Canon should discontinue this
Started Sep 22, 2014 | User reviews
EduPortas Contributing Member • Posts: 839
Re: Canon should discontinue this
I agree. I tried using this lens for video on my 6D and IQ was not good at all
(video tends to bring out the best and worst of all lenses).
Bought a nice fixed F2.8 28mm IS by Canon and the difference was astounding.
I know that fixed lenses are supposed to have much better performance, in general, than
zoom lenses and that the comparison seems unfair, but in this case it was that dramatic.
So yeah, I sold the zoom lens. I preferred quality over convenience.
Scott Larson Veteran Member • Posts: 7,505
Is that due to the lower resolution of video?
Yes, if you only intend to shoot at 28mm then by all means purchase a prime lens at that focal length.
However I don't find the center quality of the cheaper older zoom to be all that bad:
http://www.wballphotos.com/28f35.jpg
This would look fine on a 1.5X crop camera although the edges and the top of the image look pretty bad in full frame.
 Scott Larson's gear list:Scott Larson's gear list
Sony RX10 IV Canon EOS 5D Canon EOS 5D Mark II Canon EOS-1D Mark IV Canon EOS-1D X +17 more
Yes, video format exposed the lesser qualities of the lens. That's one of the reasons videophiles are obsessed with sharpness. Even though we'll turn it down all the way when recording our footage, we will manually increase it again in PP. So the better sharpness you get natively, without any processing by the camera, will be better in the end.
As you say, the edges were unusable on FF. That was my experience on the 6D.
SnappyChappie Regular Member • Posts: 434
Another lens i'm surprised is still on the books is the EF-S 17-85mm f/4-5.6 IS USM as i thought that the EF-S 15-85mm f/3.5-5.6 IS USM was it's replacement as well as having a more useful wide-end and better IS.
 SnappyChappie's gear list:SnappyChappie's gear list
Canon PowerShot A620 Canon EF 100mm F2.8L Macro IS USM Canon PowerShot SD780 IS Canon EOS 6D Canon EOS M50 +13 more
quiquae Senior Member • Posts: 2,265
Yeah, but the 15-85 is much more expensive than the 17-85.
17-85 is already off the catalogue in Japan, by the way. But then again, Canon tends to discontinue older models more quickly in Japan than in other markets (we lost the 75-300 a while ago, for example).
 quiquae's gear list:quiquae's gear list
Canon EOS R5 Canon EF 100mm F2.8L Macro IS USM Canon EF 70-200mm F4L IS USM Canon EF 16-35mm F4L IS USM Canon EF 100-400mm F4.5-5.6L IS II +6 more
Did you not view the linked photo? They're only unusable if you're pixel-peeping or making large prints. Most people don't make large prints. Ever.
This is very acceptable performance for a cheap consumer wide-angle to telephoto zoom lens with old IS. The center performance is excellent so it would be good choice for a crop camera.
