bronxbombers4
- Messages
- 3,256
- Solutions
- 2
- Reaction score
- 959
With the copies I compared the edges seemed to be pretty similar across all three lenses across the entire focal range from what I recall (surprisingly more similar than center of the frame actually, where the tamron fell behind the most actually and the 70-200 and 70-300 traded places depending upon focal length).Centre sharpness of both lenses is very good, but what the 70-200 f4 IS shows towards the edges is not matched by the 70-300 L. The 70-200 is very consistent towards the edges, even wide open, where the 70-300 falls behind a bit. I know sample variance does exist, but both 70-300 L's I use do not match my 70-200. They are almost indistinguishable at 70mm, but at 200mm the difference is there.it depends upon copies, with my pair and what I see on about 70% of tests, is that the 70-300L is sharper wide open center frame at 70mm for sure although with a lot more lateral CA, less sharp at 135L and with similar CA, a trace sharper with a bit less CA at 200mm. Noticeably sharper and with noticeably less CA at 280mm compared to other with 1.4x TC.Hi,
I use both.
In IQ they are very close, but not completely equal. The 70-200 being little better straight from wide open across the entire focal range.
I have never been a fan of TC's and refuse to use 'm, so can't comment on that.
Regards, Sandor.
My 70-200 2.8 non-IS though fell quite behind all three at the edges on FF though.
