Excellent Lens!
Started Oct 20, 2014 | User reviews
JohnH4260 New Member • Posts: 6
Excellent Lens!
Have had this lens for 2 years now (since October 2012) and I love the images it produces. Use it with a Canon 5D Mk III. Great for interior shots. Also use for outdoors shots. I find I get my best results when stopped down to f/11 or so. Given the opportunity, would definitely buy again.
Canon EF 8-15mm f/4L Fisheye USM
Wideangle fisheye zoom lens • Canon EF • 4427B002
Announced: Aug 26, 2010
JohnH4260's score
5.0
Average community score
4.4
Canon EF 8-15mm f/4L Fisheye USM Canon EOS 5D
azakeyh Regular Member • Posts: 206
Re: Excellent Lens!
Hi john
Can you share some of your photos with that lens I would like to get it
Cheers
 azakeyh's gear list:azakeyh's gear list
Sony RX100 Canon EOS 550D Canon EOS 5D Mark III Canon EF 50mm F1.8 II Canon EF 85mm F1.8 USM +5 more
Erland Nielsen Regular Member • Posts: 487
Re: Excellent Lens!
Just ordered the lens today.
My main use will be macrophotography of insects (dragonflies). This lens goes to 0.39 x magnification at 15 mm, which is very good for wide angle lenses.
My 24TSII does 0.33 and my Sigma 14/2.8 does around 0.2. I using FF which I really think this lens need.
Anyone use the lens for macro (or close up photos I guess these images should be called) ? I've tried searching the web for images, but really don't find many.
Just another Canon shooter
Just another Canon shooter Veteran Member • Posts: 4,691
Re: Excellent Lens!
I wish Canon released EF 15 II. I have the discontinued one, and I love it.
 Just another Canon shooter's gear list:Just another Canon shooter's gear list
Canon EOS 5D Mark II Canon EF 15mm f/2.8 Fisheye Canon EF 35mm F1.4L USM Canon EF 50mm f/1.2L USM Canon EF 135mm F2L USM +4 more
Scott Larson Veteran Member • Posts: 7,505
Re: Excellent Lens!
Here's what you get when you point it straight at the sun (can you find the rainbow flare?):
 Scott Larson's gear list:Scott Larson's gear list
Sony RX10 IV Canon EOS 5D Canon EOS 5D Mark II Canon EOS-1D Mark IV Canon EOS-1D X +17 more
Re: Excellent Lens!
Thank you Scott
Rick Knepper
Rick Knepper Forum Pro • Posts: 17,870
Re: Excellent Lens!
Just left of center out close(r) to the shoreline, I see what appears to be purple fringing or CA but I may not be able to see the trees for the forest. IOW, where is this rainbow flare?
Rick Knepper, photographer, shooting for pleasure. It is better to have It and not need It than need It and not have It. Mystery Gardner: "Rick, you have a passion for photography but not a position. That's a good thing." Various RAW comparisons at Link below. Includes 5D3 vs D800E (new uploads), 5D3 vs. 6D, Zeiss lenses etc. https://app.box.com/s/71w40ita6hrcfghojaie
 Rick Knepper's gear list:Rick Knepper's gear list
Pentax 645Z Canon EOS 5DS R Fujifilm GFX 50S Sony a7R IV Pentax smc D FA 645 55mm F2.8 AL (IF) SDM AW +11 more
Rick Knepper
Re: Excellent Lens!
Correction: may not be able to see the forest for the trees. Saw this mistake seconds after posting it. Stupid DPR would not let me edit this post.
Re: Excellent Lens!
Yes, there is often some purple fringing in the corners in high contrast areas around the corners with this lens when you zoom out to where the image circle just barely fills the full frame area. It's one of the quirks of this lens.
OK, start at the second person from the left and go down. Once the rocks start to get dark, there's a tiny pretty diagonal rainbow.
Rick Knepper
Got it.
