Re: DP2 Quattro to SD card write speed
I think it writes at standard UHS-1 speeds, which translates to about 50 megabytes per second, depending on file sizes and memory card architecture, etc. Some UHS-1 specification cards claim to be capable of faster write speeds, but very few devices actually support writing faster than the spec. This is one reason it makes sense to use CF cards still. There are devices that write at UDMA 7 speeds, which are up to more than 100 megabytes per second. I'm hoping the new DSLR from Sigma will be like this. It really needs to be, because it will surely have a very big buffer. No doubt the processing speed will be the bottleneck, but faster memory card write speeds would be very nice. As it is now, the 8 second maximum write times in the DP Quattro cameras really is not significantly limited by the memory card write speeds (even if the memory card write speed was twice as fast the write times would only be reduced by about a second, from 8 seconds to 7 seconds), so maybe Sigma will just put a UHS-1 SD card slot in the new DSLR. I'm hoping for faster processing and a faster memory card slot, but I guess we just have to wait and see.
I suggest this card (looks like a great value):
http://www.bhphotovideo.com/c/product/855703-REG/delkin_devices_ddmicrosdpro2_16gb_16gb_microsd_pro_sdhc.html
This looks good too:
http://www.bhphotovideo.com/c/product/1031504-REG/lexar_lsdmi16gbsbna633r_16gb_micro_sdhc_card.html
Here's a good memory card case:
http://www.bhphotovideo.com/c/product/828755-REG/Pelican_0910_015_110_0915_Memory_Card_Case.html
I stay away from Kingston, Transcend, and PNY cards, because I've had bad experiences with them (speed, compatibility, and/or reliability problems). I have found Lexar to be the best and most reliable cards I've used, and this is reported by a friend of mine too, but those Delkin cards have a great reputation for speed and reliability. They cut their teeth in the pro market. Memory cards, as you might already know, are pretty hit and miss. I got some 2 GB microSD cards made by HP really cheap at a Best Buy or CompUSA (can't remember which store) many years ago, and they worked great until I put them in my new Nikon D5000, which burned up two of them, but not all of them. These days the maximum size card I will put in a camera is 16 GB, but I wouldn't be averse to using a 32 GB card in a Quattro camera, just because the file sizes are so big that the number of files is not as great as it might be otherwise. I don't think I would get a 64 GB card yet. The value and reliability are probably not at the sweet spot yet. If I were shooting 4K video I might get a couple of those though. I have found memory cards to be quite reliable, never actually losing any photos, even though I have had mishaps (one 4 GB SD card was chewed up by my sister's dog, three or four microSD cards were burned up by cameras, I lost one card, a couple microSD cards stopped working properly over time, and the memory card reader in a model's Dell computer screwed up one SD card - I have had issues with a couple of CF cards too).
(I don't have a Quattro, so I can't tell you what card works best with them.)
Good luck!
