kit 14-42 or used prime wide such as Panasonic 14mm?
Started Oct 3, 2014 | Discussions
adamandbean
adamandbean Contributing Member • Posts: 615
Actually, I can get the 14mm 2.5 used here in Japan in excellent condition for $160! Seems like a bargain but I have heard good things of the kit lens in either Panasonic or Olympus. Your thoughts or recommendations?
Sincerely,
Adam
 adamandbean's gear list:adamandbean's gear list
Canon EOS 5D Olympus OM-D E-M10 Olympus M.Zuiko Digital 25mm F1.8 Olympus 9mm F8 Fish-Eye Body Cap Lens +1 more
Panasonic Lumix G 14mm F2.5 II ASPH
K25 Regular Member • Posts: 296
Re: kit 14-42 or used prime wide such as Panasonic 14mm?
My thought: if you take photos professionally, look for the best tools. But if you do for your pleasure, then get what you like to use.
For me would be the 14: I have one and is most of the time on my GM1. There are also a 20/1.7 and a 9-18 in the bag, and 2 standard zooms in a drawer. If am around with just camera & one lens usually it is the 14. But that's me.
So my recommendation: get the kind of lens you like to use, have fun with it, try to get the best from camera & from yourself - and you will produce better photos than fighting with a lens you got just because of supposed optical superiority, or for capabilities you don't really need.
Try to use your kit lens strictly only on the wide end. Using a prime is not just "zooming by walking": is is much more to first observe the subject and decide where to go for having the best view. If you like the challenge you will enjoy the 14 and your $160 will be well spent.
adamandbean
OP adamandbean Contributing Member • Posts: 615
K25
Many thanks for your input.
Regards
sigala1 Veteran Member • Posts: 3,911
Sincerely,
Adam
The 14-42 kit lenses from both Panasonic and Olympus are good lenses and have, in my opinion, no worse image quality than the 14mm pancake. In fact, on Olympus cameras, the 14mm pancake has much worse image quality on account of the purple fringing. Also, the 14mm pancake has soft corners. It's the second-to-worst prime lens that I own. The worst prime lens I own is the bodycap 15mm.
alcelc
alcelc Forum Pro • Posts: 19,004
Sincerely,
Adam
Two different lenses although are both touching the 14mm fl.
14mm f/2.5 is faster, smaller and lighter. But due to its fixed 28mm eq fl, its application would be relatively more limited (going back to the pros and cons of Prime vs zoom). It is considered as one of the cheaper prime for low light shooting.
14-42 kit (Panny's MII would be sharper than MI) is relatively larger and slower. But having a eq 28mm to 84mm fl (wide angle-standard-short tele: portrait) which would be very good for general purpose shooting under reasonably good lighting condition. Comparing to that 14 prime, it would be relatively more convenience.
In terms of IQ, 14 of 14-42 and 14 prime should be very close in real life shooting.
0MitchAG Contributing Member • Posts: 538
I did the exact same thing as you are currently thinking! I hated the stiffness and size of the 14-42 I kit lens and thus I refused to put it on my camera anymore, now owning just telephoto lenses (funnily enough, 45mm became one of my favourite focal lengths and I didn't feel limited to even require a wide angle for the shooting I was doing).
I went on Ebay and bought one of those Japanese-stock 14mm F2.5's for $169 and I have not at all been disappointed! Optically, it is as good as the 14-42 but it fits in your pocket!! ... And it's 1 stop faster - matching or even beating the 14-42 when shot at F2.5 so there's definitely nothing to complain about. It makes for an excellent lens in the street where the pancake size is much more inconspicuous. It will also be better kitted if you eventually buy the 20mm pancake or especially if Panasonic (and I really hope they do) release a pancake telephoto around 45mm as an equal quality, more expensive but smaller design vs the Oly 45mm.
The only criticism of this lens seems to be the large sample variation resulting in some dissapointed owners - but my copy is excellent from corner to corner.
 0MitchAG's gear list:0MitchAG's gear list
Panasonic Lumix DMC-G5 Panasonic Leica DG Macro-Elmarit 45mm F2.8 ASPH OIS Panasonic Lumix G Vario 14-42mm F3.5-5.6 ASPH OIS Panasonic Lumix G Vario 45-150mm F4-5.6 ASPH Mega OIS Panasonic 20mm F1.7 II +6 more
LMNCT Veteran Member • Posts: 4,908
Opt for the 14 2.5.  It is a good lens.
 LMNCT's gear list:LMNCT's gear list
Panasonic LX100 Panasonic Lumix DMC-GX7 Panasonic Lumix DMC-GM1 Panasonic Lumix DMC-GM5 Panasonic Lumix DMC-GX8 +23 more
inlawbiker Senior Member • Posts: 2,066
Why not both?  They're both very inexpensive and above average if I may say so.  I love the kit lens and find it very useful.
Greg.
 inlawbiker's gear list:inlawbiker's gear list
Panasonic Lumix DMC-G7 Fujifilm X-T2 Olympus E-M1 III Olympus M.Zuiko Digital ED 60mm F2.8 Macro Fujifilm XF 18-55mm F2.8-4 R LM OIS +4 more
s_grins
s_grins Forum Pro • Posts: 14,011
Everything depends on where you are and what you shoot.
For normal outdoors daylight photography I prefer kit zoom - zoom gives me versatility.
Camera in bag tends to stay in bag...
 s_grins's gear list:s_grins's gear list
Panasonic G85 Panasonic Lumix G 20mm F1.7 ASPH Sigma 30mm F2.8 EX DN Sigma 60mm F2.8 DN Art Panasonic Lumix G Vario 14-140mm F3.5-5.6 O.I.S +3 more
Charles Pike
Charles Pike Senior Member • Posts: 1,530
I shoot with a prime lens.
I have the 14, 20, 25, 45, 14-45, and 45-200.  I almost never use the zoom lens.  I do use the 45-200 for fall color during my fall trip to the N.C. mountains but that is about it.  If I knew what I know today, I would only have the 14, 25 and 45 mm lens.  The 20 quality is about the same as the 25 mm lens, but the 25 mm is tack sharp and nails the focus better than the 20.  Then the 20 is much smaller than the 25 so you have to judge for your self.  My 14 is soft around the corners if the subject is of the street taken from a distance.  Go to the museum and shoot glass or a painting and it is very sharp.  I think that the camera chose a smaller f/stop for the street shot where I set the settings for the museum shots at f/4 its sharpest setting.  I went to Chicago a year ago, and have several shots on my web page from Chicago.  The only lens that I had with me was the 25 mm lens.  The size of the 14 makes it easy to carry in a pocket to go along with that larger lens.  Don't really remember how fast the 14 was to focus.  It really is a lens that any prime shooter should have in his kit.
One thing about the primes.  when you go to look at reviews of people who are shooting with them, these fast primes are best when stopped down to f/4.  Bad for a zoom when that is nearest the fastest f/stop and you really need to stop down at least two stops from wide open.  Just not enough light for a fast shutter speed with a zoom.  That said, on a tripod that kit lens does a really nice job.  I just shot primes for so many years that it fits my style better.
www.photosbypike.com
 Charles Pike's gear list:Charles Pike's gear list
Fujifilm X-Pro2 Fujifilm XF 27mm F2.8 Fujifilm XF 35mm F2 R WR Fujifilm XF 23mm F2 R WR
adamandbean
Re: I shoot with a prime lens.
I might just get both because the e10 without the kit lens is only 40 dollars cheaper !
Thanks again to all of you
Jeff4500
Jeff4500 Senior Member • Posts: 1,921
I use the 14-42 R as my video lens, and the Pany 14mm as my match for the Sigma 30mm. I often use the GWC1 as my wide angle of choice. My 14mm seems to be very good at 22mm with the GWC1 (Not quite as good as the Nikkor 12-24 I have, but good enough for most microstock agencies) and is easily fix of any distortion or fringe in either LR or ACR//Photoshop. The Kit zoom is very good for video and is very cheap (when gotten with camera or refurbed).
For me each is a different tools that has its uses.
 Jeff4500's gear list:Jeff4500's gear list
Panasonic 12-35mm F2.8 Panasonic Lumix DMC-GX85 Panasonic Lumix DC-G9 Panasonic Lumix DC-GH6 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 +9 more
baxters Veteran Member • Posts: 5,319
Always take the deal and get the 14-42 II as part of the bundle. If everyone had to pay the stand alone $299 MSRP price for the 14-42, no one would ever buy it.
 baxters's gear list:baxters's gear list
Olympus OM-D E-M5 Panasonic Lumix DMC-GX85 Olympus M.Zuiko Digital ED 75mm F1.8 Olympus M.Zuiko Digital 17mm F1.8
The kit lens is an incredible value for only $40.  Don't NOT pick it up for that price.
Hen3ry
Hen3ry Forum Pro • Posts: 18,218
Hi Adam
A difficult choice, actually. My experience with the Oly 14-42 II R was that it was pretty much on an IQ par with the Panny 14.
However, I tended to use the 14 as my walk around lens on the E-PL3 with the 45 or 40-150 in my pocket/pack.
The 14's advantages were:
  • Very compact size and light weight
  • The extra stop - f2.5 vs f3.5
  • Better rendering of lights within the frame, e.g. a bit of starry stuff where the zoom produced a blob (which was actually more accurate, of course!).
The 14-42's advantages were:
  • Very light and compact when compared with most other lenses - but it stuck out twice as far as the 14
  • The extra length if you wanted it out to 42.
I have now switched to the Panny G6 and also switched my walk around lens to the Panny 12-32. I like that bit of extra width and the option for a bit of zoom in a very compact package. I back it up with the Panny 45-150 in my pocket/pack.
Cheers, geoff
Geoffrey Heard
Down and out in Rabaul in the South Pacific
http://rabaulpng.com/we-are-all-traveling-throug/i-waited-51-years-for-tavur.html
 Hen3ry's gear list:Hen3ry's gear list
Panasonic Lumix DMC-GX7 Panasonic G85 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Olympus M.Zuiko Digital 45mm F1.8 Panasonic Lumix G X Vario PZ 45-175mm F4.0-5.6 ASPH OIS +7 more
adamandbean
Great, I will get it with the camera.
Many thanks,
Adam
