problem whit nx1100
Started Oct 13, 2014 | Discussions
teto123 New Member • Posts: 6
problem whit nx1100
If i use autofocus mode whit optionals zoom mode i can see dots.what are this ? i can see dots only in this mode and are presente in the same position if i move the camera. The camera is new
Samsung NX1100
ttbek Veteran Member • Posts: 4,869
Re: problem whit nx1100
Hmm, I'm not sure.  Maybe small dust that isn't visible in the usually more downscaled image?
 ttbek's gear list:ttbek's gear list
Canon PowerShot SX10 IS Canon EOS 5D Samsung NX300 Canon EOS Rebel SL1 Samsung NX30 +37 more
OP teto123 New Member • Posts: 6
I can see this dot only in this mode (8x and 5x zoom in manual focus, sorry). After take the picture i can not see it.
sorry for my english
Hmm, I have no idea what it is then.
justanotherjim Junior Member • Posts: 26
Could that just be focus peaking? I'm not exactly sure what you're describing, but if you autofocus by holding the shutter halfway down, then adjust the focus ring (with dmf enabled) you will see small dots showing which parts of the image are in focus. Mine are white dots, but I think the color can be set in the menu.
Maybe try turning Focus Peaking off in the menu (top tab on my NX300) and see if you can replicate it?
 justanotherjim's gear list:justanotherjim's gear list
Canon G7 X III Nikon Coolpix P950 Sony a7C
vatazhka
vatazhka Regular Member • Posts: 355
NX1000/1100 doesn't have focus peaking.
These are most likely stuck and/or hot pixels on the sensor. I can see them on my NX1000, too. There's nothing in the captured images, though, even when looking in raw files.
BTW, could you request both threads you opened on the same topic to be merged by the moderator?
Check here if your Samsung NX firmware is up to date!
 vatazhka's gear list:vatazhka's gear list
Samsung NX1000 Samsung NX mini Samsung NX500 Samsung NX 20-50mm F3.5-5.6 ED Samsung NX 50-200mm F4-5.6 OIS +3 more
Okay, so it is not defective? I'll try to make merge threads, if I can (I just joined the forum and I do not know how to do it)
wstruth
wstruth Regular Member • Posts: 336
I had those on my Pentax K5 too, and they showed up on the images as well.  Teto123 As long as they do not show up on the images then its not really a problem.
Regards, Bill
 wstruth's gear list:wstruth's gear list
Ricoh GR II Canon G9 X Canon G7 X II Pentax K-1 Pentax KP +5 more
vatazhka
There's a good explanation in http://photographylife.com/dead-vs-stuck-vs-hot-pixels
I think you can't, please try to ask the moderator if this is some he can do (I belived he merged few threads in the past...).
