LX-100 Maximum flash sync speed? Wide angle converter?
Started Nov 3, 2014 | Discussions
WACONimages Junior Member • Posts: 49
Does anyone know what the max flash sync speed is? Is it possible to use fill-in flash at high speeds?
Other question. I loved to use my now old LX-3 + the wide angle converter. Since the LX-100 at 24mm is f1.7 it would be great to be able to add a 0,8 or 0,7 wide angle converter. Can a adapter ring added?
Thanks!
Ronald
 WACONimages's gear list:WACONimages's gear list
Nikon Coolpix A Olympus Tough TG-4 Olympus OM-D E-M5 Olympus E-M1 Panasonic Lumix DMC-GX8 +11 more
Richard Butler
Richard Butler dpreview Admin • Posts: 2,782
Re: LX-100 Maximum flash sync speed? Wide angle converter?
I've just tried and the LX100 can light the full image all the way up to the maximum speed of the mechanical shutter (1/4000th).
I don't know about adaptor lenses yet, though.
Richard - dpreview.com
OP WACONimages Junior Member • Posts: 49
Thanks a lot Richard for your quick answer and trying the camera.
Ronald
BorisK1 Veteran Member • Posts: 5,645
That's quite a feat!
How far did you have to close the aperture to enable 1/4000 sync?
 BorisK1's gear list:BorisK1's gear list
Olympus Tough TG-4 Olympus E-3 Olympus Zuiko Digital ED 50mm 1:2.0 Macro Olympus Zuiko Digital ED 40-150mm 1:4.0-5.6 Olympus Zuiko Digital 11-22mm 1:2.8-3.5
Dimitris Chorianopoulos New Member • Posts: 1
Have you checked the sync speed with an external flash, or just the built in one?
