Panasonic 14mm - why bother with the Leica 15mm ?
Started Sep 22, 2014 | Discussions
Miron09 Senior Member • Posts: 1,068
 Miron09's gear list:Miron09's gear list
Olympus PEN E-P1 Olympus PEN E-PL1 Panasonic Lumix DMC-GF3 Olympus PEN E-P3 Olympus PEN E-PL5 +18 more
Panasonic Lumix G 14mm F2.5 II ASPH
Fredrik Glckner Veteran Member • Posts: 3,894
Re: Panasonic 14mm - why bother with the Leica 15mm ?
Yes, I think the Lumix 14mm lens is very good. Here is a comparison with similar lenses for other systems:
http://m43photo.blogspot.de/2014/08/wide-angle-prime-lenses-compared.html
The Lumix lens wins this comparison.
kenw
kenw Veteran Member • Posts: 7,095
Because the 15/1.7 can render like on the left, while the 14/2.5 can only do what is on the right?
Earth shattering difference? No, but the 15/1.7 gives more of a sense of depth and has a more contrasty and saturated rendering of the out of focus areas. This by the way is a bit of a crop of the full field of view just so it is easier to see the differences. You'll want to click to see at full resolution.
The 14/2.5 when bought used or split for a kit at less than $200 is certainly quite a tiny little bargain when compared to the 15/1.7. And if you are going to be shooting stopped down a bit there is little advantage to the 15/1.7 at equal apertures to the 14/2.5 from say F/4 or smaller.
Ken W
See profile for equipment list
 kenw's gear list:kenw's gear list
Panasonic Lumix DMC-GM1 Nikon Z7 Panasonic Leica DG Summilux 15mm F1.7 ASPH Nikon Z 14-30mm F4 Nikon Z 24-200mm F4-6.3 VR +46 more
OP Miron09 Senior Member • Posts: 1,068
I'm waiting for the 14mm Schneider
otherwise I'm a reluctant WA user, rarely use anything below 25mm, and hence the Panasonic pancake is sufficient for my needs
C Sean Veteran Member • Posts: 3,423
Re: I'm waiting for the 14mm Schneider
There is nothing wrong with either lenses. It just one lens is better than the other when it comes to low light shots. So if you like to take wide angle shots in low light then the 15mm 1.7 is perfect for you, otherwise get the 14mm 2.5 or the 12-32mm if you not planning on shooting  landmarks at night or a Stegosaurus in the national history mesuem. Both lens do their job well and it's great we now have excellent choice for primes and zooms in the 12 to 45 focal length.
