Walk around prime lens for crop sensor
Started Nov 10, 2014 | Discussions
Inka Qhapaq New Member • Posts: 12
Hello everyone!
I'm looking for a standard walk around prime lens for my crop sensor camera (Canon).
I already own a 50mm lens and as far as i know i have to decide between a 35mm and a 28mm lens now. (Please correct me if i'm wrong )
Although i read a lot of articles and seen several videos i can't decide between those two...
Which one would you recommend me to buy or should i get a completely different lens?
SystemAgnostic Contributing Member • Posts: 867
Re: Walk around prime lens for crop sensor
The 24mm 2.8 STM should be released and day now. I expect it will quickly become the defacto Canon crop camera walk around prime lens.
 SystemAgnostic's gear list:SystemAgnostic's gear list
Panasonic LX100 Panasonic Lumix DMC-GX85 Panasonic GH5 Panasonic Lumix G Vario 45-150mm F4-5.6 ASPH Mega OIS Panasonic Lumix G X Vario 35-100mm F2.8 OIS +6 more
DXWCanon New Member • Posts: 18
The 35mm f/2 IS is on my 70D almost 80% of the time, and pretty much only removed for my 70-200.
Its a great lens, can't say anything bad about it.
 DXWCanon's gear list:DXWCanon's gear list
Canon EOS M Canon EOS 70D Sony a7R II Canon EF-M 22mm f/2 STM Tamron SP 70-200mm F/2.8 Di VC USD +3 more
Michael Thomas Mitchell Forum Pro • Posts: 12,158
Inka Qhapaq wrote:
Hello everyone!
If you want to get as close to a 50mm/full-frame field of view as you can, you have two good choices in the Canon lineup. The 28/1.8 has an approximate 45mm field of view on APS-C. The 35/2 is approximately 55mm. The latter is a new lens, simply spectacular, and includes IS, as well. The difference between f1.8 and f2 is absolutely negligible. You won't find many used 35/2 copies around, but you will find plenty of used 28/1.8 copies at half the price.
If I didn't already have the 28/1.8, I'd certainly be looking at the 35/2. More modern in every respect, well-built, stabilized... what's left to consider?
 Michael Thomas Mitchell's gear list:Michael Thomas Mitchell's gear list
Canon EOS-1D Mark II Canon EOS 7D Mark II Canon EOS 80D Canon EOS 5D Mark IV GoPro Hero7 Black +6 more
MFog Regular Member • Posts: 160
I've got the 28 1.8, nice lens.  Wide on my 6D, normal on my 7D, works like a champ and cheap on the used market.  Heard awesome things about the 35 as well, but for a prime, the 28 is very good.
 MFog's gear list:MFog's gear list
Canon EOS 5D Canon EOS 7D Nikon 1 J1 Canon EOS M Canon EOS 6D +16 more
OP Inka Qhapaq New Member • Posts: 12
I didn't know about that one yet, but it looks like a perfect lens for me. Thank you!
 Inka Qhapaq's gear list:Inka Qhapaq's gear list
Canon EOS 7D
First of all thank you for your opinion!
Another user mentioned the new EF-S 24mm 1:2,8 STM lens that will be available for around 180€/$225.
When i had to choose between the 24mm and the 35mm which one would you recommend me to take?
Canon EOS 7D
focusbreather New Member • Posts: 8
"EF-S 24mm 1:2,8 STM" only works on APS-C bodies, and it will be actual 24mm on those, perhaps too wide for you. If I was you I would invest in EF lenses only, and possibly L (high quality luxury) lenses only, in case you ever get a full frame camera you will be able to use your lenses on that also.
Well, the 24 hasn't been released yet, so we won't have any ideas as to its performance.  Wait for it to be released and then check the reviews.  As a rule of thumb, I wait a while on new products to see where the chips fall and give the manufacturers a chance to work out the bugs.  It will probably be similar to a 40mm pancake in terms of optics and build and the 40 is highly rated.  A couple of things to consider, 24mm on a crop is close to a 35mm of a full, so you will have a widish/normal field of view.  2.8 is not a very fast aperture on a crop and the bokeh would me more in line with a f/4 on a full.  The 35mm will be closer to normal field of view, has a faster aperture and is image stabilized.
arty H Senior Member • Posts: 1,546
I'm like the 35 mm focal length on a crop it is great for people and low light. The shorter focal length would be better for outside shots of architecture, but not quite as good when the light goes down.
What do you want the lens to do? I find the view of the 35 to be most useful on crop bodies. The 35 F2IS does everything well, with fast and accurate AF, it is sharp to the corners, has excellent flare resistance...I don't think you can do better for a general purpose lens. For outdoor work, a good zoom will do, mI have of the time.
I like the 35 mm focal length so much that I have 3.
There are some excellent crop sensor zoom options!  Don't be afraid to look into that territory.  Quality crop zooms are far cheaper than the ff equivalents.  Sigma's 18-35 f/1.8 is simply amazing and one-of-a-kind.  It is the fastest zoom I've ever seen and super sharp.  It's like having wide to normal primes in one!  Then there is the Canon 17-55, it's f/2.8 and has IS... the best part is you can pick up a good used example for only about $600.  I had the Sigma 17-70 for a while and found it to be a good performer, if a little soft at the wide end.  The Tamron 17-50 is also reported good and dirt cheap used.
Jonathan Brady
Jonathan Brady Veteran Member • Posts: 6,725
It's tough to recommend a lens for someone without knowing lots about them and their style. So I'll just list some options and their +/-
Sigma 18-35mm f/1.8 - great lens in terms of image quality - like someone else said, it's like a bag full of primes in one zoom lens (otherwise I wouldn't recommend a zoom when someone asks about a prime). Better at the wider than the long end though. Also, sharpness falls off after about f/4 so if you are going to shoot closer to the long end (sounds like you might) and/or stopped down, it may not be the best choice given the cost, size, and weight.
Canon EF 24mm f/2.8 IS USM - small, lightweight, optically very good, has IS! I had this lens and sold it. I just wasn't impressed with the IQ difference between it and the 18-55mm IS STM. There's only 2/3 of a stop difference between the two at similar focal lengths (23mm on the zoom wide open is f/3.5) and while the prime is sharper, the performance difference and minimal use it got didn't justify keeping it around (for me).
Canon EF-S 24mm f/2.8 STM - small - like... pancake small, inexpensive, and if it performs as the MTF charts suggest it should, optically great. Also, I read an article or watched a video (can't remember which) where the author said when considering a new prime lens, cut your current focal length on half (or double it) to get a substantially different angle of view. So you have a 50, half would be 25 and the 24 is close enough. Downside is, it's pretty wide if you want a "standard" lens. Might not be what you're looking for. Also, it's designed for crop sensor cameras so should you decide to move to FF, it's incompatible.
Canon EF 28mm f/1.8 - older, inexpensive, not overly sharp, especially wide open. Not a bad choice bit there might be better options. Angle of view is great for a "standard" angle of view.
Canon EF 28mm f/2.8 IS USM - better than one equal to the one above in every way except max aperture and cost.
Sigma 30mm f/1.4 ART - could be a great choice and highly versatile. Faster than anything else on this list. Sharp, not large, and not insanely expensive. For me, it would be between this and...
Canon EF 35mm f/2 IS USM - I own this one and love it! Use it quite often on my 70D and on my 6D occasionally. Nothing negative to say about it.
There's also the Canon 35mm f/2 - it's an older lens and was replaced by the lens above. It's still good but compared to the newest lenses, it's not great.
For the Canon IS options, consider buying directly from Canon's refurbished store. If you wait for a 15-20% off sale, you can get them for well under what they're worth.
If you find yourself deciding between the Sigma 30 and Canon 35IS, just ask yourself if f/1.4 or IS is more important, and that'll make your decision.
Hope this helps!
So far i only had two kit zoom-lenses. (Never used a quality zoom before).
However, i was robbed in Bolivia this summer so i had no camera/lenses until i bought a Canon 7D MKI some days ago. (It took me weeks to decide between 70D and 7D )
So i have to buy myself a complete new equipment. And since i am a little tight on budget right now i thought i'll get myself 2 prime lenses until i can afford a quality zoom. And isn't shooting with prime lenses improving one's photographic skills?
Sadly the Sigma is very expensive (850€/$1.000), Canon (670€/$835) and i would not like to spend more than 750€/$950 on lenses right know, except there are very good reasons.
Canon EOS 7D
Atoche
Atoche Contributing Member • Posts: 682
I enjoy 24mm on crop for walk around (7D user here), but I also keep the 40mm in my pocket (small, easy to have in pocket)...
although sometimes even 24mm is not wide enough.  Lately, I have been using 5D (original) with the 24mm for walk around, with the 17-40 with me in a small bag - seems to suit me the best.
"I may be a geek, but it pays for the car...!"
 Atoche's gear list:Atoche's gear list
Pentax Optio WG-2 GPS Canon EOS 7D Canon EOS 6D Sony Alpha NEX-3N Canon EF 24mm f/1.4L II USM +9 more
totleytom Contributing Member • Posts: 564
I've been using the 35mm f2 non-IS for several years and I like it a lot - certainly too much top spend the money on an F2 IS when I've already got this one.
However, I am buying the 24mm f2.8 EF-S...
 totleytom's gear list:totleytom's gear list
Canon EOS 90D Canon EF 70-200mm F4L IS USM Canon EF 40mm f/2.8 STM Sigma 17-70mm F2.8-4 DC Macro OS HSM | C Canon EF-S 24mm F2.8 STM
Wow! Thank you so much Jonathan for this great summary!
I'll definitely get the Canon EF 35mm f/2 IS USM. It has very good reviews and also you say that you are loving it.
This lens comparison sheet helped me a lot, so thank you again!
Canon EOS 7D
Peter too Contributing Member • Posts: 909
The other one to look at is the highly regarded Sigma 35 F1.4 Art lens.
