Panasonic 20mm 1.7 vs Panasonic 14-42 ii
Started Nov 9, 2014 | Discussions
tald1 New Member • Posts: 4
Hi, My name is Tal and i am new to this forum and this is
my first writing here. (but i read a lot...).
A months ago i bought EPL5 to replace my EPL2 . After a shot session with the
new camera i was very disappointed. the photo looks just bad like something is
wrong about them. The photos from my epl2 looks much better. Since i saw many
great photos before i bought the camera i started searching what is the problem.
The lens on my EPL2 was Olympus 14-42 ii and with the EPL5 Olympus
14-42 ii r. After some reading i understand the the r version is not so good
and i bought Panasonic 14-42 ii ,that i found for 100$, and that make me
very happy with great photos. (maybe i got a bad copy of the oly 14-42 ii r).
Now i am thinking of buying the first version of the Panasonic 20mm 1.7 that
i can get for 260$ but i can not find any comparison between it and
the Panasonic 14-42 ii. will the photos from it will be much
better from the Panasonic 14-42 ii ?
Thanks.
Olympus PEN E-PL2 Olympus PEN E-PL5
Fredrik Glckner Veteran Member • Posts: 3,894
Re: Panasonic 20mm 1.7 vs Panasonic 14-42 ii
tald1 wrote:
Now i am thinking of buying the first version of the Panasonic 20mm 1.7 that i can get for 260$ but i can not find any comparison between it and the Panasonic 14-42 ii. will the photos from it will be much better from the Panasonic 14-42 ii ?
These are very different lenses, and it makes little sense to compare them.
The Lumix 20mm f/1.7 is a fine lens. People generally like it for the good image quality, and the sharpness it shows even wide open. Here are some tests:
http://m43photo.blogspot.com/2011/01/comparison-lumix-14mm-vs-lumix-20mm.html
kitsap2
kitsap2 Senior Member • Posts: 1,375
First, $260 for the 20mm f1.7, is a good price if the lens is in good condition.
Second, as already stated, there is no comparison between the 14-42mm zoom, and the fixed lens, 20mm f1.7.
The 20mm is going to produce some very nice, sharp images, with nice background blur at its wider apertures.  It's a lot of fun to shoot with, but autofocus is problematic in low light, low contrast environments.  I have this lens and will keep it as long as I have my µ43's system.
Get this lens, it's perfect for the E-PL5!
Tom
 kitsap2's gear list:kitsap2's gear list
Olympus E-M5 II Panasonic Lumix DMC-LX3 Ricoh GR II Panasonic Lumix DMC-GX85
OP tald1 New Member • Posts: 4
Thanks for the reply. I know that these are very different lenses. what i wish
to know is what is the different in term or sharpness and clarity ?
PSCL1 Veteran Member • Posts: 3,770
Welcome to DP Review and to this Forum.  If you don't take too many of us too seriously, this is a great website.:-D
I own both the 14-42 first version Oly and the Panasonic 20 f1.7, first version, used mostly on an EPL-1.  IMO the 20 is one of the great lenses of all time, right up there with Leica 35 and 50 Summicrons.  Given their recent close collaboration for m43 lenses, it would not surprise me to learn that Leica had a hand in designing the 20; the images have that 3-D natural Leica 'look.'  The main complaint about the 20 is slow AF in low light.  While that is to some extent true, it is no reason to avoid this outstanding optic.
 PSCL1's gear list:PSCL1's gear list
Leica X1 Nikon D80 Olympus PEN E-PL1 Panasonic Lumix DMC-G3 Sony Alpha NEX-3N +27 more
RaymondR
RaymondR Senior Member • Posts: 2,496
the other posters are right, it is hard to compare the 20 with the kit zoom.  but I can say that i had both (used on an E-Pl2) and for me the 20 outperformed the kit (at 20mm) consistently in sharpness at any aperture and in most lighting situations.  Plus it gave the advantage of the faster aperture.  Once I paired the 20 with the Oly 45, the kit zoom went into storage and never got used again -- ended up selling it with the E-Pl2 when I got the E-M10 (body only).
RaymondR
 RaymondR's gear list:RaymondR's gear list
Sony a7 II Sony a7C Sony FE 24-105mm F4 Sigma 70mm F2.8 DG Macro Art Tamron 17-28mm F2.8 Di III RXD +2 more
markintosh13
markintosh13 Veteran Member • Posts: 4,951
There are two issues with the 20mm 1.7 that have caused me to all but abandon it.
1. The AF speed is something I have never been happy with.
2. The banding issue when used with a PL5.
Ever since buying the Oly 25mm 1.8, I have not used the 20mm 1.7
SammyToronto Regular Member • Posts: 148
I second that opinion. The 20mm is a great lens in terms of sharpness and contrast at any aperture, but the Oly 25mm 1.8 is just as great in those aspects, but with a noticeably faster focusing mechanism (and no banding issues with the epl5). Both lenses are in the same price range and the Oly is only slightly bigger, so it's the one I'd recommend to get, if that's an option for the OP.
I sold my 20mm after getting the Oly 25mm.
 SammyToronto's gear list:SammyToronto's gear list
Olympus PEN E-PL1 Olympus PEN E-PM1 Olympus PEN E-PL5 Fujifilm X-A1 Tamron SP AF 17-50mm F/2.8 XR Di II LD Aspherical (IF) +5 more
Ontario Gone
Ontario Gone Veteran Member • Posts: 4,183
If you are comparing the 20mm as a walk around vs the 14-42 at any FL, the 20 will be far sharper and faster as well, for when you need more light. I have owned both, have photos from both, and the 20mm wipes the floor with the zoom. The 14-42 isn't bad, it's ok for a kit lens, but the 20mm is exceptional even for a prime. Here is a wide open shot with the 20, and another at F4 for peak sharpness.
Both shots were cropped on the sides, pixel level detail is otherwise untouched, ie no downsampling.
"Run to the light, Carol Anne. Run as fast as you can!"
 Ontario Gone's gear list:Ontario Gone's gear list
Nikon D7000 Canon EOS 70D Nikon AF-S DX Nikkor 35mm F1.8G Nikon AF-S Nikkor 50mm F1.8G Canon EF 40mm f/2.8 STM
mh2000 Senior Member • Posts: 2,813
huh? why hard to compare???
When you want any FL other than 20mm the zoom will excel! When you want a fast aperture at 20mm the 20/1.7 will excel.
At 20mm and f5.6, both lenses will produce good photos, but when you zoom in to 100% you will notice that the 20 is a little sharper.
If you really want a faster aperture, the 20 will be one good option. FWIW, I love the Oly 25 & 45. If I were to get another fast prime, it would be the Oly 17, but that is based on FL and feature set. Others love the 20mm FL.
Yannis1976
Yannis1976 Veteran Member • Posts: 6,309
I don't have the 14-42 but have the 14-140 mk2. Recently I also got the 20mm/1.7 and have almost forgot the other lens. When I was reading here from much more experienced users that "it's all about the glass" I couldn't understand what they mean until I used the 20mm/1.7...
http://www.dpreview.com/forums/post/54707072
http://www.dpreview.com/forums/post/54685441
 Yannis1976's gear list:Yannis1976's gear list
Fujifilm XF 35mm F1.4 R Fujifilm XF 70-300 F4-5.6 R LM OIS WR
assaft
assaft Senior Member • Posts: 1,483
The short answer is yes - the 20/1.7 is expected to be sharper at any comparable aperture. However, once you stop down the zoom lens, the difference is expected to be minor (assuming that both are good copies). The P 14-42 ii has received some very good reviews and it looks like a good zoom. The main reason to add the 20/1.7 is its wider aperture - f1.7. This will allow you to lower the ISO in low light situations and to get more subject isolation. Carrying a good zoom and 1-2 fast primes is a good idea in general.
Thanks.
 assaft's gear list:assaft's gear list
Olympus PEN E-PL2 Olympus OM-D E-M10 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Panasonic Lumix G 20mm F1.7 ASPH Panasonic Lumix G 14mm F2.5 ASPH +6 more
Prairie Pal Senior Member • Posts: 2,912
I'll take my Panny 20 to my grave
Even if I were to abandon M4/3 for another format I will always keep my Panny 20 mounted to a M4/3 body.  I basically got into M4/3 because of the 20 f1.7, and I look for excuses to use it.
Avoid the kit lens 12-50 if you are looking for acute sharpness. The 12-50 practically oozes chromatic aberration, and that's bad news for a landscape photographer.  After you fix it in post you're left with blurred unsaturated edges. (critically speaking of course). I can't even give my 12-50 away for $150 (Canadian)
Ivan
 Prairie Pal's gear list:Prairie Pal's gear list
Nikon D600 Nikon D7200 Olympus OM-D E-M10 II Olympus E-M1 III Nikon AF-S Nikkor 70-200mm f/2.8G ED VR II +6 more
Joseph T Lewis III Veteran Member • Posts: 3,594
Outdoors in bright sunlight at say f/5.6, you won't see as much difference. The 20mm really comes into its own when used indoors with no flash. See samples that follow.
f/1.7, ISO 200, 1/50th sec
f/1.8, ISO 320, 1/50th sec
f/1.7, ISO 800, 1/50th sec
f/1.7, ISO 500, 1/60th sec
Tom
 Joseph T Lewis III's gear list:Joseph T Lewis III's gear list
Canon PowerShot G7 X Olympus E-M1 Olympus PEN-F Panasonic Lumix DC-G9 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 +6 more
Michael J Davis
Michael J Davis Veteran Member • Posts: 3,755
I have the older and better zoom (14-45) and I have the original 20mm f1.7 from the day it became available. The 20mm lens is sharp and contrasty, even at full aperture. I have many prints at 19"x 13" (47x 32cm) which are fine. One judge thought that one print at full aperture "must be from a full frame camera"!
People complain that it is slow to focus, but it's just a bit slower than the latest lenses.
Highly recommended.
Mike
Mike Davis
Photographing the public for over 50 years
www.flickr.com/photos/watchman
 Michael J Davis's gear list:Michael J Davis's gear list
Panasonic Lumix DMC-G1 Olympus OM-D E-M5 Panasonic Lumix DMC-GX85 Panasonic Lumix DC-G9 Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS +6 more
The 20 is kinda over-rated IMO
It's a really good lens, not saying it isn't, but it isn't as out-of-this-world-spectacular as some like to claim.
Yes, at 100% it's better than my 17/2.8, but on a print it's not that much better. Can't say in a general sense that it's *better* than my Oly 25 or 45... don't even know whether it's even that much better than the Sigma 30.
My girlfreind loves the FL and it's her most used lens. I much much much prefer a 25mm FL.
Buy a prime because it has a really great FL for *you*.
I bought the Oly 17/2.8 over the 20 and for me it was a way better choice.
Re: The 20 is kinda over-rated IMO
In terms of FL the 20 is too wide for my preferred al'rounder walking lens/ landscape lens.  I often find myself resorting to panoramics using 3 or 4 images to achieve what a 14 or 17mm lens would otherwise see.  On paper (review sites with measurements), I see the 20 dominating the 17 f2.8 in measurements and conclusions rating IQ, price, and mechanical.  I guess I just found my joy spot with the 20, and I keep marveling about it.  Give me the same or better IQ in a 30mm equivalent focal length pancake and I might consider trading my 20.
Ivan
Highly recommended.
Mike
The images on your flickr gallery are brilliant and rich.  I appreciate your work with the 12-40.  I haven't seen any of your images yet with the 20mm in the exif, but I'm still looking
Ivan
When a 17/2.8 costs half the price of the 20, I think it's more difficult to put one above the other when you include price... the little 17/2.8 is a "cheap" lens while the 20 isn't. I also like the smaller size etc. as well as the wider FL (I have the 14 as well, but it ends up being too wide for most of what I shoot... and not that "superb" either... maybe it's just my training with traditional 35mm lenses, but 17 is a perfect FL for "moderately wide" and my shooting).
When I said the 20 is "over-rated," I didn't mean to say anything bad about the lens, just that I don't see it as the "better than anything ever made" type of lens.
My girlfriend shoots a 20 almost exclusively so I have lots of direct experience with the images it produces. Yes, it's better than the 17/2.8 (and faster!), but I still ove my little 17 to keep in my pocket. On the other hand, it's hard to say which is better, her 20 or my 25/1.8 (though I love my 25!).
I guess my real point was not to get a 20 just because it's the "best thing ever," but get it because it's a good lens in a FL that you love.
Nicholas Johnson Regular Member • Posts: 387
Oly 17/1.8
I would strongly suggest the Olympus 17mm f/1.8 rather than the Panasonic 20mm f/1.7. Using the original version of the 20mm (there is a version 2 available now) I found the AF to be much slower than the Panasonic kit zoom and everything else I used on my Panasonic GF1. I recently got the Olympus 17/1.8 and it is basically permanently mounted on my E-PM2. I find the focal length perfect almost always. Probably because I've been shooting at 20mm for years. But its slightly wider FOV lets me do that one handed pic with the wife whenever we go somewhere new and interesting. Of all the photos I take in town or on vacation the ones we cherish most are of us and the area around us. Taken with the outstretched arm.
