ultraviolet photography
Started Sep 21, 2014 | Discussions
chihiro1 Junior Member • Posts: 33
Hello,
I would like to ask you about some advice regarding the images below : I would like to try and test how to achieve similar effect like on the image bellow?
Can you tell me how do you think is done? with ultraviolet filter?
can I achieve that with digital camera canon 5d markIII?
I appreciate every opinion!
Sailor Blue
Sailor Blue Forum Pro • Posts: 14,744
Re: ultraviolet photography
You would have to have the UV/IR blocking filter removed from the image sensor, use black light illumination, and possibly use a UV pass filter to block all visible and IR light.  You might also have to get a special lens since normal glass does a pretty good job of blocking UV light.
EXTREME TECH - How to turn your DSLR into a full spectrum ‘super camera’
randombio.com - Ultraviolet photography with a modified D90 DSLR
Living and loving it in Pattaya, Thailand. Canon 7D - See the gear list for the rest.
 Sailor Blue's gear list:Sailor Blue's gear list
Fujifilm FinePix Real 3D W3 Canon EOS 7D Canon EOS 5DS R Tamron SP AF 90mm F/2.8 Di Macro Tokina AT-X 16-28mm f/2.8 Pro FX +9 more
Mike_PEAT Forum Pro • Posts: 13,344
In addition to modified camera, a special lens is needed...
The following video should explain everything:
http://www.youtube.com/watch?v=UrvViq2Y7OE
But the basics besides a modified camera and UV light source is a special lens that has quartz optics instead of glass optics. The video gives suggestions.
