Re: J-j-j-j-j-j-jitters here!
Vesku wrote:
Aberaeron wrote:
I don't do 4K and my upload speed wouldn't make it practical to post, but I have just shot another 1080 50P short video hand holding as still as possible, No editing, just processed through HandBrake to compress it slightly. Its come out as 720P on Youtube but I can't help that. Why 4K? It has not been a limiting factor up 'till now. So what you are effectively saying is that 1080 isn't a problem? Well it certainly isn't for me, so you'd be correct there. Here we go, shot five minutes ago, fresh for you two and any others to see for themselves whether it is worthy of regurgitating criticism regularly.
https://youtu.be/NyaguvTKIVI
Thank you for testing this phenemenom again. If you cant see any issue dont try to see it harder. Once you see it you see it all the time. The vibration is very small amount of sideways rapid movement, like OIS over reacting the hand movement. I have many clips when the issue is minimal. It is mostly visible in my nature videos when I try to keep the camera very still.
I dont want to tease anyone. I just want to share information and yes I am quite frustrated having very expensive gear not working as I like. I can still correct that vibration completely with Mercalli stab software. It has its own issues too, unfortunately.
Well I have to say, I can clearly see the jittering in your (Aberaeron's) sample footage however it's not as bad as what I see in my own footage, which I tend to shoot in cinema 4k 24p. I can point out where you can see the jittering in your above example, but as Vesku says if you don't notice it then perhaps you would prefer to stay happily oblivious?
The reason I checked back into this thread was not to "prove" anyones side of the argument but rather to see if the GX80 improved the handling of the OIS in this lens, which based on others reports it does, so that's great!
I might do some further tests with my own equipment (GH4) to see if higher frame rates reduce the intensity of the vibrations coming out of the 14-140mm II OIS. I'm also going to try physically supporting the lens by the hood to see if I can replicate Vesku's improvements there.
Anyhow bottom line for me is this lens does exhibit strange high frequency vibrations when handled for a static shot. Perhaps its comes down to personal tolerances but for anyone to claim this issue is non existent, is just not true and if you're planning on using this lens for video on any body that isn't the gx80/85 you should be aware of it.
Sample, straight from camera, for you to observe the jitters. Shot last month on holiday in Portugal (yes I still use the lens and about half the clips go through Mercalli before hitting my edit timeline.)
https://youtu.be/r6eOktGTE1c
