GM1: first impressions, and a quick question!
Started Oct 30, 2014 | Discussions
Alex Notpro
Alex Notpro Senior Member • Posts: 1,013
Got my GM1 "direct from Korea". First impression: thought I had been scammed... looked like a fake piece of plastic, too small and light to be a real camera? E-PM2 now seems like an overweight brick, even though the difference in spec is barely over 2 ounces (64 grams). Anyway, battery charged, it powers up, so I guess it's a real camera
The question... in A-mode, I somehow became stuck in Exposure Compensation mode, so that the dial controls EC rather than aperture. How do I get out of it? Tried every button and dial, nothing works.
 Alex Notpro's gear list:Alex Notpro's gear list
Sony FE 35mm F1.4 Sony a5100 Sony a7 II Sony E 16mm F2.8 Pancake Sony E 10-18mm F4 OSS +7 more
Olympus PEN E-PM2 Panasonic Lumix DMC-GM1
Mike Ronesia
Mike Ronesia Veteran Member • Posts: 3,043
Re: GM1: first impressions, and a quick question!
Press the +/- on the rear wheel to toggle between exp comp and A or S depending on the mode you're in. When in Manual mode this will also toggle between S and A for you to change your settings.
Mark James
A.K.A. Mike Ronesia
 Mike Ronesia's gear list:Mike Ronesia's gear list
Panasonic Lumix DMC-GH2 Panasonic Lumix DMC-GM1 Panasonic Lumix DMC-GH4 Panasonic Lumix DMC-GX8 Sigma sd Quattro +13 more
alcelc
alcelc Forum Pro • Posts: 19,005
Just expand a little on Mark's comment, press the +/- position of the rear wheel would switching between 1) EC and; 2) f/stop (in A mode), or Shutter speed  (in S mode) or Program shift (in P mode).
A general rule for all Panny's small bodies without an individual clickable rear wheel.
Alex Notpro
OP Alex Notpro Senior Member • Posts: 1,013
solved
When a lens that has an aperture ring is mounted, the aperture cannot be changed in the camera unless the lens aperture ring is set to "A".
AdamT
AdamT Forum Pro • Posts: 62,285
It`s funny, I thought the GM1 was made of plastic when first got one, someone had to point me to the review top prove otherwise ....... I`ve seen many cams which try to make plastic look and feel like metal (the Fuji XM1 for one) but the GM1 was the first full Mag alloy body which looked and felt like 100% genuine bonafide plastic
Canon PowerShot SX50 HS Nikon D3 Panasonic Lumix DMC-GH3 Nikon Z7 Nikon Z9
Kim Letkeman
Kim Letkeman Forum Pro • Posts: 33,444
rubberized is not the same as "plastic"
The GM1 has a rubberized body, which is tacky and makes for a decent grip for a camera with no attempt at a grip of any kind. I added the Franiec grip and the camera is now perfect.
The only Panasonic that ever struck me as pure plastic was the G6, and to a lesser extent the GH2. These two shocked me a bit at first, but I got used to it. Interestingly, the G5 had a gorgeous body and although the shell was plastic, it never felt like "plastiky."
I've read that Panasonic put a magnesium shell inside the G5, but not inside the G6. Not sure what the truth is, but the G6 is in my opinion still the best body to hold in their current consumer m4/3 line, despite the lack of luxurious materials.
 Kim Letkeman's gear list:Kim Letkeman's gear list
Nikon Coolpix 990 Fujifilm FinePix F770EXR Nikon D600 Nikon D7200 Panasonic Lumix DMC-G7 +27 more
LMNCT Veteran Member • Posts: 4,908
Re: rubberized is not the same as "plastic"
I love the term 'plasticy' because it reminds me that one of the objectives of M4/3 is to keep the weight down.  With the 'space age' plastics that are used today I do not worry when the body feels plasticy but do have some concern when the body is too metally.
 LMNCT's gear list:LMNCT's gear list
Panasonic LX100 Panasonic Lumix DMC-GX7 Panasonic Lumix DMC-GM1 Panasonic Lumix DMC-GM5 Panasonic Lumix DMC-GX8 +23 more
Fredrik Glckner Veteran Member • Posts: 3,894
Most pre-GH3 cameras from Panasonic have a steel frame inside, and a plastic body over it. I think that is a sensible way to construct small system cameras.
The GH3 and GH4 feel more "solid", but I'm not sure it makes any real life difference.
http://m43photo.blogspot.com
AdamT
The GM1 ain't rubberized Kim
Mine definitely is not rubberized , to does have a leatherette cover on the front like old film cameras and leicas - the back of the LF1 is rubberized, most of the G1 and G2 also but the GM1 has that hard (anodized ?) textured finish similar to some Pro DSLRs, the texture is similar to some plastic bodied cameras .. a lot of these kind of cams have plastic backs (the NEX series and canon G series for a start) and I thought the GM1 had also when it arrived
Mike Ronesia
Re: solved
Good catch. I don't have a manual aperture lens.
Mark James
A.K.A. Mike Ronesia
