good grief--I just read that the f/4 version is going to cost US $3000! Can you imagine how expensive a f/2.8 would be? Not to mention needing a wheelbarrow to haul the sucker around.
Also, from an engineering and optical standpoint, it is much easier to make a f/4 wide angle truly sharp at the corners as opposed to f/2.8. The new 16-35 f/4L IS is phenomenal. The 16-35 f/2.8 versions 1 & 2--not so much.
Finally, thanks to modern sensors ability to handle low light, there really isn't quite so much a desperate need for that extra stop. I've handheld the 16-35 f/4L IS several times in truly awful light and been quite pleased with the results.
photojournalist
 hotdog321's gear list:hotdog321's gear list
Canon EOS 5D Mark IV Canon EF 100mm f/2.8 Macro USM Canon EF 70-200mm F2.8L IS II USM Canon EF 24-70mm F2.8L II USM Canon EF 16-35mm F4L IS USM +3 more
DavidNJ100
OP DavidNJ100 Contributing Member • Posts: 514
Where did you read it would cost $3000? I find that a bit hard to believe; Canon doesn't have a market for a $3000 super wide angle.
The Nikon 14-24/2.8 is $2000 and very sharp with minimal distortion. The Tamron 15-30/2.8 VC will probably be around $1500. The Sigma 12-24/4.5-5.6 is $875 but maybe a step below the others optically. The Tokina 16-28/2.8, which DxOMark says is the sharpest of the wide angle zooms, is $640. The Nikon, Tamron, and Tokina all have large front aspherical elements and don't accept screw on filters. They are all over 2 pounds.
DavidNJ100
That is an exposed aspherical element, they all look like that as do fisheyes. Wide angles usually have the largest front elements. The exception is large aperture long telephotos.
There are lots of places where the subject is very close or very wide and the widest wide angle never seems like enough. This can include indoor shots to city streets.
hotdog321
Canon Rumors.  Poor source,  but I didn't feel like digging deeper.
photojournalist
Steve W Veteran Member • Posts: 6,999
Why do two new wide angle zooms, the EF 16-35mm f/4L IS and the EF 11-24mm f/4L, make you assume they have abandoned f/2.8? The 16-35mm f/2.8L II, while not the best landscape oriented lense is a great lens for photo journalism and events where the speed can really be taken advantage of.  Nikon had the 14-24 but no equivalent for event photography to the Canon.
For many years I used the f/2.8L II along side the Zeiss ZE 21mm and 18mm that gave me better performance for landscape work but the f/2.8 was a great lens to own.
 Steve W's gear list:Steve W's gear list
Fujifilm X-E3 Canon EOS R5 Sony a1 Sony a7 IV Sony a7R V +49 more
(unknown member) Forum Pro • Posts: 11,521
you know this how?
good grief that was almost as inane as your original post. a 16mm UWA isn't even in the same ballpark.
it would / will be the widest rectilinear zoom on the planet, constant aperture at that - they can set their own price. a full 3mm wider than anything else.
I honestly can't imagine this at F/4.0 let alone f/2.8.
for sure - and out side of the astroscape crowd to which the Samyang primes are far more suitable, there's just not as much use for the insane size of this as a 2.8
DavidNJ100
you know this how?
In the real world no one can set there own price.  As lenses move north of $2000 they have a fairly high price elasticity. The only EF lenses north of $2500 are long or fast telephotos. At $3000 they probably wouldn't have a big enough market to justify the cost manufacturing and marketing the lens.
The number of people who say 14mm, 15mm, or 16mm isn't wide enough and they must have 11mm isn't going to be large. On the other hand those who may chose an 11-24 to complement their 24-70 and 70-200 rather than a 16-35 is large. Nikon's 14-24 is the benchmark example. Except Nikon's is an F2.8.
It is the difference between a 117° FOV vs 104°, 100°, or 97° FOV.
both lenses are best in class - the 24-70 II and the 70-200 II.
the only lens that needs an update from the 2.8 lens lineup is the 16-35mm.
DavidNJ100
Among 62 Nikon full frame lenses listed at B&H, the Nikon 12-24/2.8 at $2000 is listed as the 9th best seller. It has over 500 reviews. The only more popular wide angle is the 20/1.8 prime for $800.
