70-300L change of mind
Started Oct 5, 2014 | User reviews
drbird Regular Member • Posts: 432
5
I never really was a big fan of the different 70-300 on the market I always liked the range but not what was available. Either the IQ at 300 was poor or the lens just wasn’t built well enough to survive longer than a year. In fact I went through several 70-300 IS which all ended up as paperweight. At the end I covered the range with a either a 2.8 or 4.0 70-200 and a 1.4 II converter. As I had to replace the 4.0/70-200 (hit a rock really badly ) the choice was either go with what I knew is a terrific lens or give the first L 70-300 a try. After lots of thoughts I decided to go for L 70-300, what a lens the IQ is really up on the level of the 70-200 and the bokeh at 300 is nicer than with either of the 70-200 with converter. Mechanically the lens doesn’t disappoint but I really don’t like arrangement of the zoom/focus ring it took me quite a while to get used to the zoom-ring in the front. And the second really annoying fact is that the tripod mount ring is not included for the price Canon asks - just include it. Is as good as the 2.8/300?? No at 300mm of course not;   between 299 and 70mm  it is by far the better lens .   a happy camper.
+ IS works stunningly well, IQ doesn’t disappoint, AF is very fast, no problems with strong backlight, versatile range, not heavy at all and ideal for having in my jacket when I am out with 500 or 600 including tripod.
- Af in low light sometimes hunts at the long end of the lens (a problem of being a 5.6 lens), extreme focus breathing at the long end and close focus – in fact it gives roughly the same magnification as the 4.0/70-200 at 1.2m means same focal length
Geraldo Hofmann
two examples when the lens comes in handy
 drbird's gear list:drbird's gear list
Canon EOS 7D Mark II Canon EF 400mm f/5.6L USM Canon EF 70-300mm f/4-5.6L IS USM
Telephoto zoom lens • Canon EF • 4426B002
Announced: Aug 26, 2010
drbird's score
4.5
Average community score
4.8
OP drbird Regular Member • Posts: 432
Re: 70-300L samples full res.
300mm
Geraldo Hofmann
kevindar
kevindar Veteran Member • Posts: 4,625
Re: 70-300L change of mind
yes, the 70-300L is indeed very good.  However, unless you are using your lens as a weapon, its highly unusual for 70-300 Non L to last you for only one year..... twice.
Its interesting what you say about focus breathing.  Fist I have heard about it on this lens.  I just tested it, and you are absolutely correct.  its only about 10-20mm longer than 70-200 f4 IS at MFD.
this is usefule information for me, as I often shoot hummingbirds with it at very close distance.  the 70-200 f4 IS is a stop faster, and lighter.
 kevindar's gear list:kevindar's gear list
Canon EF 85mm F1.2L II USM Canon EF 70-200mm F2.8L IS II USM Canon EF 24-70mm F2.8L II USM Sony a7R II Sony a6300 +25 more
Timbukto Veteran Member • Posts: 4,988
He was talking about the non L breaking. And I can see that. No one would rate a L that breaks in a year that high.
 Timbukto's gear list:Timbukto's gear list
Canon EOS M Canon EF 200mm f/2.8L II USM Canon EF-M 22mm f/2 STM
kevindar
its interesting that you quoted me without properly reading what I wrote, and then proceeded to correct a mistake which was not there  Read it again.
Sorry, my mistake.  Still I kind of see the 70-300 non-L not lasting in wildlife shots like the pictures he have shown (well if you baby it even in the outdoors it should be ok, but lenses shot by wildlife shooters typically aren't the type of lenses that you can sell on ebay or CL as mint condition)
kevindar
http://www.flickr.com/photos/kevindar/
I owned the non L for about 4 years, and it saw some good amount of use  It certainly does not have the built quality of the L lens (nor the focus speed, or optical quality), but I find lenses to be precision equipment with glass elements in them and treat them as such.  Keep in mind that if you are abusing the L lenses, even if they dont break, they could very well get out of alignment.
Not to say built quality does not matter, it does.  Additionally the L lenses are more commonly weather sealed.   It just surprised me for someone to go through two lenses (may be with exception of 50 1.8 II) in two years.
kevindar wrote:
I had one too...I think the biggest potential point of failure on the non-L is that its probably the largest lens I've ever owned that still utilizes front element/cam rotation on focus.  I think that might be a point of failure but that is just pure speculation on my part.  50mm 1.4 has a bad reputation for AF failure and it has a slightly protruding lip that is coupled to its AF motor.  The 70-300 non-L in comparison has a huge rotating cam that may be coupled to its AF motor and like the 50mm 1.4 it uses a cheaper grade of USM (gear based?) compared to many L Ring USMs.
It was the none L 70-300…which is a nice lens for what it is.
The sealing against moisture is just not good enough when you camp in the rain forest for two months (was the first one hitting the bin) and neither does it like sand when working in the desert. I agree I don’t pamper my equipment but then they are tools for me which have to earn me my living. Whereas my L lenses often are not that much better in terms of IQ they really take bad conditions and treatment much better than their less expensive relatives.
Geraldo Hofmann
-A 12/25mm extension tube gives you back some of the focal length of the 70-300 works really well I use it sometimes for venomous snakes when longer is better.
Geraldo Hofmann
That would certainly do them in.  Based on what I saw the 70-300 non-L seemed very 'drafty' in its design.  My 85mm 1.8 does not have any extending barrels and internally focuses and collects dust like a vacuum.  So to see a large telephoto that pretty much ignores weather sealing of any kind is inviting failure in the conditions you cite.
rebel99 Veteran Member • Posts: 4,025
kevindar, unfortunately i lost my 70-200 f4.0IS a couple weeks ago and i need to replace it. i am really hesitant to purchase a new f4.0IS and replace the lost one or get 70-300 L IS, which has a superb IQ, almost the same as f4.0IS. in the same time, i do have a 70-200 f2.8L non-IS. i strongly feel like going for the 70-300 L which is nice for travels since i do have the 70-200 f2.8 non-IS already, what would you do? appreciate your input
chears.
stratobill Senior Member • Posts: 2,081
chears.
I followed the 70-200 F4IS with the 70-300L and was not disappointed. Maybe ever so slightly less sharp, but not so you'd notice.
 stratobill's gear list:stratobill's gear list
Canon EOS 6D Canon EOS Rebel SL2 Canon EF 70-300mm f/4-5.6L IS USM Canon EF 24-105mm f/4L IS USM Canon EF 40mm f/2.8 STM +4 more
kevindar
chears.
You logic is sound.  optically, there is nothing that separates the two lenses.  both are stellar. 300 goes to 300, but its not a constant aperture.  its fatter and heavier and extends, but packs smaller.  Both are very fast focusing, with a very slight edge to the 70-200 f4 IS.  the 70-200 is also a touch less expensive.  However, If I were in your shoes, I would go with te 70-300 L IS.
For me the IQ of the 70-300 L is good enough even at 300 the images turn out quite sharp (see the samples of the deer males in the water (view the 1:1 and you should see the pixel level). Theonly thing which annoyed me –in particular at the beginning- was the handling to have zoom and focus ring not in the place I was used to for so many years was quite tricky at the beginning. Even now after thousands of images I sometimes turn the wrong one but that may be me working with Canon 70-200 since decades. If you think you benefit from the 200-300 range go for it is stunning lens small and light enough for the pocket and you still have the 2.8/70-200 when you need the speed.
Geraldo Hofmann
totleytom Contributing Member • Posts: 564
"extreme focus breathing at the long end and close focus – in fact it gives roughly the same magnification as the 4.0/70-200 at 1.2m means same focal length"
Can I just check that I understand what you mean by this? That when set to 300mm and focused on something very close, it seems to give the same image as a 70-200 at 200mm?
What about at longer focusing distances? Do you have any feel for what distance you need to be at before it starts acting like a 300mm lens?
 totleytom's gear list:totleytom's gear list
Canon EOS 90D Canon EF 70-200mm F4L IS USM Canon EF 40mm f/2.8 STM Sigma 17-70mm F2.8-4 DC Macro OS HSM | C Canon EF-S 24mm F2.8 STM
Yes at minimum focus distance you roughly end up with the same focal length as the 4.0/70-200 has. Focus breathing is quite common nowadays in modern designs, I guess it doesn't bother most people or most don't realize it. Just look at all the 18-200(300) and the like they suffer massive from focus breathing as does one of the newer Nikon 2.8/80-200. An extension tube often helps to get some of the original focal length back (you basically focus with extension and avoid the IF-mechanism which mostly is responsible for the focus breathing – but also for the compact size, ice IQ and blazing fast AF of modern lens)
No I didn’t really check at what distance it kicks in, I often use it at 300mm around 5-10m and it works out very similar to my 2.8/300. But as soon as I get the tripod mount for the lens I will compare it to the 2.8/300 to get some valid data.
Geraldo Hofmann
cybersimba
cybersimba Senior Member • Posts: 1,724
70-300L is an awesome lens! I bought one myself when considering 70-200 f/4 IS and I have been very happy with it. The IQ is outstanding! Based on images I have managed to click with this lens I sometimes think that this lens is under-rated or probably not covered as much as 70-200 series. The extra range, portability makes it very handy to even carry it in small camera holster along with you for any casual day trips. Here are some samples from mine:
https://www.flickr.com/photos/sachinsawe/14952005710/
https://www.flickr.com/photos/sachinsawe/15182400861/
https://www.flickr.com/photos/sachinsawe/15185673615/
and a couple of more...
Taken at a children's park
Taken at a beach
 cybersimba's gear list:cybersimba's gear list
Sony a9 Sony a1 Sony a7R IVA Sony FE 90mm F2.8 macro Sony FE 85mm F1.8 +12 more
brightcolours Forum Pro • Posts: 15,885
All lenses change focal length over the focus range, it is normal. The 70-200mm f4 gets a bit shorter in focal length at MFD, which results in a more narrow FOV . The 70-300mm L gets a LOT shorter at MFD, which results in a wider FOV. The FOV at MFD for both lenses, one at 200mm and the other at 300mm, is similar.
The change in FOV over the focus range of a lens is called focus breathing.
The change happens gradually over the focus range. At medium distance to infinity, the lens "acts" like a 300mm lens, for all intends and purposes.
It has been a thing of all (lens) ages.
The Nikon 70-200mm f2.8 VR II gets wider at MFD. The Canon 70-200mm's (all) get more narrow at MFD. The Sigma 70-200mm f2.8 OS version acts like the Nikon, the Tamron sort of too.
The IF mechanism is not responsible, that is an internet myth. The Nikkor 70-200mm VRII gets wider at MFD, the Canons (all 70-200's) get more narrow at MFD. All are IF lenses. The only lens I have which does not show any breathing, positive or negative, is an IF lens too (Tokina 12-24mm f4 DX).
It does not kick in, it is a totally gradual change.
Geraldo Hofmann
