nx200 firmware update went wrong
Started Oct 5, 2014 | Discussions
sanderkerkhoff New Member • Posts: 2
i noticed there was a new firmware for my nx200, so i went ahead and dled it, unzipped it to my sdcard and upgraded from the internal menu.
Unfortunately something went wrong, and the update was not finished after waiting for more then 1/2 hour. Finally i took out the battery, but after that the camera didn't turn on anymore...
The green led on the back and the green foucussing light were flashinh, and nothing happened.
After some fiddling, i decided to leave it alone with the flashing leds, and after it seemed alive again. Only problem is that nothing works, i cannnot access menu and other functions
What can i do? Is my NX200 bricked now?
Samsung NX200
vatazhka
vatazhka Regular Member • Posts: 355
Re: nx200 firmware update went wrong
Contact Samsung repair centre and ask how much it will cost to repair it. They will probably tell you that a mainboard needs to be replaced. In such case, if the cost is prohibitive, you could try to procure another NX200 (e.g. with a cracked screen) and try to replace the mainboard yourself / in a 3rd party repair centre.
Or, if you feel that you have nothing to lose and feel adventurous, please try whether the procedure described below will trigger reflashing. The disclaimer is that the below is a shot in the dark - I'm not sure whether it works (most likely not) and have never tried it myself.
  1. Create a file with a name FWUP in the topmost folder of your memory card. Put the following text inside:
    upgrade all
    keep
  2. Place a BIN file with up-to-date firmware image in the topmost folder of your memory card.
  3. Now place the memory card in your camera (battery has to be fully charged) and turn it on.
If this doesn't work, probably the only way to go is to reflash via JTAG port (I'm not even sure whether JTAG port is present on the PCB.). Or maybe there is a way to prepare a special rescue image with OneNAND Boot Loader? This needs fairly specialised knowledge which I don't have...
Check here if your Samsung NX firmware is up to date!
 vatazhka's gear list:vatazhka's gear list
Samsung NX1000 Samsung NX mini Samsung NX500 Samsung NX 20-50mm F3.5-5.6 ED Samsung NX 50-200mm F4-5.6 OIS +3 more
OP sanderkerkhoff New Member • Posts: 2
i have tthis on a fresh SD:
HWUP
(contains this:
upgrade all
keep)
nx200.bin
nx200.rom
but that does nothing....
