What's the truth about the Panasonic 14-140II?
Started Nov 10, 2014 | Discussions
cathyph1 Regular Member • Posts: 362
It's all kind of confusing what I have read from various threads about this lens. Adam T says it's a great lens (and he doesn't seem to praise unless something really really deserves it). Others agree with him. But John Lock says it has terrible shutter shock problems even with the zero shutter shock option set on the Olympus E-M10. He says it happened in more than 50% of his photos that were in the problem shutter speed range. But Joachim Gerstl started a thread with high praise for the lens.
Others have said that if you set your E-M10 for zero shutter shock it is not possible for the Panasonic 14-140II to have shutter shock problems (at least I think that is what is being said by some).
And someone else says it has terrible problems with its image stabilization (OIS) that Panasonic has acknowledged but seems to have no plans to fix.
It's a lens that I am quite interested in but really don't want to buy and then have to return so I am trying to figure out what the truth about the lens is. Hard to know what to think about all this.
I believe I can get around the OIS problem by using the IBIS in the Olympus and turning off the Panasonic OIS -- so that one can be gotten around.
But the shutter shock problem is one I am concerned about.
Cathy H.
 cathyph1's gear list:cathyph1's gear list
Sony RX100 VII Panasonic Lumix DC-G9 Sony a6400 Nikon Z50 Olympus OM-D E-M10 IV +26 more
Olympus OM-D E-M10 Panasonic Lumix G 14mm F2.5 II ASPH
flacko_man Regular Member • Posts: 487
Re: What's the truth about the Panasonic 14-140II?
I've had mine about 6 months and use it on both Oly and Panny bodies. Never noticed and shutter shock and the OIS seems to work OK on my GM1, though I haven't used it in many if any low light situations. I use IBIS on my Oly bodies. Great little lens and I use it more than I thought I would.
Cheers
f_m
 flacko_man's gear list:flacko_man's gear list
Olympus OM-D E-M5 Olympus E-M1 Panasonic Lumix DC-G9 Fujifilm X-T3 Canon EOS RP +1 more
robonrome
robonrome Senior Member • Posts: 2,334
It's a flawed gem. The best and most consistently sharp superzoom ive ever used.
It has reported OIS problem but only an issue for video.
It does exhibit the worst shutter shock of any lens ive used. Its not subtle and is easy to see with a panny body simply by taking a pair of shots one with e shutter and one without. At any focal length longer than say 35mm and shutter speed between 1/25th and 1/250th its obvious.
But if you dont care about video and dont mind using the e shutter at offending speeds (guess that wont help oly user) then its great.
 robonrome's gear list:robonrome's gear list
Olympus E-M1 II Sony a7R III Olympus M.Zuiko Digital ED 60mm F2.8 Macro Olympus M.Zuiko Digital ED 75mm F1.8 Sony FE 35mm F2.8 +10 more
OP cathyph1 Regular Member • Posts: 362
Thanks much to both of you for replying.  Both are very helpful.  Cathy H.
Pedagydusz Veteran Member • Posts: 6,027
cathyph1 wrote:
[...] And someone else says it has terrible problems with its image stabilization (OIS) that Panasonic has acknowledged but seems to have no plans to fix.
That is only for movies, though. I never saw any complains on the OIS for stills.
I don't own the EM-10 or the 14-140 II, but I never saw any shutter shock problem that was not resolved by the 0 Delay strategy.
 Pedagydusz's gear list:Pedagydusz's gear list
Sony Cyber-shot DSC-F707 Canon EOS 7D Panasonic Lumix DMC-GX7 Olympus E-M1 Panasonic Lumix DMC-GX8 +3 more
SkiHound Veteran Member • Posts: 3,939
Wonder about sample to sample variation?
Don't have the lens but have looked at it and have been left with many of the same questions as the OP. I wonder if there's a lot of sample to sample variation with this lens? I've always sensed that to be the case with the Oly 12-50.
Pesitalia Forum Member • Posts: 93
I would consider also the Tamron 14-150 f 3.5-5.6
I have just purchased the above superzoom as a travel kit for my OMD EM-1 . It is very compact, well built and, for what I can see, also sharp at both ends. Last but not least, it costs less than the Panasonic zoom.
Carlo
AdamT
AdamT Forum Pro • Posts: 62,285
My Praise of this lens is because the optics are beyond any other superzoom regardless of mount by quite a margin and even beats the Pan 45-150 at the 45 end ! whilst matching it at the long end for across the frame sharpness and beating it for close focussing and microcontrast  -------
the Shutter shock thing is a different matter entirely , I use Electronic shutter on the GX7 so hadn`t seen it, on the mech shutter the shock is there , worse than any other lens I `ve used on it so stick with the E-Shutter  .. Panny need to fox this and the Video Jitters ASAP .
As for the Olys with 0-sec shock still getting it - I find this hard to believe IF it really is electronic first curtain .. I can`t see how it can happen unless Oly`s EFC really is a bodge and not true EFC at all ...
there`s no shock on the GM1 regardless of shutter type but then the Stepper shutter is so gentle I doubt it`d shock anyway
Canon PowerShot SX50 HS Nikon D3 Panasonic Lumix DMC-GH3 Nikon Z7 Nikon Z9
Bobby J Veteran Member • Posts: 5,191
Cathy, since you don't yet have this lens have you considered the Oly 14x150?  I have one and it's proven to be a good lens and extremely versitile.  My son recently switched from Nikon to an EM-10 and he bought the 14x150 when he got the body.  He had been using a Nikon D-90 and their version of the 14x150 equivilent lens.  I think it's an 18x200.  Anyway he's had plenty of time to evaluate his new camera and lens and he says he can see little if any difference between images made with either lens.  He really likes the new Oly set-up and loves it's light weight and convenience.
I've been pleasantly surprised by my 14x150.  I've read some less than flattering reviews of it and was not expecting much.  It has proven to be much better than I expected.  I would not hesitate to make reasonably large prints from it.  I think it could print 20x24 images that would look good.
Might be some sample variations, and perhaps I just happened to get a good copy, but that's likely true of any lens.
BJM
 Bobby J's gear list:Bobby J's gear list
Olympus M.Zuiko Digital 45mm F1.8 Panasonic Lumix G 25mm F1.7 ASPH Olympus 12-100mm F4.0 Olympus E-M1 Olympus E-M1 II +9 more
dweller88 Forum Member • Posts: 95
Okay this is my first post here, long time lurker.
Anyhow, I got the 14-140 ii in a deal with G6 last year. At first I got shuttershock with all my m43 cameras and was disappointed for sure.
Now I will only use it on my em5 with 1/8th antishock switched on - I also set it to f5.6 usually for optimum sharpness. With those things set up it is a great lens, I just wish em5 had 0sec antishock.
Yes I can use it on the G6 in electronic shutter mode but I find the e-shutter is at too high risk of jello effect especially once zoomed in a bit.
Hopefully future Panasonic bodies will help to sort out this problem or perhaps a firmware for the lens.
Good luck in your buying decision.
Bobby -- Thanks for the suggestion.  I will give the Olympus a good look.  Cathy
Cathy, regardles of which lens you buy, you might want to be patient and watch for it be on sale.  When I bought mine, Oly had it on sale for 100.00 off list price.  My son bought his when he purchased his M-10 and saved 200.00 so it might pay to be patient.  However if you need it, you need it, I understand.
BJM
JohnLock Senior Member • Posts: 1,524
I'll stand by my (several) comments about the Panasonic 14-140 II as reported in several threads.  However, both the Oly 14-150 and Tamron 14-150 do not have this problem on either my EM10s or EM1-- all set to zero second in menu.  I will say that the photos that I did get from the Pana 14-140 II  that were sharp were very sharp for a 10X zoom lens-- e.g. those at high SS.  Personally I've settled on the Tamron 14-150 in this class of zoom-- nicely made and good optically, but the Oly is just as good optically and can be had used for a good price from KEH, Cameta etc.
JL
 JohnLock's gear list:JohnLock's gear list
Panasonic Lumix G X Vario PZ 45-175mm F4.0-5.6 ASPH OIS
bs1946
bs1946 Veteran Member • Posts: 7,780
You could also consider the Tamron 14-150mm. Tamron has been making superzooms for a long time.
Bill S.
Digital film is cheap; shoot fast and shoot often!!!
 bs1946's gear list:bs1946's gear list
Panasonic Lumix DC-GX9 Panasonic 20mm F1.7 II Panasonic Lumix G 14mm F2.5 II ASPH Panasonic 12-60mm F3.5-5.6 OIS Apple iPhone 12 Pro Max
arbuz Senior Member • Posts: 2,247
All tests, samples and opinions on this forum I've seen contradict what you stated here. Maybe you an support your claim with some proof?
Obviously, sinc eits 10x superzoom like Panasonic, just not versatile enough on panasoni bodies beause of absence of OIS. I'm not sure you have used word 'extremly' in a propor way here.
BJM
 arbuz's gear list:arbuz's gear list
Nikon D600 Samsung NX300 Panasonic Lumix DMC-G6 Samsung NX30 Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS +14 more
Henry Richardson Forum Pro • Posts: 21,959
Olympus 14-150mm
Since you have an E-M10 with IBIS you might also consider the Olympus 14-150mm. I have it and like it. Here is a review:
http://www.ephotozine.com/article/olympus-m-zuiko-digital-ed-14-150mm-f-4-5-6-lens-review-22983
Also a review of the Panasonic 14-140mm II:
http://www.ephotozine.com/article/panasonic-lumix-g-vario-14-140mm-f-3-5-5-6-lens-review-22632
Henry Richardson
http://www.bakubo.com
rlumpy Regular Member • Posts: 169
Warning: tecnobabble ahead
Here's a thought I had about these two problems, shutter shock and video OIS vibration issues: are they related? I know that electronic servo control loops, which this lens probably employs, can be underdamped to provide fast response, with the unfortunate side effect of some ringing in the loop. Is this happening here? This may be an unfixable problem short of redesigning or modifying the circuitry involved. Or, they may be taking manufacturing shortcuts, omitting servo tuning operations that get around parts tolerances.
A good but highly technical explanation of these issues is
http://www.compumotor.com/catalog/cataloga/a36-a38.pdf
 rlumpy's gear list:rlumpy's gear list
Fujifilm FinePix S6000fd Sony Cyber-shot DSC-HX100V Panasonic G85 Panasonic Lumix G Vario 45-150mm F4-5.6 ASPH Mega OIS Panasonic Lumix G 25mm F1.7 ASPH +6 more
Aberaeron Forum Pro • Posts: 10,184
Re: Wonder about sample to sample variation?
I have two, built six months apart. Yes, there can be a slight shutter shock issue under certain conditions if you pixel-peep. It is not an issue for me, or I instinctively avoid it by various means, including the use of electronic shutter on the G6 where appropriate.
I have no issue at all with video. Took another short one today, with the old days art filter, handheld and in difficult light. Left the full horizontal and vertical stabilization on, MP4 highest quality and no problem whatsoever. Not when zooming and not when panning. Not at all.
Both copies behave identically. No noise issues either. They have a quiet humm if you really listen in a very quiet place but it is never heard on a video. Focusing is totally quiet.
These are by far my most used lenses. I do have several others to choose from.
assaft
assaft Senior Member • Posts: 1,483
In this case I'd recommend you to do some careful testing by yourself, with your own copy of the camera and a copy of the lens. Either at a local shop before you buy, or if you order from a place that accepts returns in 14 days.
 assaft's gear list:assaft's gear list
Olympus PEN E-PL2 Olympus OM-D E-M10 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Panasonic Lumix G 20mm F1.7 ASPH Panasonic Lumix G 14mm F2.5 ASPH +6 more
Len_Gee
Len_Gee Veteran Member • Posts: 9,880
Hello,
Just curious why do you have two of the same lens?
Are you using both at the same time to shoot stereo pics?
Wouldn't it make more sense to have spent the money on one professional quality lens?
BTW: Do you have any pics to post here showing side by side comparisons of identical IQ of both lenses?
Lena
 Len_Gee's gear list:Len_Gee's gear list
Olympus PEN-F Olympus OM-D E-M10 IV Olympus M.Zuiko Digital 45mm F1.8 Samyang 7.5mm F3.5 Fisheye Olympus M.Zuiko Digital 17mm F1.8 +4 more
