Panasonic 100-300 -- views of a late adopter
Started Oct 10, 2014 | User reviews
Valentinian
Valentinian Contributing Member • Posts: 883
Re: Panasonic 100-300 -- views of a late adopter
View of a non-adopter:
unfortunately there is not a mft prime tele longer that the olympus 75mm. I decided not to buy neither the Pan 100-300 nor the Oly 75-300.
Instead, some time ago I bought a used  OM 200mm/f4 (manual focus of course) and a cheap adapter.
 Valentinian's gear list:Valentinian's gear list
Panasonic Lumix DMC-GX8 Panasonic Lumix DC-G9 Panasonic Leica DG Summilux 15mm F1.7 ASPH Panasonic 100-300mm F4-5.6 II Panasonic 35-100mm F2.8 II +1 more
Trevor Carpenter
Trevor Carpenter Forum Pro • Posts: 19,436
Re: Another late adopter
Dave Stott wrote:
I have just bought the lens, hoping I can completely migrate from apsc to m4/3. Only played around with it so far. Off the Florida in a week or two, what settings would you recommend for capturing birds' feather detail? The body is a GX7 , and I shoot RAW.
Thanks,
Dave
I think sweet spot is F7.1 /F8.  Not bad feather details here with the G6 and this is using the digital zoom
Panasonic G85 Panasonic Lumix DC-G9 OM-1 Olympus M.Zuiko Digital ED 60mm F2.8 Macro Panasonic Lumix G Vario 14-140mm F3.5-5.6 O.I.S +1 more
Eric Nepean
Eric Nepean Veteran Member • Posts: 6,209
I bought a used Canon FD 200mm F2.8, I have the simple FD-M43 adaptor, a FD-M43 Metabones Speedbooster and an FD 2x teleconvertor.
Eric
When the light is gone, the picture is gone ....
 Eric Nepean's gear list:Eric Nepean's gear list
Panasonic Lumix DMC-TS3 Panasonic Lumix DMC-GX7 Olympus E-M1 Panasonic Lumix DMC-GM1 Panasonic Lumix DMC-GM5 +73 more
LMNCT Veteran Member • Posts: 4,908
The f 7.1 aperture was my discovery when I first bought this lens.  It is great for telephoto-macro shots as well as wildlife.  My 100-300 gets a lot of use and I have never found it to be "soft" at any point when the proper aperture is used.  Enjoy your new lens.
 LMNCT's gear list:LMNCT's gear list
Panasonic LX100 Panasonic Lumix DMC-GX7 Panasonic Lumix DMC-GM1 Panasonic Lumix DMC-GM5 Panasonic Lumix DMC-GX8 +23 more
BJN
BJN Veteran Member • Posts: 5,119
Your lens has a problem.
I never have the lens twist when mounted. For yours to lose electric connection means your lens has a deficient mount. I can say I'm impressed with Panasonic's repair service and support (in fact I'm the opposite of impressed), but I'd recommend you get the mount replaced unless the lens is still within and exchange window and you can replace it that way.
BJ Nicholls
SLC, UT
 BJN's gear list:BJN's gear list
Rens
Rens Senior Member • Posts: 1,987
Yes, but...
Hi Geoff, thanks for the review.  I've also been wondering about this lens for a while.  I mostly use wide angle, but longer would be useful too.
I feel we're spoiled these days.  If your 300 mm examples are seen as too soft, well, how fussy are we getting?
My 'but' concerns your comment about your 45-200.  I have one (bought for my wife's G1 but she didn't want it), and haven't liked anything I've taken with it.  I can't quite say why, just that everything I shot with it didn't appeal to me.
So I would hope the 100-300 to be rather more likeable.
Any thoughts?
Rens
There are optimists and there are realists
 Rens's gear list:Rens's gear list
Panasonic Lumix DC-G100 Panasonic Lumix DC-S5
(unknown member) Veteran Member • Posts: 3,010
This is out of foucs
tinpusher
tinpusher Senior Member • Posts: 1,393
Re: Yes, but...
This image is taken at the soft 300 end but up to 250mm it's quite good ; just stop down one and use a fast shutter instead of the stabiliser. You only need the stabiliser when holding the lens steady.
Oh and both the Olympus inbody and Lumix lens systems work better at different times so it's always worth a bit of trial and error testing.
I never liked the 45-200 lens myself although it seems sharper with my EM10 than previous Lumix kit but it never gets used.
MOD Tom Caldwell Forum Pro • Posts: 46,352
Tokina 300mm mirror - a fate worse than death?
Geoff
You saved yourself from a fate worse than death with the Tokina 300mm mirror
It has no image stbilisation, no zoom, is fixed f6.3, on the soft side, lacks contrast, focus settings are hair-trigger even on th cusp of infinity, and has those doughnut out of focus artifacts which just love sparkly foam.   It is light but maybe it still needs a tripod for distance shots.
But it is a brilliant "occasional" lens  for the following reasons:
It is inexpensive, it works well at closer to medium distances (not far distances where its softness and lack of contrast  interfere), it is very light and small for its focal length,, f6.3 is not so bad in reasonable light, it is easy to hand hold as it is light and this is do-able at closer to medium distances. Doughnuts can be avoided once you know what causes them and they are not so bad when they are unavoidable.
It is no birder lens nor is it good for bringing the horizon into your lap but I wouldn't be without it rattling around in my kit bag, I might even use it from time to time when no other lens will do the job.
Tom Caldwell
TN Args
TN Args Forum Pro • Posts: 10,687
A nice OP and thanks for creating this thread, Henry.
My 100-300 is nearly 12 months old now. Quality I would describe as outstanding at the price point. I simply do not have the issue that you mentioned at all.
Sharpness at 300mm I would describe as sharp. At 100-200mm, very sharp. It is neither fair nor accurate to describe this lens as 'not sharp' at 300mm, as some people have done.
Arg
 TN Args's gear list:TN Args's gear list
Sigma dp0 Quattro Panasonic Lumix DMC-GX7 Olympus E-M5 II Sony a7R III Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 +10 more
Valentinian
Right. focus is not perfect (maybe still acceptable).
This one was a little better.
snapster Regular Member • Posts: 131
Re: Thanks, but one question.
tt321 wrote:
Corkcampbell wrote:
Thanks, but one question. As for your last comment - how do you know that it's not the camera mount that allows the lens to move?
I only ask because I have the lens (used on GH2/3 and EM-5 cameras) and have not noticed this problem.
This move/play exists in probably all camera/lens combos, if you try to wobble the lens hard enough, but breaking the electrical contacts accidentally is quite rare. In fact this is the first time I read about this.
The contacts are lost only if you move by more than a mm, I think, and that would feel quite weird.
I've had this lens for four years. I got it on pre-order in December 2010. During this period I have taken probably over 60,000 images on first the GH1 and now the GH3 and have never had this problem with the mount.
Paul
 snapster's gear list:snapster's gear list
Sony a7R IV Sony FE 90mm F2.8 macro Sony FE 100-400mm F4.5-5.6 Sigma 24-70 F2.8 DG DN
Yes a lot sharper. Nice photo!
Hen3ry
OP Hen3ry Forum Pro • Posts: 18,218
Re: Yes, but...Ren and Tinpusher
The 45-200 -- hmmm, possibly depends on what camera you use it with. I got it along with a G1 with the 14-45 and to be frank, after not having an interchangeable lens camera for a while, I thought I had died and gone to heaven.
I took some excellent pix with the 45-200 in a range of situations and very much enjoyed using the 45-200 with the G1. A great handling combination. Here are some examples from PNG and Melbourne, Aust., all JPEG and except the first, pretty much OOC:
This was with my then new E-PL3. I found the 45-200 was just wrong with that little body with its lousy grip (I switched from the G1 for the better JPEGs). I switched to the Oly 40-150. I am now back with the Panny G6 but using the 45-150 lens -- and now the 100-300 beyond that.
Cheers, geoff
Geoffrey Heard
Down and out in Rabaul in the South Pacific
http://rabaulpng.com/we-are-all-traveling-throug/i-waited-51-years-for-tavur.html
 Hen3ry's gear list:Hen3ry's gear list
Panasonic Lumix DMC-GX7 Panasonic G85 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Olympus M.Zuiko Digital 45mm F1.8 Panasonic Lumix G X Vario PZ 45-175mm F4.0-5.6 ASPH OIS +7 more
Hen3ry
Re: Tokina 300mm mirror - a fate worse than death?
Tom Caldwell wrote:
Geoff
I can understand the long coat hiding the whipping pointy tail and the crazy hairdo to cover the horns, but where did you park your trident while you typed, you tempting devil, you?
Actually, I am not tempted. No AF is beginning and end of story for me much as I would like the size, etc.
Cheers, geoff
Geoffrey Heard
Old Listener
Old Listener Senior Member • Posts: 2,028
Geoff,
I always like the pictures of masks and headdresses that you post.  The art is in the content of the pictures.  Thanks.
 Old Listener's gear list:Old Listener's gear list
Panasonic Lumix DMC-FZ50 Panasonic FZ1000 Panasonic Lumix DMC-G6 Panasonic Lumix DMC-G7 Panasonic Lumix G Vario 100-300mm F4-5.6 OIS +5 more
Hen3ry
Old Listener wrote:
Geoff,
It is, Oldie -- I try to make a decent composition, etc., etc. but the fact is that the content, this wonderful art work, is what "sells" so many of my images.
And then I do landscapes with palm trees and volcanoes.
Sometimes I feel like a total cheat! LOL.
Cheers, geoff
Geoffrey Heard
Hen3ry wrote:
Tom Caldwell wrote:
Geoff
Cheers, geoff
I don't think that you would like it Geoff, even with AF.  It makes many compromises and I don't use it a lot. But I must get it out next time I am doing mid-disatnces on a sunny day.  It then does get you right up close and the images can be fine - but it is not a shoot from the hip lens and takes a little work to get everything set.
Tom Caldwell
Old Listener
Hen3ry wrote:
Old Listener wrote:
Geoff,
Cheers, geoff
Well, being in the right place at the right time is a priceless skill. Recognizing interesting content is a very real skill.  Capturing the image to best advantage is another real skill.
I think that photography as documentation of a subject at a particular time is mainstream.  Real fine art photography is far less mainstream.
