Re: Panasonic 14-140 II OIS jitters when shooting video
Vesku wrote:
Joe Foreman wrote:
Just registered to join the conversation and say I agree wholeheartedly.
I just recently purchased this lens and will take delivery of it later this week. I'll be sure to test it and report back but by the sounds of it I'm expecting it to display the cmos jitter when the Power OIS is engaged. I'll definitely make some noise over here (AUS) and let a few more people at Panasonic know about it. The squeaky wheel.....
Logic would dictate that a FW revision should be able to alleviate, or at least minimise the issue, as it did for the pro lens, BUT people need to make some noise. Panasonic are not likely to allocate resources to fixing this if they don't have to. So in that regards I say a big thank you to Vesku who is on a mission to make this known.
Thanks for support. I am trying to get people making noise about this jitter issue. Panasonic can fix that via FW update if they want.
Here is one more depressing example of that Panasonic 14-140mm f3.5-5.6 OIS jitter.
https://www.youtube.com/watch?v=S82ff3rKKzI
Hey just a quick update. I received my lens today and within the first 5 minutes confirmed that the CMOS jitter was present and VERY obvious during video recording with the POWER OIS on at both 14mm and 140mm.
I could see in on the viewfinder of my GX7 and even more clearly on a 27" iMac screen. It's looks horrible and makes the vision look "cheap". In my samples I also clearly saw shutter-shock using the manual shutter under 1/500. E-shutter images looked very nice.
A couple of things I also quickly tested:
- Video record with e-shutter active (not sure this makes any diff) = CMOS jitter present.
- Ex Tele Conv whilst video recording = CMOS jitter present.
- Video recorded without Power OIS = no jitter
I also quickly tested a few image stabilisation methods with the tools I had and I can tell you both FCPX in-built stabiliser and After Effects Warp Stabiliser do NOT eliminate the jitters. The image still appears "non-solid". I guess its Prodad Mercalli v4 or bust...
This is looking more an more like a widespread problem. I can post samples but its so obvious that many of the previous samples posted here illustrate the problem clearly already.
