Panasonic 14-140 II OIS jitters when shooting video
Started Sep 26, 2014 | Discussions
OP Vesku Senior Member • Posts: 2,964
Re: Panasonic 14-140 II OIS jitters when shooting video
Joe Foreman wrote:
Vesku wrote:
Is there new users with this problem?
I've been shooting a fair bit with this lens lately and I have noticed a variation in the frequency and intensity of the jittering from shot to shot. Unfortunately I can't pinpoint any correlation between settings/environment and the jitters.
Some observations: I think its been previously mentioned but slow pans seem to record with far less jitter than stationary shots with all other things equal. Using a monopod seems to reduce the number of shots that have excessive jittering. Using ExTeleConv exhibits vision with extreme jitter and cmos jello. This situation is improved significantly with power OIS turned off (however good luck holding that shot still at the long end without a tripod).
Generally now when I pull the video off the sd card I have a quick look through all the wilds and then drop the worst offenders in Mercalli V4 and just use quick repair for CMOS jitters or Intensive Repair for ExTeleConv shots + any general stabalizing as required. Not a bad solution but obviously an extra step that shouldn't really be necessary.
Joe.
Thanks for telling your experiences. Sometimes I wonder that I am the only one who sees that issue.
I must stabilize all my handheld clips with Mercalli V4. It is frustrating too because I cant set stabilizing settings before using batch stabilize feature (the batch is fully automatic and does wrong things). If I have to stabilize for example 400 clips it is a very slow process and there is also memory issues in Mercalli. It is very strange that Mercalli has no "save settings" feature. Mercalli also uses super high bitrates even with "medium" codec setting. I have seen almost 300Mbs bitrates with GH4 100Mbs source files. I wonder what "high" might do.
It is strange that I use 100-300mm lens handheld at 300mm and I have no need to stabilize those video clips. With 14-140mm II I must stabilize all the 14mm clips???
Jon555 Veteran Member • Posts: 7,722
Never tried video at 600mm equiv - does it really not suck?
 Jon555's gear list:Jon555's gear list
Nikon Coolpix 950 Fujifilm FinePix Real 3D W3 Sony RX100 V Canon EOS 5DS R Panasonic GH5 +31 more
Video handheld with at 300mm (600mm eq) is just OK for me. It is impossible to hold image "locked" but the movement is natural and smooth and there is no horrible fast jitter like with 14-140mm even at 14mm.
I can even shoot 300mm + ex-tele (1440mm eq) handheld and prefer it to 14-140mm II.
When I stabilize 14-140mm II clips things change and the results are very good.
lacix
lacix Contributing Member • Posts: 736
....may not be a lens problem!
I don't have any jitter problem when shooting video with GM5 and the lens 14-140 II OIS!
I tried with different focal lenght!
UBL
 lacix's gear list:lacix's gear list
Canon EOS 5D Mark II Panasonic Lumix DMC-GM5 Sony a7R IV Canon EF 50mm f/1.2L USM Panasonic Leica DG Macro-Elmarit 45mm F2.8 ASPH OIS +10 more
Re: ....may not be a lens problem!
Really? Handheld?
What shutter speed you use? My jittering issue is less visible at 1/30s-1/50s.
Have you tried to shoot very stationary clip (holding still) handheld?
Have you seen these jittering examples:
https://www.youtube.com/watch?v=cAKHpXpYffU
https://www.youtube.com/watch?v=WLNSg3Wz7ps
https://www.youtube.com/watch?v=Vf1i3Prg8X0
https://vimeo.com/115764239
https://www.youtube.com/watch?v=jLJcesfvNc8
https://www.youtube.com/watch?v=-Ev14Zn7a2I
https://www.youtube.com/watch?v=iO5DtFM9vkM
https://www.youtube.com/watch?v=YwIj...p-ax4fLspsNtEp
https://www.youtube.com/watch?v=UlGSjthkgzo
lacix
Yeah, I see your problem!
Well, I always trying to keep the shutter-speed at least double (1/100) of the f/s. The GM5 f/s is 50 f/s max. and yes I do mostly handheld videos. The firmware version of body and the lens is 1.0 on both!
UBL
vakhariasb Forum Member • Posts: 83
So, after some deliberation, I settled for the older version 14-140 F/4.0-5.8. I got a pre-owned copy and it seems to be fine. I did not notice any jitter in the small test video that I took.
It's not as sharp as the new one, but I found mine was okay and the stabiliser was better. I was using mine for longer focal length video until they fixed the 35-100. I hope you have fun with it.
AdamT
AdamT Forum Pro • Posts: 62,285
The Mk1 was designed first and foremost as a video lens - stills use was very secondary so smooth action, fast AF and more to the point perfect OIS were far more important than compact size or optical ability (which the Mk-II excels in beyond expectations) .... it was originally only available as part of the GH1 kit if I remember rightly then became available as a separate item
It`s a shame that Panasonic are unwilling to address the video jitter and shutter shock issues with the Mk2 - the fact that the lens is that good optically, it drove me to moving to an Olympus camera to dodge the shutter shock problem speaks volumes for both the lens and Panasonic's laziness on the matter ......
If Tamron had put their Power-OIS beating VC in their example , I may have given it a go but they didn`t and it`s not as good as the Panny Mk2 optically either (though better than the Oly 14-150 Mk1 ) .
Canon PowerShot SX50 HS Nikon D3 Panasonic Lumix DMC-GH3 Nikon Z7 Nikon Z9
14-140 II OIS jitters - NEW TEST
Fredrik Gløckner made an OIS comparison of 1 and 2 versions of that lens:
http://m43photo.blogspot.fi/2015/05/lumix-14-140mm-ois-jitter.html#more
He said that he cant see the difference of lenses or any significant vibration in mk2 version. " I don't see any adverse jitter effects with any of the lenses."
The Youtube sample is the new 1080P50 and the compression is so bad that there is no details to see any micro jitter.
https://www.youtube.com/watch?v=6zAebHclAas
The sample is also shooted with constant panning and moving so the micro jitter which exists only in stationary clips cant be seen. I would be happy to see a stationary comparison with 4k 30P or at least 1080 30P in Youtube.
I watched my jittery GH4/ 14-140 II clips with 4k tv and I think the jitter was a bit less disturbing in 4k because tv showed native resolution without down scaling issues and because motion enhancement smoothed or averaged the jitter too.
I hope that now when G7 4k kits with that lens comes people would notice that issue and Panasonic will make a FW fix.
Re: Anything to get you to...
Fredrik Glckner wrote:
AdamT wrote:
Keep Whining Vesku - it worked for the 35-100 !!
Did the firmware update reallu change that much? I have before/after footage here, and there is a quite small difference in the video performance:
Why did you make a new test of 14-140mm lenses video OIS with panning and moving clips because the jitter issue is reported to occur just in stationary hand held video clips? Can you test also stationary clips?
Setter Dog Veteran Member • Posts: 5,768
I just waded through this long thread and, to be honest, it spooked me a little bit. I realize it's an old thread and there may be updated versions of the 14-140 II on the G7.
I'm hoping someone can help me with a decision I have to make. I have a G7 on order, primarily to take advantage of the 4K photo modes. I have 4K in my FZ1000 and find that pulling stills from the 4K is just a great way to get the perfect attitude on animals and birds.
Right now, I have ordered the G7 w/14-140mm, but am seriously considering a change to the 14-42 and adding a zoom lens to the bundle. I used m43 several years ago and had the 45-175mm. I liked it fine. I have never used the 45-150mm or the 45-200mm, though both seem to get good reviews.
Question for users,....which of these lenses is most likely to give me good results with the 4K video. Another way of asking that is which lens has the best image stabilization?
I'll appreciate any input. Thanks!
Jack
Corkcampbell
Corkcampbell Forum Pro • Posts: 18,895
I have read that the only changes on the 14-140 that comes with...
I have read (m43 rumors site) that the changes in the 14-140 lens that ships with the G7 has only cosmetic changes, such as removing the "HD" label. I am also looking at this lens and don't know whether to buy it or not, so am paying attention to these threads. It would be used mostly for video. Note: I have the 45-175 and like it.
"Knowledge is good." Emil Faber
 Corkcampbell's gear list:Corkcampbell's gear list
Sigma DP2 Merrill Sony Cyber-shot DSC-RX10 Sony RX100 III Sony RX10 III Leica C-Lux +8 more
Fredrik Glckner Veteran Member • Posts: 3,894
Re: I have read that the only changes on the 14-140 that comes with...
Here, I have a rather long 4K video recorded with the GH4 and 14-140mm II and the 100-300mm:
https://www.youtube.com/watch?v=iY0-GHGO2C4
Much of it was recorded on a tripod, but 2:05 - 2.40 is handheld, with the 14-140mm II. Do you see any jittering?
Hi Cork,...thanks for the 45-175mm comments. I enjoyed the lens when I had it several years ago. I strayed from M43 but am back now, waiting for the G7.
Jack
Fredrik,.....thanks for posting that video. If it has any jitters in it, these old eyes sure can't see them. My buddy has the G7 on order with this lens. He'll be impressed and this will probably give him confidence that he's made the right choice.
Sure would be nice to find a You Tube or something showing the 14-140 shooting 4K with the G7 or maybe the GH4.
Jack
There are some "jitters" in the video that I can see, but they are from the sequences shot with the 100-300mm lens at 300mm on a tripod, and are due to using a too light tripod. At this very long focal length, a very sturdy tripod is needed for the ultimate stability.
I can see that rapid little vibration in your example. There is much subject movement in foreground but the background is not stable. The AF is breathing and there may even be some post stabilization but I can still see that familiar jittering.
Jack
You dont need 4k to see that jittering. Try these links.
kitesurfer New Member • Posts: 6
The jitters are there for sure. I have been using this lens as my primary lens while traveling for the past 6 months and you will see the jitters once you are trying to take a stationary video. I will link a clip so you can see it.
It took me a while to actually notice the jitter, but after I did I can see it in almost every clip people have posted. Vesku has a thread and picked random videos to show in it and when I first watched those clips prior to him posting about the jitter I thought they looked amazing and I never noticed it. Once I was made aware of the jitter I notice it ever time.
My question is in Photoshop for post editing, how are you guys fixing the jitter? Which settings are you finding you have to use to remove it?
Thank you
Look at all the shots in here : https://vimeo.com/129635294
Re: Panasonic 14-140 II vs Canon 70-200
What happens when those lenses are in the same tripod rig. Canon is very steady but Panasonic vibrates very ugly in TRIPOD!
https://www.youtube.com/watch?v=UQlAvRuTYIQ
