Is this barrelling what was supposed to be firmware fixed?
Started Sep 29, 2014 | Discussions
frascati Regular Member • Posts: 115
EX2F RAW. Saved as Jpeg. No distortion correction.
Same vantage. Out of camera Jpeg. No correction.
I had read that this camera had barrel distortion issues in RAW that were reasonably corrected with the last firmware 305244. I've installed it and verified installation via EXIF data.
Auto Jpeg was f/2.  RAW original was f/2.5. No zoom. Nearly identical vantage.
New camera with about 250 shots under its belt. Went back and checked other RAW images and see it now. This just happened to be one of the first with clearly evident lines of reference.
Is this the best I can expect? I'm a relative beginner. Was pre upgrade barreling even worse and this is actually up to expectations for a lens/processer in this range of performance?
Distortion in raw is pretty normal for a 24mm wide lens, nothing that can't be fixed in the automatic Jpeg processing of the EX2f, or in Photoshop etc. later on\
That's from an early review even pre-update. What is "automatic Jpeg processing"? What's the simplest way to deal with this if one opts to take the camera out and shoot all day in RAW? Batch process the lot prior to any other image specific corrections? Correct it in-camera (is this possible?) before downloading for post processing?
Samsung EX2F
OrdinarilyInordinate
OrdinarilyInordinate Veteran Member • Posts: 3,741
Re: Is this barrelling what was supposed to be firmware fixed?
Is distortion correction enabled in the camera menu?  I think generally that's only done for JPEGs.  RAW distortion is fixed later outside of the camera (unless you convert to JPEG in-camera).
 OrdinarilyInordinate's gear list:OrdinarilyInordinate's gear list
Nikon Coolpix A Fujifilm X-T2 Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Fujifilm XF 23mm F1.4 R Fujifilm XF 56mm F1.2 R +4 more
OP frascati Regular Member • Posts: 115
From another review....
When converting raw files without correction, barrel distortion at wide angle is much higher, at about 2.8%.... Samsung's bundled Raw Converter software automatically reduces geometric distortion (as does Adobe Camera Raw), producing distortion results very similar to in-camera JPEGs. We expect high distortion at wide angle for smaller lenses though, so it's nothing to be overly concerned about unless you are using a raw converter which does not understand the embedded "opcodes" to perform distortion corrections automatically. There is however going to be some loss of resolution and possible interpolation artifacts as a result of such strong correction, because pixels in the corners of the frame are being "stretched" to correct for the distortion
I boldened the text.
So this will be corrected as a matter of course. Does not introduce another step as I worried about.
Is the bold script above possibly less of a concern since the last firmware update? Last update was claimed to remedy some of the firmware's handling of RAW barrel distortion. Anyone's experience?
All considered what would be the point, at all, in correcting in-camera barrel distortion resulting from the lens design compromises (compactness, speed, etc) if it's simply shifting responsibility for this correction from earlier to later in the image processing chain? Seems illogical that in-camera correction prior to laptop RAW conversion would change the gist of the bold text above. No?
Additionally, shouldn't all in bold above apply to images shot in Jpeg? Some software/firmware must correct this lens's barrel distortion to wind up with a Jpeg in all cases.
Is EX2F's optical barrel distortion, in this class of camera, that bad comparatively?
Bottom line is that I'm trying to weigh all the pros/cons on this camera after three days of opening the box as early as possible to decide if it's a keeper.
Does a photographer learn to work within/around the limits of a camera's weak spots?  Recognize the need to shoot at longer focal lengths when barreling effects are going to be too obvious in a shot with lots of geometric reference?
ttbek Veteran Member • Posts: 4,869
I'm not sure what the update did, or said it did...
I don't really understand how this relates, that would be fixing it for the raw -> jpeg conversion in camera, nothing to do with your raw -> jpeg conversions in outside software unless it's following the directives in the raw.
It's never been much of a concern. The only people that that should really give pause to are perhaps serious landscape shooters that need the finest detail possible all the way out to the corners.
I'm not sure I understood this question, could you rephrase it?
Right, it will not change it.
Yes, absolutely.
No, I'll quote from what you quoted, "We expect high distortion at wide angle for smaller lenses though, so it's nothing to be overly concerned about."  It's expected because it is common.
Yes, at least the good ones do.  The masters from long ago were dealing with many more limitations than we are now and still pulled off some great results.
It's a consideration.
Alright, I was answering your questions as best I could through there, but I'm not sure I followed what you were asking all the way through.
Let's concern ourselves with only two processing paths, then we'll break down the 2nd one.
Path 1: shutter button -> raw -> in camera jpeg processing (which includes the distortion correction, and CA correction, white balance, filters, etc..) -> jpeg from the camera    This is what happens if you shoot jpeg, the raw is then discarded by the camera.  If you shoot raw+jpeg, then the raw file is also kept and you can use it for path 2.
Path 2: shutter button -> raw -> raw conversion software -> jpeg, or png, or tiff, etc..  This is the path for processing raws that you've been trying to add to your skillset.
Lets talk about the raw for a bit.  In addition to the image data the raw file can also contain data about the distortion and parameters for correcting it.  Some raw processors read this data and do it automatically, in some it is an option that must be selected, and in some the software doesn't know how to use the data.  Aside from this data in the raw, the software can get the information from another source, lens profiles, which are created for correction distortion, chromatic aberration, etc...  The lens profile may differ a little from the data in the raw file (it could be a better or worse correction than what the camera manufacturer does for the in camera jpegs).  In the case where the raw converter you're using can't handle the data in the raw, and can't use a lens profile (either because it doesn't support lens profiles at all or because a lens profile for your lens doesn't exist), then you may need to manually fix the distortion in the program (if it even supports that, some you're just entirely stuck with the distortion and would need to fix it in a different program after conversion), this is the only case that paragraph was implying to be concerned about.
Ok, so how we're going to deal with distortion in the raw file depends greatly on which raw conversion software you're using.  Basically though, it will usually amount to needing to check a box for lens corrections.
My favorite converter (Darktable) actually lacks many Samsung lens profiles, it uses the lensfun database, it's easy enough to have them add your lenses, but I would need to stop being lazy and send them in some sample shots of the right sorts of scenes.. I should do that sometime soon.
 ttbek's gear list:ttbek's gear list
Canon PowerShot SX10 IS Canon EOS 5D Samsung NX300 Canon EOS Rebel SL1 Samsung NX30 +37 more
Thank you very much for describing that for me.  I'll digest it as I go along.  Sorry for the convoluted question originally.
I just noticed something interesting.  The RAW image above never was converted with Samsung's RAW converter.  I'd viewed it in Faststone Viewer which provides some quick and easy processing then saved it as Jpeg.
I was looking at a dozen RAW files today in that viewer since it's such a quick way to preview shots and noticed vignetting.  It's there in the second image above.  I wondered what the heck?  Scared me for a sec until I viewed a few images I'd converted yesterday with the RAW converter.  How does the converter deal with vignetting?  Must be a permanent part of the image.  Side by side I noticed that conversion is a crop of the RAW image just enough to eliminate the vignetting.  Is this common to other cameras/lenses when shooting RAW.
I realize many of the questions and concerns I've flooded this board with over the weekend are bit inappropriate overall.  Most of them turn out to be questions any photographer ought to have the patience and diligence to resolve on his own, but I felt under pressure to evaluate this camera in a great hurry.  So thank you very much for the assistance here and keeping me from getting too overwrought in the process.
Vignetting is easily corrected in post-processing--for RAW and JPEG.  It happens with all cameras of all brands.  Some software allows you to fix camera distortion and vignetting in one step (like Adobe Lightroom--just click on the option and it brightens the image and stretches it according to a lens profile).
