Which wide angle lens is best. Olympus 12mm F2.0 , SLR Magic 12mm T1.6 or Rokinin 12mm T2.2
Started Sep 25, 2014 | Discussions
Jacob James Junior Member • Posts: 48
I'm looking to buy a wide angle lens for my Gh4. I shoot mostly video but occasionally photo weddings also. I was originally going to get the SLR Magic but I've seen some tests and it seems a lot less sharper than the Olympus. I currently own the Voigtlander 17.5 0.95 and the Olympus 45mm 1.8. I love the sharpness of the Oly and the photo taking ease with the AF and the camera compatibility. I love my Voigtlander and the video use and I'm a little worried that The Oly 12mm will not be great for video. Is the focus smooth for rack focusing? I've never owned a Rokinon but the price makes me interested.
Any feedback is greatly appreciated as it took me a while to save up for this purchase and I want it to go well. Thanks!
 Jacob James's gear list:Jacob James's gear list
Sony 24-70mm F2.8 ZA SSM Carl Zeiss Vario-Sonnar T*
Olympus M.Zuiko Digital ED 12mm 1:2 Panasonic Lumix DMC-GH4
belcanto Contributing Member • Posts: 557
Re: Which wide angle lens is best. Olympus 12mm F2.0 , SLR Magic 12mm T1.6 or Rokinin 12mm T2.2
And then you have the Kowa prominar 12mm. And if you strech a bit the new CV 10.5mm . I have the olympus 12/2 wich I choose over the slr based on pictures I found on the net. Since I'm a fan of mf lenses I got my eyes on the Kowa. I'll wait for reviews first . I don't do video so I'm not any help there.
Kjell
 belcanto's gear list:belcanto's gear list
Fujifilm XF10 Fujifilm X-T1 Panasonic G85 Voigtlander Nokton 25mm F0.95 +11 more
Chad Hardy
Chad Hardy Senior Member • Posts: 1,192
I just have a hard time considering a 24mm FF FOV as wide angle.  What do other's think?  for me it needs to be 18mm or less
 Chad Hardy's gear list:Chad Hardy's gear list
Fujifilm X-T1 Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Fujifilm XF 56mm F1.2 R Sony RX100 III Olympus E-M1 +16 more
Mark Thornton Veteran Member • Posts: 4,570
It is certainly wide angle, but not ultra wide angle (which is often deemed to be lenses shorter than 24mm equivalent)
http://en.wikipedia.org/wiki/Ultra_wide_angle_lens
Mark
 Mark Thornton's gear list:Mark Thornton's gear list
Panasonic Lumix DMC-GX1 Panasonic Lumix DC-GX9 Olympus Zuiko Digital 11-22mm 1:2.8-3.5 Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital ED 12mm 1:2 +8 more
Max Pegler
Max Pegler Regular Member • Posts: 414
Consider the original 4/3s lenses as well, such as the 11-22mm. I like it a lot. With adapter, it'll probably work out cheaper.
To answer you question, I can't warm to the SLR magic. By contrast, the Voit 17.5mm is my favourite.
The SLR magic has the focus & aperture round the other way to the Voit, which I don't think I'll ever get used to.  For filters it needs a 77mm, a 72mm shows in the corners.
The aperture drifts, because it's a movie lenses. No click stops.
Wide open its so soft at the edges its gooey. ( No distortion correction is possible with these manual lenses). The work-around is to centre your subject, and crop to square.
Just back on the 11-22mm, being a 4/3s it's telecentric so no in-camera software correction is needed for the edges to be sharp.
Me? I'm waiting for the upcoming Voit 10mm. (or is it 10.5mm?) Then the SLR magic is up for sale.
Regards
Max P
 Max Pegler's gear list:Max Pegler's gear list
Olympus E-10 Olympus E-1 Olympus E-3 Olympus E-510 Olympus E-520 +42 more
OP Jacob James Junior Member • Posts: 48
Thanks for the response Max. I'm not familiar at all with original 4/3 lenses, I'll look into it. I just came to micro 4/3 recently. The new Voigt you speak of sounds amazing. But when and how much?
Leo Veteran Member • Posts: 6,445
A 24mm lens is a wide angle lens, however I do understand what you said and agree. Getting 24mm while having 28mm is not an upgrade to spend $. I am thinking of Rokinon 7.5mm.
Leo
 Leo's gear list:Leo's gear list
Pentax K-S2 Pentax smc DA 16-45mm F4 ED AL HD Pentax DA 55-300mm F4.0-5.8 ED WR
So you're saying since I already have a 17.5 mm getting a 12mm wouldn't be much different?
Max Pegler
No-one knows yet! Have a search on Four Thirds Rumours,  there's a bit there, e.g. some pics & specs posted on Sept 16.
http://www.43rumors.com
Regards
Max P
Skeeterbytes Forum Pro • Posts: 23,186
Have probably never shot video with the mZD12, so take this with a grain of salt. The AF is quick, responsive and basically silent. The snap MF feature is a pleasure to use and I can operate it smoothly, which might be a factor in rack-focusing. And of course, it's small as a small thing. Highly recommended, demo or rent one if you can.
No experience with the others you mention; everything else I have in that focal length is a zoom. Someone mentioned the 11-22, which is a fine WA zoom--really well corrected and relatively sharp and contrasty. AF will be a disaster on anything not an E-M1 and MF is somewhat audible, so you'd want to be using an isolated mic (you probably do). The 12-60 has mechanical MF that's silent and is a great lens, sharper than the 11-22. Pretty big, though!
Good luck,
Rick
"Whiskey is for drinking, digicams are for fighting over."
—Mark Twain
In my post I said: "Getting 24mm while having 28mm is not an upgrade to spend $."
If one already has 14mm lens with about 76 FOV then 12mm lens of the same class with about 84 FOV in my opinion does not worth to spend money. However, having 14-42mm II R F3.5-5.6 and buying a 12mm F2.0 is a different story. The Mark's reply is related only to FOV for equivalent lenses - that is how I read it.
My post express my opinion without spending your money
Currently, I am looking for a wide lens. However, having a sharp 14-45mm F3.5-5.6 lens it does not make much sense from FOV point to get a 12-32mm F3.5-5.6. - for myself. The 12-32mm is a very small and light lens and I would buy it for its size and weight only.
Leo
300Bee Regular Member • Posts: 308
I have a Rokinon 12mm, it is very good except I have to do my own infinity marker, but not an issue.  The focus ring is slightly tighter than I want.  It is also not the easiest to mount because the aperture ring is sitting quite close to the end.   The Rokinon 10mm would be better of being wide, but it is way too big and heavy considering I'm using it with a small camera to travel with.
Chad Hardy
Mark
You got it Mark!  I guess I don't really have a "wide angle" category.  I just skip right to ultra hehe!
I messaged Voigtlander and they said Spring 2015 is their plan. I don't think I have that kind of patience, I need to get something wider.
Michael L NYC 99
Michael L NYC 99 Veteran Member • Posts: 5,239
There's also the Rokinon 10mm f2.8. It's a big heavy lens, but it is very sharp.
Michael
See my Flickr photostream here Michael.Lee.Pics.NYC
 Michael L NYC 99's gear list:Michael L NYC 99's gear list
Olympus E-M5 II Sony a7R II Nikon AF Nikkor 85mm f/1.8D Panasonic Leica D Summilux Asph 25mm F1.4 Panasonic Lumix G Vario 100-300mm F4-5.6 OIS +15 more
eques Veteran Member • Posts: 4,115
The best AF 12mm lens ...
..., according to the reviews I read, is  - strangely - the Olympus 2,8/12-40.
Perhaps it is even the best or all mFT lenses, if you can live with F2,8 and its size and weight.
But then you have the zoom to 40mm, WS and close focus, too.
Can't give you personal experiences though, as I still use my 14-45 for WA or the Rokinon 7,5 for UWA.
Peter.
 eques's gear list:eques's gear list
Panasonic Lumix DMC-GX8 Panasonic Lumix G 20mm F1.7 ASPH Olympus 12-100mm F4.0
bs1946
bs1946 Veteran Member • Posts: 7,780
I have the Olympus 12mm f/2.0 and the 17mm f/1.8 Their field-of-view is far enough apart that they complement each other. They both have extremely well built, metal bodies, and are small which makes them great on my E-M10. Both have blazing fast autofocus and are sharp with good IQ; the 12mm is the better of the two. The AF/MF snap back feature will not work on a Panasonic body and if you use manual focus for your work; you will be spinning the focus ring forever.
I don't do video and have no experience with the other two lenses. However if you do use manual focus for your work, either one would probably a better choice.
Bill S.
Digital film is cheap; shoot fast and shoot often!!!
 bs1946's gear list:bs1946's gear list
Panasonic Lumix DC-GX9 Panasonic 20mm F1.7 II Panasonic Lumix G 14mm F2.5 II ASPH Panasonic 12-60mm F3.5-5.6 OIS Apple iPhone 12 Pro Max
Re: The best AF 12mm lens ...
Peter.
The 12-40 really is a fine lens, and has cut into how much I use the 12/2.0. They both share the snap MF feature as well.
The prime, of course, is a dream to handle and that extra stop can come in handy. For video, I imagine the extra bit of subject isolation is a tangible plus.
Rick
—Mark Twain
These two lenses stand on their own and it is a perfect pair
Leo
Snap focus works fine on a Panasonic GX1
I don't know what you expected, but it seems to work just fine on my GX1. When engaged you get a brief message saying "switch to manual focus" and can then focus manually as I expected. The AF/MF button is disabled (quite reasonable). What you don't get is the magnified view that you see with regular MF when adjusting focus (though perhaps there is another way to activate this if desired). Push the ring forward and it returns to the previous focus mode.
Tested just now using the 17mm f/1.8.
I didn't find regular MF to be spinning the ring forever either, though it might have been close to the required position when I entered MF mode.
Mark
