S5 Pro users ...
Started Oct 7, 2014 | Discussions
veroman Veteran Member • Posts: 4,904
S5 Pro users ...
I need a recommendation for a fast, all-around zoom for my S5 Pro, i.e. traditional walk-around range (18-50 or so) and f/2.8 or larger. I'm looking for a lens that will bring out the best of what the S5 Pro has to offer but that won't break the bank. Nikon's kit lens, the 18-55 VR, is very good for what it is ... a bargain in fact. It's just too slow and color rendition leaves something to be desired.
Thanks.
SteveG
'When love and skill work together, expect a masterpiece.'
— Found in a Chinese Fortune Cookie
www.stephenmichaelgarey.com
 veroman's gear list:veroman's gear list
Leica X Vario Ricoh GR II Panasonic Lumix DMC-GF1 Pentax K-01 Pentax K-5 II +2 more
Fujifilm FinePix S5 Pro
JF69 Contributing Member • Posts: 864
Tamron 17-50mm ƒ2.8
I have the non-VC version, & it is a great all round lens; it's very good WO, stopped down eve to ƒ3.5-ƒ4 it's already excellent.
I've used the S5/17-50 combo for my pro work for years; I only recently replaced them with the Nikon D610 & Nikkor 28-105mm.
 JF69's gear list:JF69's gear list
Fujifilm FinePix S5 Pro Nikon D610 Nikon AF Nikkor 85mm f/1.4D Carl Zeiss Distagon T* 2,8/21 Carl Zeiss Distagon T* 2,8/25 +8 more
OP veroman Veteran Member • Posts: 4,904
Re: Tamron 17-50mm ƒ2.8
Thanks. Yes, I'm considering that one. Enjoy your D610!
SteveG
Mark Carr Senior Member • Posts: 2,411
Re: S5 Pro users ...
I'd have to agree with the other member, that Tamron is a great lens. I too had the non-VC version, which I believe was better optically, and it was a joy to use. Difficult to focus manually, but for the money I don't think you could find a better zoom in that range.
Kind regards,
Mark
Giovanni_1968
Giovanni_1968 Veteran Member • Posts: 3,916
I'd say that the S5 requires high quality glass like primes, I enjoyed it a lot with the 50/1.4D but also with the old school 35-70D, if you don't mind great apertures the Tamron should do fine but give a try at a couple primes.
Many S5 shots in my flickr
Giovanni
http://www.flickr.com/photos/giovanniaprea/
FujiS5 Nikon D800 Panasonic L1 shooter
 Giovanni_1968's gear list:Giovanni_1968's gear list
Fujifilm FinePix S5 Pro Nikon D2Xs Nikon D800 Nikon Z6 II Nikon AF-S Micro-Nikkor 60mm F2.8G ED +20 more
Buttons252
Buttons252 Senior Member • Posts: 1,642
My S5 pro came with an older tamron 28-105mm F2.8 and i didnt care much for its output. I later bought a Nikon 50mm F1.8 AF-D and was quite pleased before i sold the whole setup. I tried a tamron 17-50 F2.8 for my pentax K5 and didnt really care for that either, but im sure it was a lot better then the kit lens.
I tend to favor the primes or overpriced zooms.
Fuji X-A1 + PK lens adapter + 55mm Pentax SMC 55mm F1.8
Nikon D600 + Rokkinon 14mm F2.8 / Nikon 85mm F1.8G
 Buttons252's gear list:Buttons252's gear list
Sigma DP1 Merrill Sony a7 IV Sigma 40mm F1.4 DG HSM Tamron 150-500mm F5-6.7 Di III VC VXD Samyang 135mm F1.8 AF
mistermejia Veteran Member • Posts: 3,340
Try the sigma 17-50 or 18-35 1.8.
Ignore the Nikon 17-55, I had it and IQ is not worth it.
Try them and see if u like them. If u have big bucks get Nikon 16-35 f4 or the pro FF lenses. U won't regreat it.
 mistermejia's gear list:mistermejia's gear list
Fujifilm FinePix S5 Pro Fujifilm X-E1 Nikon AF-S DX Nikkor 35mm F1.8G Tamron SP AF 70-200mm F/2.8 Di LD (IF) MACRO Fujifilm XF 35mm F1.4 R +6 more
Duri Regular Member • Posts: 276
Sigma 18-35 F1.8 - excellent lens, best zoom you can buy, it even beats primes
Sigma 17-70 2.8-4 OS HSM Contemporary - great value for the money, sharp, stabilization around 3 stops (so at 70mm f4 translates to f1.4 from exposure perspective), nice zoom range, good close focus capability
Both can be calibrated at home via Sigma USB dock.
I have no direct experience with those lenses (just own first generation of 17-70, above mentioned is third gen.) but last month I'm considering new lens for S5.
Duri
 Duri's gear list:Duri's gear list
Fujifilm X-T1 Fujifilm XF 35mm F1.4 R Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 56mm F1.2 R
Westmill
Westmill Senior Member • Posts: 2,279
The Sigma 18-35 is certainly superb but both expensive and over kill on a S5 Pro.                    The tamron 17-50 is a good choice for sure. Very sharp lens. None VC version is sharper !
Another perfect lens for the S5 is the Nikon 18-70 F3.5-4.5   A bit faster with greater range than the standard zoom and produces excellent quality results. Top this with silent fast autofocus and weather sealing ring on its base and it takes some beating.
Sharpness comes from the lens though... as such, my choice would perhaps be the Tamron !
 Westmill's gear list:Westmill's gear list
Fujifilm X-Pro1 Nikon D4S Nikon D500 Nikon AF-S Nikkor 70-200mm f/2.8G ED VR II Nikon AF-S DX Nikkor 16-80mm F2.8-4E ED VR +5 more
No no no. Those lenses are NOT overkill. The S5 deserves the best glass. The best bang for the buck are the sigma lenses. I'm not a fan of the tamron lenses, even if the non VC is sharper. The stabilization of the sigma 17-50 is excellent.
Westmill
I was refering to the Sigma 18-35 F1.8 only which also happens to be expensive.
I tried a sigma 17-50 on a D7100 the other week. I sent it right back as it had compatability probs with the D7100. It seemed ok IQ wise but my old Tamron seemed sharper and notably so.
I have come to value VC though so it is something to take into consideration for sure. If I still had my S5 i would myself stick the Nikon 18-140 on it  Seems the OP wants f2.8 though
Yes I know.  But that lens is not an overkill.  Only one of fuji's prime lenses can cost the price of the sigma.  The price of that lens is a bargain.
Yes, there is compatability issues with the D7100 and some sigma lenses, that doesn't have anything to do with the S5.
All i can say is that the sigma with OS was giving me sharper images than my previous nikon 17-55. The OS really helps for still shots mainly, but it does make a difference indeed.  I think my local samy's camera store is having a sale on sigma lenses this month, possibly, and I'm also having a difficult time deciding which of the two sigma lenses i will get.
The nikon 16-35 F4 is a gorgeous lens too, but THAT is a bit over priced
mistermejia wrote:
... The S5 deserves the best glass. The best bang for the buck are the sigma lenses. I'm not a fan of the tamron lenses, even if the non VC is sharper. The stabilization of the sigma 17-50 is excellent.
Yes, the S5 Pro certainly does deserve the best glass. It's a stunning performer in many respects; it has always been an underrated camera.
And, yes, Sigma does deliver the best bang for the buck much of the time. But their quality control is fairly unreliable. I've bought and used many Sigma lenses over the years and have had to return all too many of them due to issues. It's not the end of the world to return something for adjustment but it's a pain, and it takes time.
I find Tamron lenses, as third party lenses go, to be far more predictable and issue-free compared to the Sigmas ... although I believe Sigma is getting better at it these days with their newer Art and Contemporary lenses. Still ... I'd opt for the Tamron 17-50 over the Sigma 17-50 simply from a reliability viewpoint. They're both very good lenses.
SteveG
If I ever buy additional sigma lens (I have 3 now) it will be a model compatible with USB Dock so I can tweak AF to my needs in case of any issue.
2 of my sigmas went calibration (30 f1.4 and 50-150 f2.8) and it really helped.
Duri
May I ask if you bought all your sigma lenses new or used?  Which models did you buy?  Did you buy them on line?  What i do know is that BOTH sigma and tamron vary in quality a lot, but yes, i also think sigma has improved a lot.  Some of the tamron long lenses are REALLY good too.
My dad has the sigma 17-50 and he has never had any problems.  I have borrowed it too.
I can't say which is better, Sigma or Tamron, but they're producing world class optics at the moment. Sigma's Art line is top shelf, and Tamron's 70-300mm 90mm and 60mm lenses rival Nikon's best. Their 17-50mm and 180mm are also very good, maybe exceptional. Great to see so much competition, we all benefit from it.
Kind regards,
Mark
zapper Regular Member • Posts: 204
I still have my S5Pro, but don't use it.
I found the Nikon 17-55f2.8 to be wonderful on the S5Pro.
I preferred primes for less weight & bulk, like the Nikon 35mm F1.8 DX, Nikon 50mm F1.8G and of course the Nikon 85mm 1.4
BSandu New Member • Posts: 2
Tokina 11-16 2.8 - wonderful
Tamron 17-50 2.8 (non VC) - excellent
Tokina 50-135 2.8 - fabulous, hard to find. Alternative Sigma 50-150 2.5 with OS - expensive, but it worth
Tamron 70-300 VC - MUCH better than Nikon 70-300 VR II. Cheap and fantastic
Sandu
 BSandu's gear list:BSandu's gear list
Fujifilm FinePix S5 Pro Nikon D2X Nikon D300 Nikon D5300 Tokina AT-X Pro 50-135mm f/2.8 DX +7 more
I assume that sigma 50-150 2.5 is typo. AFAIK sigma have 3 50-150 lenses and all for them are 2.8.
50-150 F2.8 - oldest one
50-150 F2.8 II - same as previous with minor tweaks
50-150 F2.8 OS - most recent, huge lens, similar to 70-200, excellent optics (but really heavy)
Duri
Westmill
Sigma 50-150 Is ooooooo yes !
http://www.dpreview.com/forums/thread/3618195#forum-post-53179864
Although I might be selling it
