AdHoc007
Contributing Member
Copying color negatives with camera
Oct 13, 2014
I figured I would go ahead and post this as an experiment in progress. My basic setup is a Fuji X-t1 equipped with a shutter release cable, Minolta 50mm macro lens, 1:1 extension tube and a Metabones adapter that has a lens mount(important to have it because it centers the lens)
From there, I have a Minolta brand set of bellows, focus rail, and slide copier attachment. The bellows does not have much use for me because I ideally prefer to have a 1:1.5 ratio, and I don't have a lens that could provide me with one when attached to the bellows. So instead I use only the focus rail with slide copier attached. Because my slide copier has a bellows that attaches to the lens I don't have to work in a darkroom.
Beyond the camera, and focus rail, there is a light-box that supplies a 5000k light source, and a off camera flash hooked up to the PC terminal on my camera(I'm going to change it to a TTL cord later because the cord I am using has been showing signs of corrosion on the contacts). The flash is pointed at the light box so that it bounces off the box and on the back of the slide copier attachment.
I'll add some pictures later to show the setup.
When I was copying slides, it was easy to do, no problems with color correction, but now moving on to copying color negatives is a whole new ball game. So after weeks of reading, agonizing over how to do it properly I have come up with some theories to test.
Most solutions have suggested to shoot an undeveloped portion of the film and apply an auto white balance to it in GIMP, then apply the same settings to the developed film. This does not work at all. Once I invert the negative to a positive, there is an ugly green tint. Trying to white balance the "positive" image for the green gives me some bad coloration.
I tried custom white balancing in camera, not helpful. I tried white balancing in camera to an undeveloped negative, didn't work either. Then I tried setting the white balance to the lowest Kelvin possible. Now I have made some progress.
Seeing how setting my camera's white balance to the lowest possible Kelvin could compensate for the orange, I decided to try something else use a blue color correction filter. I set the white balance to 5000k so it matches the light-box, and then I attached a 80a color correction filter to the macro lens. I got useable results that could be adjusted in GIMP using the levels and autowhite balancing tools.
From what I have read about the negative to positive process, it sounds like a set of color correction filters are used in creating a positive print.
If there are any expert on here who can chime in, from what I read, it sounds like the best way to use color correction filters is to have the filters alter the light that hits the back of the film negative? What about having the filters on the lens which filters light that has already passed through the negative? What would be the next step, buy a set of color correction gels for the flash unit? Or would a set of lens filters be adequate for my purpose?
