SX50 Sunset: what setting do I need to.....
Started Oct 29, 2014 | Discussions
Le T Regular Member • Posts: 253
.....make the church, tree to be like a silhouette while still keep the sky color and background highlight straight out from the camera?
I know it can be done in PP with PS or other software. However I'd like to know if any camera setting that can be done to reduce much PP later.
Thanks in advance
Le
 Le T's gear list:Le T's gear list
Canon PowerShot SX50 HS
MarioV Veteran Member • Posts: 7,074
Re: SX50 Sunset: what setting do I need to.....
Beautiful sunset colours.
Use spot metering on the sky. You have it on Evaluative (whole of scene metering).
 MarioV's gear list:MarioV's gear list
Nikon Coolpix P900 Canon G3 X Panasonic ZS100 Nikon D5200 Canon EOS M100 +4 more
OP Le T Regular Member • Posts: 253
Mario,
Thank you for pointing that out. I tried it next time.
GeraldW Veteran Member • Posts: 8,864
To enhance sunsets, I set exposure compensation to -1/3, and then set White Balance to Cloudy.  That gives richer colors and enhances the reds and yellows.  It also works very well for fall colors in the trees.
Jerry
 GeraldW's gear list:GeraldW's gear list
Canon PowerShot S95 Canon PowerShot G15 Panasonic Lumix DMC-FZ300 Canon G7 X II Canon EOS M5 +1 more
Thank you very much for the tips, Jerry. I'll keep that in mind.
Frizzen Regular Member • Posts: 198
On mine I use TV mode and set shutter speed to 500 and use ISO on Auto on sunsets and sunrise.
When it gets brighter I will re-set ISO down to 100.
Thank you, Frizzen. I'll try your setting sometime. I haven't shot much in Tv mode as I still learning and struggle to find the correct exposure.
Le
Augustin Man
Augustin Man Forum Pro • Posts: 11,322
Both images quite impressive, but I like more the second !
Congratulations,
Augustin
 Augustin Man's gear list:Augustin Man's gear list
Nikon Coolpix P1000
Augustin Man
I think it an excellent image, as composition and colors! So you're a skillful photographer not only with our Solar System
Congratulations,
Augustin
Nikon Coolpix P1000
Thank you, Augustin. So far I have more "delete" pictures than "keeper" but I'm having fun with the SX50. I've learned a lot from you guys/gals here.
