D800 with KitKat- Issue There is no MTP device connected.
Started Oct 28, 2014 | Discussions
Michel Sauvage New Member • Posts: 4
Hi
First I am french so sorry for english ...
I tried to copy files from my D800 to my Samsumg Tab (Kitkat) and the Tab issued the following messahe --> There is no MTP device connected. I used a OTG cable that works with USB key.
Strange because i verified that my nikon support this protocole here
Have you some clues?
Who have connected D800 with KitKat? and how?
regards
Michel from Toulouse, somewhere in France!
Nikon D800 Samsung Tab S 10.5
(unknown member) Senior Member • Posts: 2,071
Re: D800 with KitKat- Issue There is no MTP device connected.
I have a Samsung Note 10.1 2014 edition with Kit Kat. I use OTG to USB on a D7000 which is USB 2.0. I think the D800 has USB 3.0, I wonder if this might be the problem. I am sorry that I do not have access to a D800 to test it.
OP Michel Sauvage New Member • Posts: 4
good idea i will try to find an USB 3 OTG
Thank
Michel
Willy79
Willy79 Veteran Member • Posts: 9,806
External SD
I have a Samsung Tab S with "Photo Mate R2" loaded.  I import  RAW files to my Tab S from my Sony A99 (USB OTG).  I import the RAW files to the External SD, 64GB  (/DCIM).  In the Tab file manager I can move the RAW or converted jpg files between the Internal memory and External SD (just can save the edited file to External SD).  I will note if I edit a photo file that is located on my External SDI have to save it to my Internal memory (can not save the edited image to the External SD).
I also Have all my maps for Mapfactor GPS Navigator saved to my External SD.
A99, A900, A55, A700, R1, w/Zeiss + Sony G Glass, Samsung Galaxy Note III, PS CS6
My Picasa Albums: https://plus.google.com/u/0/photos/109849611643818398019/albums My YouTube: http://www.youtube.com/TheWillybug
 Willy79's gear list:Willy79's gear list
Sony a6500 Sony a7C
Re: External SD
Hi
Sorry for the late i was off ...
Nevertheless i tried with an OTB USB 3.0 this type of cable (here ). This time is worst, no message nothing happens on the Tab !
I tried also to change the type of card inside the D800, no effect.
@William, thank you for your reply, but i am looking for a simple solution with cable to copy files from my d800 to my tab.
Thank you, i continue to test ...
Regards
Willy79
Michel Sauvage: Camera Is Set To Mass Storage - External SD
I am not sure if we are on the same page or not but if we are here is what I do:
Important: For transferring files Camera Is Set To "Mass Storage" not "MTP".
1) Connect OTG cable to Tab S and USB to camera.
2) Turn camera on.
3) File manager on Tab S opens.
4) I Navigate to USBDrive A > DCIM > 100SDCF (my RAW files are here).
5) Click on RAW files in 100SDCF (press on file for a selection box and check for each file).
6) After the files have been selected, click on icon at the top to "Paste Here".
7) I then navigate to SD Card > DCIM > Camera and then click above on “Paste Here”.
8) The files are then Pasted to SD Card > DCIM > Camera.
Hope this helps.
Michel Sauvage wrote:
Hi
Regards
Sony a6500 Sony a7C
Re: Michel Sauvage: Camera Is Set To Mass Storage - External SD
First thank you very much for your detailed post and you right it is what i aim.
I block in the first step, where i have to define masse storage. I didn't find this parameter into my tab either into D800.
I found some posts on this topic and it seems that is related to the new version of android 4.4.2, what is your version on your tab?
Regards
Michel
