Solid performer
Started Oct 20, 2014 | User reviews
LightCatcherLT Forum Member • Posts: 66
Solid performer
6
Here comes my subjective impressions after spending weekend with Olympus M.Zuiko Digital ED 40-150mm F2.8 Pro on OMD E-M1, firmware v1.3, lens firmware 1.0.
  • very sharp across range, gets little mild at wide end and long tele end;
  • beautiful bokeh;
  • prone to flares, with clearly pronounced magenta tint even with lens hood extended;
  • could be used as, but generally does not substitute portrait lens e.g. M.Zuiko 75mm/1.8;
  • focus not as fast as M.Zuiko 12-40/2.8, but OK (elements move longer distances). Center weighted metering contributed to slower focus speeds;
  • solid choice for street/documentary work, wildlife, maybe sports and everywhere where longer reach is needed;
  • solid build, truly professional feel;
  • lens hood retracted contributes to "fat"/"big"/"voluminous" image of this lens. Hood can be taken off, lens becomes more "slim". However you need it on sunny days to avoid flares;
  • it's pretty inconvenient to zoom with lens hood retracted, especially with tripod collar getting in your way. Extend hood or take it off.
  • tripod collar is not convenient if you carry camera around and can/should be taken off because you'll really notice weight difference without it;
  • you will surely need grip for E-M1 with this lens, otherwise it becomes too difficult to hold camera with long lens in the long run.
Final mark for this lens - if I gave 12-40/2.8 5 stars, then 40-150/2.8 would get 4. Solid performer, but not so spectacular as 12-40.
 LightCatcherLT's gear list:LightCatcherLT's gear list
Olympus E-M1 Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R Olympus M.Zuiko Digital 45mm F1.8 Olympus 12-40mm F2.8 Pro Panasonic Leica DG Summilux 15mm F1.7 ASPH
Telephoto zoom lens • Micro Four Thirds • V315050BU000
Announced: Sep 15, 2014
LightCatcherLT's score
4.0
Average community score
4.8
LearningForeverIHope
LearningForeverIHope Senior Member • Posts: 2,216
Re: Solid performer
Thanks for this report.
One question ¦ why would you use centre weighted metering?
 LearningForeverIHope's gear list:LearningForeverIHope's gear list
Panasonic Lumix DC-G9 Panasonic Lumix G 20mm F1.7 ASPH Panasonic Leica D Summilux Asph 25mm F1.4 Panasonic Lumix G 14mm F2.5 ASPH Olympus M.Zuiko Digital ED 60mm F2.8 Macro +3 more
Torsten Hoff Veteran Member • Posts: 3,787
Re: Solid performer
7
I wonder if you would have gotten better AF performance if your camera firmware was up-to-date -- you're two versions behind. V1.4 included AF improvements, and V2.0 would surely have been the one that Olympus did most of their compatibility testing with.
Mike Ronesia
Mike Ronesia Veteran Member • Posts: 3,043
Re: Solid performer
By not giving this lens 5 stars you will suffer the wrath of oly fanboys and risk being tarred and feathered as well. Thanks for your honest assessment. While I already find my 35-100 bigger and heavier then I'd like, it does look like a great lens for those who don't mind the extra bulk.
Mark James
A.K.A. Mike Ronesia
 Mike Ronesia's gear list:Mike Ronesia's gear list
Panasonic Lumix DMC-GH2 Panasonic Lumix DMC-GM1 Panasonic Lumix DMC-GH4 Panasonic Lumix DMC-GX8 Sigma sd Quattro +13 more
Mike Ronesia
Re: Solid performer
I use center weighted a lot. It helps balance the exposure while giving my subject the edge. This in conjunction with manual mode so I tend to ETTR, but I find it easier to get the exposure I want in the end using this method.
Mark James
A.K.A. Mike Ronesia
NZ Scott
NZ Scott Veteran Member • Posts: 5,201
It's good to read a review of this lens that isn't a gushing rave.
I usually find more balanced, and even negative, reviews to be more useful than the gushy ones.
After all, no lens is perfect.
If I buy a pro-quality telephoto zoom then I'm probably going to choose the Panny 35-100 for its more manageable size and weight.
Thanks again.
S
My Flickr stream:
http://www.flickr.com/photos/scottkmacleod/
My latest work of fiction:
https://www.smashwords.com/books/view/444160
My kit: E-P3, 12/2.0, 17/1.8, 45/1.8, 60/2.8 Macro, 7.5 Fisheye, 7-14, 12-35 f2.8, 14-42 IIR, 40-150 ED, 75-300 II
 NZ Scott's gear list:NZ Scott's gear list
Sony RX100 VII Olympus PEN E-P3 Panasonic Lumix DMC-GM5 Panasonic G85 Panasonic Lumix G Vario 7-14mm F4 ASPH +14 more
Oleg Vinokurov Regular Member • Posts: 261
Might be not at its best because of too old firmware.
Focusing speed is worse than 12-40 most likely because of old firmware, with 2.0 looks like it's faster, well lets say at least on par with 12-40. Wonder what else can firmware improve.
Also saw reports that 40-150 is noticeable sharper at 40mm than 12-40. Getting little bit softer at 150, as expected anyway.
But your report on flare is a bit surprising, from what i saw from this lens until now i thought it's at least on par with panasonic 35-100.
Casual photography blog - http://www.ofdigi.com/
500px - https://500px.com/olegvinz
eques Veteran Member • Posts: 4,115
Re: Thanks
After all these perhaps too high expectations, it is good to read this, though I am suprised at your report on IQ (sharpness, flare).
Peter.
 eques's gear list:eques's gear list
Panasonic Lumix DMC-GX8 Panasonic Lumix G 20mm F1.7 ASPH Olympus 12-100mm F4.0
Godiwa Regular Member • Posts: 322
Re: Solid performer
update your firmware and then please test again, using ancient firmware is not fair towards this lens or your camera.
and the hood, always keep it on, extend it when you use the lens and retract it when you bag the lens, no reason to take it off completely. and I agree with you on the tripod mount, remove it unless you plan on using tripod, it raises the weight and gets in the way.
why the center metering?
anyways thanks for the review, definetly not a bad lens.
Re: Thanks
If I read him right sharpness is rather good. As for flare, I'd say that the 12-40 pro, which should be of the same quality, does flare more than other lenses I own, 60mm macro, 20mm f1.7 even the Samyang 7.5mm surprisingly.
Peter.
SHood Veteran Member • Posts: 6,100
Re: Might be not at its best because of too old firmware.
The report on flare is not surprising. It was already reported and compare with the 35-100 in this review.
http://www.bestmirrorlesscamerareviews.com/2014/10/13/should-m43s-lenses-always-be-small-olympus-40-150mm-f2-8-pro-vs-panasonic-35-100mm-f2-8/
"The last image quality test I did was in a backlight situation to see micro contrasts and flare rendering. Regarding the ability to retain details, both lenses work fine. The Lumix seem to handle flares better."
 SHood's gear list:SHood's gear list
Olympus E-M1 II OM-1 Olympus M.Zuiko 300mm F4 IS Pro Olympus 12-100mm F4.0 Olympus 17mm F1.2 Pro
Skeeterbytes Forum Pro • Posts: 23,182
Re: Solid performer
Seems so unlikely that somebody with a big set of Panny gear would take an unprovoked shot at those who own Oly gear. Simply can't fathom why this might be....
Leaving amateur psychology aside, it's nice to get owner feedback on a lens that's still so rare. Hopefully we'll have a few dozen limilarly lucky folks posting work soon, then our own lying eyes can tell us whether the lens is something we want.
Rick
Re: Thanks
Well, I expected "stellar", not "rather good". Somewhere I read, it is even sharper than the F2/150 43 lens. (I hope I remember correctly)
Peter.
But this is all right for me: I won't be tempted to get this large and heavy lens.
Peter.
OP LightCatcherLT Forum Member • Posts: 66
Re: Solid performer
for portrait for example.
Re: Solid performer
you may be right, however mechanically 12-40/2.8 and 40-150/2.8 are two different beasts, so I do not them to act identically and have same speed. I consider my test unit to perform 'adequately'.
Re: Solid performer
well, I believe those who "want it" will have it anyway, others are mature boys and professionals that will make judgement based on lens capabilities and suitability for their task. It's very good lens indeed.
I spent few more days contemplating about my experience with this lens and reviewing my pictures. I am happy with picture quality that lens gave me, just a little bit frustrated with purple fringing. However biggest stop for me is not optics but size of that lens, because it makes my m43 system bigger and whole photo set heavier than I am willing to tolerate on my long trips, despite the fact that I want above average optical capabilities that pro level lens with F2.8 promises. It's like going back to Canikon DSLR's again.
It's special lens for special circumstances not the relatively compact super quality lens like 12-40/2.8 is.
webber15 Senior Member • Posts: 1,600
Re: Solid performer
I think robin Wong's summary more accurate than this,,and slr gear's review which is now up...there's always someone trying to throw a spanner in the works,,very dubious summary...
 webber15's gear list:webber15's gear list
Fujifilm X-Pro2 Fujifilm XF 100-400mm F4.5-5.6 OIS WR
Re: Thanks
The lens is stellar,,if sharpness is your thing,,great close up performance,,build,,focusing,,better at 40mm than the 12-40,, as good as 75mm f1.8 at equivalent focal length,,you want the superlatives (like me 😃) look at slrlens review...one downside is some chromatic aberration,which,as sharpness is so good,I can live with...I had a feeling this bloke was underselling it...now we have proof!!
Dan Veteran Member • Posts: 4,383
Re: Solid performer
LightCatcherLT,
How much purple fringing are you seeing and under what circumstances?
Like you I hate it and have returned a couple Nikon lens that I would have "loved" to keep...most notably the 180f2.8 D (nice size and decent reach) and the 85f1.8D.  Haven't had a chance to test the new Nikon 85f1.8...having the AFS 85f1.4 G makes the only incentive is some weight savings.
Thanks for your comments.
Dan
 Dan's gear list:Dan's gear list
Canon EOS 5DS R Nikon D5 Olympus OM-D E-M1X GoPro Fusion
Photo Pete Veteran Member • Posts: 5,430
Re: Solid performer
  • beautiful bokeh;
Could you post some of your photos to help illustrate your review please? -- Have Fun Photo Pete
