Panasonic 14-140 II OIS jitters when shooting video
Started Sep 26, 2014 | Discussions
vakhariasb Forum Member • Posts: 83
Re: Panasonic 14-140 II OIS jitters when shooting video
AdamT wrote:
Yes some people are saying that it is better to shoot handheld without the OIS with that lens. Lets see if people are going to prefer Olympus for video because of its amazing IBIS.
I very much doubt it , Oly video is and always was very poor and IBIS makes such a racket that it`ll wreck the audio unless a long shotgun mic is used . I`d put the 1st generation GF1 (yes G*F*) over the latest Oly for video .. answer is not to use that lens on your panny - either get the lens which was designed for video first and foremost (the Mk1 14-140) , use a non-superzoom or shoot from a tripod
I am not getting this. So, should I go for the first generation 14-140 from Panasonic? Or something else for video?
The GX7 has no way to add shotgun mic or external accessory. So, audio is going to be poor anyway.
AdamT
AdamT Forum Pro • Posts: 62,285
Whichever you`d like - cheapest method is to use a tripod and switch off the OIS on the lens you have - if you MUST have a superzoom and do lots of Vid, get the Mk1 14-140 but use the Mk2 for stills as it`s significantly better optically ... if you don`t need the reach for vid then a used 14-42-IIHD on the cheap is both Video friendly and superb optically
not as poor as it would be with Oly`s IBIS hissing away like a rampant Adder .. Audio can be recorded with an external recorder if Pro quality is needed , you can`t do anything to improve Oly Video except not use an Oly in the first place .
the lack of Mic Port on the GX7 was stupid in the extreme, Japanese camera makers do stuff like that to protect other models in the range but all it does is shoot them in the foot, they all do it, canon and Fuji are the worst.
I got a used and tatty LF1 for casual video , the quality is very good (it`s a Panasonic), slips in a shirt pocket and can be remoted, inc Zoom with an iPhone if needed, I`d much rather use the GX7 for serious stuff though even with the built in mics.
Canon PowerShot SX50 HS Nikon D3 Panasonic Lumix DMC-GH3 Nikon Z7 Nikon Z9
OP Vesku Senior Member • Posts: 2,964
What might Panasonic think about that advice? Mk1 for video, mk2 for photos - what a joy to change lenses in hybrid photography.
AdamT
They must know something as both are still on the shelves new ...
Hi AdamT,
I appreciate your advise. However, I do not have the liberty to buy and carry multiple lenses. So, the option of buying Mk2 AND MK1 does not suit me at all.
Probably I should look at 35-100mm from Panasonic. The cheaper version is with f/4.0-5.6. Hopefully that one is good for video and stills and does not have any stabilization issues and no zoom mechanism noise issues?
AdamT
the Panny 45-150 has better range and is a damn sight cheaper - also compact (same size as the 14-140 but a lot lighter) and sharp end to end .. I sold mine after getting the 14-140-II as it was redundant but I only ever shoot Video unstabilized from a tripod with the GX7
Adrian Harris
Adrian Harris Veteran Member • Posts: 7,708
Re: Anything to get you to...
AdamT wrote:
...stop whining is aces in my book.
It`s the squeaky wheel which gets the grease ..... Shutting him up will only let Panasonic get away with it, the more people whine, the better chance of panny fixing it .... don't you want that ?
Keep Whining Vesku - it worked for the 35-100 !!
Well said Adam.
...sadly there are to many 'fan boys' on all these forums and anyone that points out faults always get attacked for being a voice of reason. It is easy to understand why progress in certain areas regarding correcting faults is so slow.
 Adrian Harris's gear list:Adrian Harris's gear list
Sony RX100 Panasonic Lumix DMC-G1 Sony SLT-A77 Panasonic Lumix DMC-GX7 Panasonic Lumix DMC-GX8 +1 more
AdamT
The Japanese are the worst for not admitting to mistakes out of sheer pride and then stubbornly repeating them to prove they "weren`t mistakes" (so are they deliberate design flaws ?) .
Defending stuff like this OIS issue and the even worse numerous issues with the Oly EM1 is ludicrous in the extreme - Purchase defenders are far worse than trolls on these forums and sadly DPR has far more than its fair share
While I have not read much about the 45-150, I found that the $1000 lens (35-100 f/2.8) also has OIS issues.
http://vimeo.com/111664303
Jon555 Veteran Member • Posts: 7,722
New firmware came out for the 35-100 f2.8 recently to improve the OIS in video - I find it a good improvement.
 Jon555's gear list:Jon555's gear list
Nikon Coolpix 950 Fujifilm FinePix Real 3D W3 Sony RX100 V Canon EOS 5DS R Panasonic GH5 +31 more
I am glad that Panasonic did acknowledge this issue and solved it (almost?).
I hope they do so for the less expensive version as well 35-100, f3.5-5.6
Rspearing57 New Member • Posts: 14
From what I've read there's no fix for this, so what I'd do is switch to the older model which I can confirm doesn't suffer from the problem. It is a slight step down I know, being f4-5.8. But we're only talking half a stop so it's a minor sacrifice in the grand scheme of things. Plus you'd naturally switch to a faster lens for lower light situations whatever version you have.
It's just a shame their shorter 2.8 zoom lenses suffer from the issue too... I'm hoping by the time I decide to invest in a short zoom their fixed versions will be available which I heard they were making...
Rhodri
AdamT
there`s quite a significant drop in optical quality with the older lens and it`s quite a bit bigger and heavier too - choice depends on where your usage for a superzoom lies - for me, it`s 99% stills so it`s the Mk2 that wins out - for someone who does mostly Video, the Mk1 would be the choice
yeh, that makes sense. I wouldn't be surprised if there was barely any discernible difference in optical quality when in 1080p and after the compression images get with video.
I guess it's down to how much you use the gh3 for stills Vesku?
I usually carry my camera+lens (GH4) in a small bag and shoot both stills and video. I dont like changing lenses. If I am in hiking trip or in some event I use just one lens and I want versatile reach and compact package. In very dark I use 20mm f1.7 pancace and sometimes 100-300mm with sports and nature.
14-140mm f3.5 is usually enough bright indoors when using 4k video. Noise is very fine grain. I like f3.5 because it has more sharpness range than faster primes and of course stabilization is a problem with primes and focusing too.
Henry Richardson Forum Pro • Posts: 21,959
Well said
Well said.
Henry Richardson
http://www.bakubo.com
I think that the worst misinformation is that reviewers of many sites dont tell us about that issue which is so obvious that an experienced user can see it instantly when watching results.
I wonder if there is any solution for that video OIS jittering issue. Seems that Panasonic is not going to make any FW fix or maybe they are really slow.
I have found that shooting at full aperture gives a little less vibration. I also wonder if there is some sample variation and my lens is in the worst end.
Is there new users with this problem?
AdamT
looks like mentioning it on here all the time isn`t working - maybe you should constantly bombard Panasonic with Emails
I`m not having a go Vesku - I mean, it . you have more staying power over this issue than anyone else so that`s the best way IMO
Joe Foreman
Joe Foreman New Member • Posts: 13
I've been shooting a fair bit with this lens lately and I have noticed a variation in the frequency and intensity of the jittering from shot to shot. Unfortunately I can't pinpoint any correlation between settings/environment and the jitters.
Some observations: I think its been previously mentioned but slow pans seem to record with far less jitter than stationary shots with all other things equal. Using a monopod seems to reduce the number of shots that have excessive jittering. Using ExTeleConv exhibits vision with extreme jitter and cmos jello. This situation is improved significantly with power OIS turned off (however good luck holding that shot still at the long end without a tripod).
Generally now when I pull the video off the sd card I have a quick look through all the wilds and then drop the worst offenders in Mercalli V4 and just use quick repair for CMOS jitters or Intensive Repair for ExTeleConv shots + any general stabalizing as required. Not a bad solution but obviously an extra step that shouldn't really be necessary.
Joe.
 Joe Foreman's gear list:Joe Foreman's gear list
Panasonic Lumix DMC-GX7 Panasonic Lumix DMC-GH4 Panasonic Lumix G 20mm F1.7 ASPH Sigma 18-35mm F1.8 DC HSM Art Panasonic Lumix G Vario 14-140mm F3.5-5.6 O.I.S +3 more
